Using Battery For Running Air Compressor
Discussion in '3rd Gen Tundras (2022+)' started by bigbenride, Oct 24, 2023.
  1. Oct 24, 2023 at 7:40 AM
    bigbenride
    bigbenride [OP] New Member
    2024 tundra 1794 TRD
    New truck not delivered yet but important info needed. Anyone use the battery to power a very large compressor to air up. It has alligator clips and motor is not Hybrid.
  2. Oct 24, 2023 at 7:44 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Define a "very large"? I have a 5.65 CFM Smittybilt, it airs up 4 33" tires from sub-10 to 30 PSI without problems. I also run a 350 Watt 4-stage 5000 PSI airgun pump for about an hour from my 10 years old second battery before it slows down enough for me to start the engine and charge it up.
  3. Oct 24, 2023 at 7:50 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    First off...welcome to the forum.
    Secondly, to answer your question: Yes. I've run my 10.6 CFM dual cylinder air compressor from my battery 3 or 4 times when airing back up. It hasn't been a problem. Should go without saying: Have you truck running at the same time. :)
    RickyBobbysTundra and Mike59 like this.
  4. Oct 24, 2023 at 8:45 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    alligator clips doesnt mean anything. What amp draw? and for how long are you planning on running it?
  5. Oct 24, 2023 at 9:53 AM
    KroppDuster
    Bilstein 5100s
    Probably 90 amps with a 30 minute duty cycle. That's about the going rate for the bigger dual cylinder units, as far as I'm aware. I'm pretty sure my unit is in line with those specs. However, 30 mins is extreme. I can air up all 4 tires at once in about 8-10 mins from 15 psi to 40. I've never had to run it at the full duty cycle.
  6. Oct 24, 2023 at 10:13 AM
    AZBoatHauler
    So.Arizona
  7. Oct 24, 2023 at 11:12 AM
    eddiefromcali
    Eddie
    100% Stock
    AZBoatHauler[QUOTED] likes this.
  8. Oct 24, 2023 at 1:14 PM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
  9. Oct 24, 2023 at 1:59 PM
    AZBoatHauler
    So.Arizona
    I’m not - but the trailer plug will be set up the same way. Wire the connecter onto your compressor so the + goes to charge and the - goes to ground.
  10. Oct 25, 2023 at 11:03 AM
    bigbenride
    Thanks to all and I appreciate your support. I’m a little hesitant with these new trucks with all the tech stuff nowadays. My Previous trucks were so simple. Thanks again for welcoming me to this forum.
    Nio9 likes this.
