Valve cover gaskets, intake gasket, cam seals etc
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Apr 7, 2025.
  1. Apr 7, 2025 at 6:03 PM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I'm trying to develop a plan of attack for upcoming projects over the next year and further down the road that potentially involve valve cover gaskets, intake manifold gasket, cam seals, oil pump, oil pan gaskets, and possibly the starter
    I've read where some suggest to go ahead and replace the intake manifold gasket while you're doing the valve cover gaskets. And then within that thread, other suggested to go ahead and replace the starter since I would have the intake manifold off
    With my limited knowledge of my tundra top end at the moment, I believe if you're replacing the cam seals on a VVTI you also have to take the valve covers off and remove the cams
    if I do go ahead and replace the valve cover gaskets and intake manifold now, i'm assuming I'll have to redo the valve cover gaskets whenever I do the cam seals - correct?
    I saw no signs of seepage with the cam seals when I did the timing belt this past summer. It would really be nice if I could delay replacing them when I do my next timing belt until the following timing belt change because on my next timing belt change I plan to replace the oil pump. Doing all of this at one time would be a major multi-part time-consuming project that would have me down for a while so I'd rather split it up. I'm not quick. I just plod along.
    On a 19-year-old truck with 320,000 miles should I consider replacing the starter while replacing the intake manifold gasket even though it seems fine? Is that something I could just replace the brushes and essentially do a rebuild?
    Since I've not yet touched the top end it's hard for me to gauge the best order of attack
    as it stands right now this is my plan:
    1. First project this spring or summer: replace valve cover gaskets, intake manifold gasket, spark plugs, any damaged coil packs, possibly the starter. Likely remove secondary air pump since it is by-passed and no longer used after installing the LT headers
    2. Second project in about 60 to 80,000 miles (in roughly 3 years): replace timing belt, crank seal, oil pump (due to damaged threads for the tb tensioner bracket - repaired now with big SERT kit) and oil pan gaskets.
    I'm probably answering my own question but if I can hold off doing the cam seals at my next timing belt change until the subsequent TB change, then I won't be replacing them for another 160 or 180,000 miles which would probably be a good time to do the valve cover gaskets again anyway
    Any thoughts or suggestions as appreciated, particularly about the starter
  2. Apr 8, 2025 at 5:55 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    I wouldn’t do cam seals, unless leaking, ever. The starter should be good, unless you’ve had issue. I wouldn’t replace my starter, I’d have it refurbished my a 12v motor specialist, here in Tucson we have “Luna” they rebuild starters and alts, keep it og Toyota. I have only worked on the 5fevz, so I’m not fluent on the v8s. As far as main seals, I’d only replace what leaks. Hope this helps
    Weagle[OP] likes this.
  3. Apr 8, 2025 at 6:15 AM
    What he said ^^ on starter, just give it the @KNABORES treatment! Or, actually, better yet, maybe just replace proactively while Denso is still making the part. Hell, why not? Clean up any grounds you see in there. Wrap your wires under there with rodent tape.
    If cam seals aren't leaking, I wouldn't touch. Unless you really feel motivated to get in there. If you had the '00-04 where it's relatively easy, I'd say "Go for it, while you're in there!" but ... nah. AT-205 shored up the small driver side cam seal leak I had going on.
    Yes, if pulling valve covers anyway, cleaning up things in there, and re-FIPG of the corners and half moons is worthwhile. You could try buttoning things back up and hope for no leaks, but it doesn't take much more time to just clean and re-do everything. Don't let any little bits of old FIPG or other crud fall into the head. Take a once-over before reinstalling the cover to pick any little bits out.
    Intake gaskets if manifold is off: That's more of a non-VVTi thing, the gaskets are different. Our VVTI ('05-06) intakes use a molded rubber gasket. Not saying it's not necessary, that rubber is aged, so why not? But that recommendation to swap the intake gaskets, whenever I've recommended, is for the earlier trucks with silver intake manifold. And I'd only replace the manifold-to-head gaskets, not the gasket that sits in between the two halves of the intake manifold.
    Coil packs ... Before you do anything, understand cracks on the outside plastic likely don't mean shit about health and here's why.
    I wonder if removing the SAI pump will actually cause an error to throw, if the ECU recognizes the circuit is open? Just a thought. I can't say for sure. But if removing that, I almost feel like "why not just go the distance", remove the solenoids above the valve cover, remove the valves off the back of the manifold/heads, install some blockoff plates where the valves bolt on ... ?
  4. Apr 8, 2025 at 6:20 AM
    I replaced mine recently with an OEM reman due to exactly what @shifty` said, parts availability. I have replaced the contacts and plunger before on my OEM one and kept it to rebuild as a backup, but many of our parts are getting DC'd so I wanted to have another Denso one. Probably need to order another alternator also, even though my OEM has not failed me yet.
    Weagle[OP] and G_unit3000 like this.
  5. Apr 8, 2025 at 7:13 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    It would be neat to have a list of parts that have potential to get discontinued that might be worthwhile having backups for. I don't want to induce panic buying, but for example, we can't get OEM CV axles anymore.
    Weagle[OP] and PNW15 like this.
  6. Apr 8, 2025 at 7:45 AM
    Someone started a similar thread, but ultimately it's really tough to say.
    We've just noticed a decline in availability of, for example, Denso fuel pump for earlier models, alternators for all models, various trim parts many of which are only coming in beige, rear drum adjusters on earlier years, there's no real rhyme or reason I can understand from the discontinuations.
  7. Apr 8, 2025 at 5:31 PM
    Weagle
    Prattville, AL
    I was agonizing over some of the schematics, trying to order some parts and saw that Toyota offers a remanufactured starter with an $80 core charge. I was curious if anyone had tried it so I didn't recall in your build thread which option you chose but sounds like you did the reman so that is probably what I will do
    I may do the same with the alternator as well
    Both times I'll just pay the core charge and keep my original
  8. Apr 8, 2025 at 5:33 PM
    I did not send a core in, so not sure
  9. Apr 8, 2025 at 5:42 PM
    Weagle
    Prattville, AL
    Great info as always.
    I'd ordered one of the Hewitt bypass kits last year but I think it is the most simple one with just two block off plates. I would rather eliminate some of the extraneous parts if they're not needed
    I was curious about removing that SAIS pump as well. I know the ECU programming keeps it from throwing a code as it is now with the LT headers, but I'm gonna talk to the seller of that ECU to be sure removing the pump won't cause problems. And I was hoping to read up and research on that whole system I wasn't aware of the solenoids you mentioned, but I knew there was more to it I would like to remove anything unneeded with the SAIS system
    yeah I'm definitely gonna do a thorough cleaning with new gaskets and FIPG the half moons
    I agree about those cam seals. I'm just gonna let those go. There was no signs of leaking when I did the TB last summer. I know they are a pain in the ass since you have to remove the cams so I will put that off and do it only when it is absolutely necessary. Most everything else I'm trying to be proactive and do preventative maintenance
  10. Apr 9, 2025 at 7:02 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Just an fyi, if your starter works, leave it alone. I’ve seen a few issues with Denso remans not lasting lately.
    Now if you want to buy and hoard a spare, I can’t argue with that.
    It would be interesting to see if the Denso remans sold as Toyota parts get better or extra treatment vs aftermarket Denso rebuilt parts (starters and alternators).
    Weagle[QUOTED][OP] and shifty` like this.
  11. Apr 9, 2025 at 7:04 PM
    Mine was a Toyota branded Denso reman. I popped it open to inspect. All shiny and new inside. So far it's been rock solid.
    Weagle[OP], rouxster70 and shifty` like this.
  12. Apr 9, 2025 at 7:15 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I think thats the ticket. The failures that I have seen were Denso boxed, not Toyota. Toyota is specifiying better grade of rebuild.
  13. Apr 9, 2025 at 7:53 PM
    Weagle
    Prattville, AL
    What did you pay for yours? I guess I'll call the dealership because I can't tell the difference in these three
  14. Apr 9, 2025 at 8:19 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    50090 is the 1.4kW starter.
    50100 and 50101 are both 2.0kW starters.
    50101 shows as the correct part for 2006. This is the one I would purchase. Your truck may have the 1.4kW starter if the dealer checks by VIN number, but there is no real downside to installing the stronger starter.
    My guess is the starter part number changed for some reason for the 2005 and 2006 4.7 V8 engines.
    On the Denso 2.0kW reman, it crosses to both 50100 and 50101. There is probably very little difference between the 2.0kW starters.
  15. Apr 9, 2025 at 8:32 PM
    Weagle
    Prattville, AL
    Big help, thanks
    odd that the least powerful is the most expensive
  16. Apr 10, 2025 at 5:21 AM
    IIRC, I think about $180 for the 1.4kw version.
  17. Apr 10, 2025 at 6:05 AM
    Mine was a 50070. $163 before discount
  18. Apr 10, 2025 at 6:18 AM
    Also of note on that list. I only ordered one upper ball joint and one tie rod end. Duh. Then the steering rack bushing is actually one of the large internal metal piston looking things with seals on it, not the rack mount bushings I was trying to order. Toyota parts ordering be hard yall
  19. Apr 10, 2025 at 6:25 AM
    Weagle
    Prattville, AL
    I was thinking when you posted that that was a great price for what all you got didn't notice the quantities
    I need to get up an order while the 25% discount is going on. Intake gaskets, I assume OEM for valve cover gaskets, probably the rebuilt starter and alternator, probably an oil pump even though that's down the road, and I'm sure a few other things I'm forgetting
  20. Apr 10, 2025 at 6:36 AM
    I've honestly not heard, or can't remember ever hearing anyone having to replace the oil pump in the 2UZ.
  21. Apr 10, 2025 at 6:37 AM
    Weagle
    Prattville, AL
    I have the stripped and repaired bolt hole for the timing belt tensioner bracket which just happens to mount into the oil pump. I'm going to do it at my next timing belt change Otherwise, I'm like you, I've never heard of any issue
    KNABORES[QUOTED] likes this.
  22. Apr 10, 2025 at 6:38 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Perhaps Serra's entry is incorrect. Ourisman Toyota is another online to check out, who was McGeorge Toyota at one time. They still have good online service via email and competitive in price.
    Weagle[QUOTED][OP] likes this.
  23. Apr 10, 2025 at 6:41 AM
    Weagle
    Prattville, AL
    Thanks I've bought from McGeorge/Ourisman Toyota before. Those are better prices even with Serra's 25% sale
    I must be going to the wrong place. I know I've looked up parts on their site before. When I go there, it wants you to submit your name and contact info and request pricing
    BubbaW[QUOTED] likes this.
