Using exiting Bed Lights to power LED strips
Discussion in 'Lighting' started by MogwaiBoogie, Dec 23, 2024.
  1. Dec 23, 2024 at 8:18 AM
    MogwaiBoogie
    MogwaiBoogie [OP] New Member
    Justin
    TEXAS
    2020 Tundra Platinum
  2. Dec 23, 2024 at 8:23 AM
    You should be fine. I have the same set. Mine are tapped into the parking light circuit and on a switch mountedin the bed. That way I'll never have to worry about them being left on.
  3. Dec 23, 2024 at 8:39 AM
    SD Surfer
    Bruce
    So Cal
    I don't see why not.
    I have those same strips (except the 3-pc) and love them.
    I personally chose to go straight from the battery into the bed because I wanted constant HOT without having to open the cab and futz with any other switches to energize my lights &/or 12V/USB receptacle.
    If I have a cart full of stuff at Costco I want to just drop the tailgate and turn on the lights without going to the cab.
    I use the 12V outlet to plug in a portable shower to rinse off after surfing. I want to be able to drop tailgate and have my hot shower ready without dropping saltwater on everything up front turning stuff on.
    But that's what I decided works best for me... Your mileage may vary.
    FYI, a lot of the reviews say the adhesive on those light strips isn't very good... I cleaned the hell out of the mounting surface with alcohol and they have stayed stuck very well. I see you're in TX so I dunno what summertime heat in Texas will do to the adhesive, (Damn near killed me) but I've had no problems with my light strips sticking.
    Bed lights are a great mod that comes in very handy.
    BlackNBlu likes this.
  4. Dec 23, 2024 at 9:41 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    I am so doing this.
    The O.E. bed lights that came with mine are like the interior lighting. DIM.
    When I want light in the bed I want it to look like @SD Surfer 's above.
    I like the power tap/outlet also. :thumbsup:
    SD Surfer likes this.
  5. Dec 23, 2024 at 10:08 AM
    SD Surfer
    Bruce
    So Cal
    Yeah I love my Toyotas but they are kinda stingy with the lumens!
    I was shocked they gave my 2019 truck like 43 12V outlets in the cab but couldn't throw one in the bed?! Come on...
    Here's a thread when I did it. https://www.tundras.com/threads/whooo-bed-is-almost-dialed-bedrug-check.124960/
    I'm happy with how mine turned out and I use the hell out of both the power and the lights, makes my world so much easier... But if I were doing it over again I'd go with a little bigger box.
    I'm like $20 all in for mine and that's just a 2-gang junction box from the Home Depot electrical aisle, but when I added the lights it got a little tight stuffing all the wires, connectors, and fuses back in the box.
    @dittothat has a nice setup he posted using some nice waterproof boxes that are available in all different sizes on Amazon.
    https://www.amazon.com/dp/B08394K2LZ?th=1
    Doing it over I would use a bigger box and maybe put dedicated switches for each... 12V, USB, Lights.
    BlackNBlu[QUOTED] likes this.
  6. Dec 23, 2024 at 10:28 AM
    SD Surfer
    Bruce
    So Cal
    Sometimes I'll be doing something in the bed at night and briefly forget about the lights... Hit the switch and I swear I kiinda' hear the angels sing. :rofl:
  7. Jan 26, 2025 at 4:02 PM
    Mexican Papi
    Mexican Papi New Member
    2023 Tundra SR5
    Tonneau Cover for now.
  8. Jan 26, 2025 at 4:08 PM
    Double check the fuse but it sounds like you said that you are getting 12 volts on the meter? Maybe try a different grounding spot as well.
