Used Rock Warrior Wheels vs new Methods
Discussion in 'Wheels & Tires' started by UTAHRTK, Apr 10, 2020.
  1. Apr 10, 2020 at 8:16 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Currently contemplating used RW wheels or new Method 701s or 704s in bronze. Like to hear thoughts & opinions. If I go RW I would end up using 1.25" spacers. Thanks.
  2. Apr 10, 2020 at 8:18 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Can you find or have some RW's wheels available? If not, they can be hard to find and expensive when found.
    Leo's first and EDDO like this.
  3. Apr 10, 2020 at 8:23 AM
    UTAHRTK
    SOCAL
    There are a few sets available - used and not very cheap. Its difficult to justify but they are so damn classic. I can get Methods for about $500 cheaper- That is a chunk of change but not too bad over the long haul.
  4. Apr 10, 2020 at 8:26 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    RW with spacers and 35s will rub cab mount.
    I vote RW, 35s, no spacers.
    Pbed85 and cmack like this.
  5. Apr 10, 2020 at 8:26 AM
    Trooper2
    JR
    I would probably vote to keep it simple (and cheaper); new wheels with desired offset.
    TheBeast likes this.
  6. Apr 10, 2020 at 8:27 AM
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    I’ve heard using spacers and “off-roading” aren’t a good idea. Everythings riding on the spacers to stay put.
    Can’t say for sure on that, just some things I’ve seen on other forums. Could just be “bro-science”.
    I vote Methods but I’m biased.
    Either way good luck!
  7. Apr 10, 2020 at 8:27 AM
    Elduder
    Elduder New Member
    Does weight matter, RW with spacers are going to be around 26lbs the methods will be closer to 30. I think it really comes down to looks on this one though. If you want the best of both though, try the 313s they weigh about 25lbs or so.
  8. Apr 10, 2020 at 9:09 AM
    UTAHRTK
    SOCAL
    Thanks. I have heard same with regard to spacers. Weight is a concern but not a show stopper. Those 313s are nice! Reckon the scale is leaning towards methods or maybe Icons.
  9. Apr 10, 2020 at 9:10 AM
    recomr
    recomr New Member
    My 305/70/17 Ridge Grapplers wrapped around RW.
    1.25 Spidertrax spacers.
    Bilstein 6112 @2.5 /Icon 2.0 rear.
    NO BMC or UCA issues. Not even close. Im still running mud flaps all around, with heat gun trick in the front.
    I like the 701s. If I could have got those for the price I got these, I would have. Money in the bank is always good.
  10. Apr 10, 2020 at 9:14 AM
    UTAHRTK
    SOCAL
    Your set up is what started me on the RW trip- nice! You must have gott'n a smoke'n deal on those. With spacers is the offset around +18? I was originally going with 701's with 0 offset- starting to back pedal to +25 now. Im only at 1.5" in front and still need to figure out tire size with whatever offset I go with.
  11. Apr 10, 2020 at 9:15 AM
    UTAHRTK
    SOCAL
    @recomr where are you located if you don't mind me asking? VA?
  12. Apr 10, 2020 at 9:20 AM
    recomr
    recomr New Member
    Nice! Cool to hear. I like the way the 34s look. These trucks swallow tires. That said, I might go down a size next time for performance reasons (shift points/less weight).
    I found them on Facebook. They were pretty gross when I got them. Had to put some major elbow grease in. $500. 0 offset looks awesome but damn would that be a PITA on 1.5" up front. I'm at a good medium here. Helps protect paint a little too. Good luck!
  13. Apr 10, 2020 at 9:21 AM
    recomr
    recomr New Member
    Im from VA, down in Florida now. Don't wheel as much as I used to in the Blue Ridge mountains anymore. :(
  14. Apr 10, 2020 at 10:17 AM
    UTAHRTK
    SOCAL
    Yea I hear you on the performance side. That is a primary objective for me to maintain close to stock shift points, low end torque, hp... Double edged blade I guess- either settle for lower and smaller or man up and regear. I will not be regearing so...Take care.
    recomr likes this.
  15. Apr 10, 2020 at 10:34 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Wheel spacers with new studs are perfectly safe as long as they're installed correctly (ie. torque, Threadlocker, cross-tightening). I've ran different sets of spacers since my truck was basically new in 2014. Today, I'm running 1" spacers up front and 2" in the rear. Also note that 1" is the lowest you can go on the front and 1.25" is the lowest in the rear because the stud lengths on the OEM hubs are different lengths. Here's how my truck sits today..
    https://www.instagram.com/p/B9Sicurnxkm/?igshid=q90x6dvxu2nm
    Hbjeff, pvn.beluga, stewtopia and 3 others like this.
  16. Apr 10, 2020 at 11:58 AM
    Elduder
    Elduder New Member
    Icons and Fifteen52 both make 17s that weigh in around 27lbs. I will likely go Icon due to the +25 offset
  17. Apr 10, 2020 at 2:02 PM
    UTAHRTK
    SOCAL
    Damn that is a beast.
  18. Apr 10, 2020 at 2:37 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Rock Warriors powder-coated black, chrome ring delete, 285/75R17.
  19. Apr 11, 2020 at 5:13 AM
    UTAHRTK
    SOCAL
    Great looking truck! Thank you guys for the feedback and info and making the decision harder.
    EDDO likes this.
  20. Apr 11, 2020 at 5:36 AM
    UTAHRTK
    SOCAL
    @recomr for your drop down size what are you thinking? 305/65 or 295/70? Just curious.
    Jbickel likes this.
  21. Apr 11, 2020 at 6:10 AM
    11CMGray
    11CMGray New Member
    Have you looked the the icon 6 speeds. Very similar look to RW with a 25 offset.
  22. Apr 11, 2020 at 6:20 AM
    UTAHRTK
    SOCAL
    Yes I like the six Speed wheels- the drawback I had was that those are not hub centric for the Tundra. The rebounds are hub centric at 110.0 mm bore.
    bob949 likes this.
  23. Apr 11, 2020 at 6:42 AM
    11CMGray
    11CMGray New Member
    This true, haven't researched to see if the rebounds are, though it seems you did. I haven't had any issues with the six speeds not being hub centric, there is a whole thread on here about them I looked at and didnt appear to be an issue that I saw from those who had them for extended time.
  24. Apr 11, 2020 at 6:55 AM
    UTAHRTK
    SOCAL
    I have seen plenty Tundras here running them and have heard of not issues. Don't know what wheel to go with... 0 offset or +25 offset. I have at least decided to go with 17's!
    EDDO and 11CMGray like this.
  25. Apr 11, 2020 at 7:53 AM
    11CMGray
    11CMGray New Member
    I wanted the bronze methods nv 305 for the longest time. Because I only have bilstein 5100s in the front, I was able to fit a bigger tire with the icons with no rubbing. That's pretty much what narrowed it down for me. If you're Clearence is big enough it definitely opens up your choices on wheel selection making it much harder
  26. May 3, 2020 at 5:10 AM
    geargarcon
    geargarcon New Member
    What do you mean new studs? New on the spacer or on the truck?
    I’ve heard stories of spacers failing in the internet, but never first hand in person or on any forum
  27. May 3, 2020 at 6:25 AM
    Twise
    Twise More punk than you...
    Trever
    Temecula, California
    2017 Tundra Cmax TRD Off-road
    Fox 2.5 /w DSC CO’s and Rear Shocks, Total Chaos UCA’s, 17” Rock Warriors /w 35 12.5 17 BFG AT KO2’s, Powerstop Rotors and Pads Front And Rear and The stereo is really nice.
    I went with RW’s so I could run 35’s with no chop. They fit fine with a front mud flap delete and a trim on the OEM skid. I could find no AM wheel with the proper backspacing.
    17 inch RW / 35x12.5 BFG KO2 - 2” Lift front / 0” Lift rear
    EDDO and recomr like this.
  28. Aug 22, 2021 at 10:25 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    When you removed the bead lock, was there a bunch of residue underneath? I like them better without the beadlocks but I have read it is impossible to get the crud underneath off
    EDDO[QUOTED] likes this.
  29. Aug 22, 2021 at 5:57 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    There was. Powder coat shop did a nice job getting them looking good. I have a feeling they also laid up more paint on those areas because they weren’t smooth when I dropped them off.
    Ring pulled:
    My attempt at cleaning:
    Final product:
    Mattyc and RobertD like this.
  30. Aug 22, 2021 at 6:10 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Damn those look great. How did you clean them?
