Valvoline MaxLife Trans Fluid For PS Fluid?
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Patriot 1776, Oct 9, 2020.
  1. Oct 9, 2020 at 8:17 PM
    The Patriot 1776
    The Patriot 1776 [OP] Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I know the manual says to use WS trans. fluid for the PS fluid. I want to use Valvoline MaxLife synthetic trans. fluid as it’s a really good trans. fluid.
    It has friction modifiers that the WS fluid does not have. Will this harm my new rack and pinion I’m installing?
    I would think it would be better than the standard Dexron III WS fluid but I wanted to make sure. Thanks.
  2. Oct 10, 2020 at 5:37 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The Repair Manual is not picky about the type of power steering system fluid used . Dexron II, Dexron III or equivalent is recommended. WS fluid is not mentioned, which implies that any good quality Dexron II or III fluid is fine for the PS system.
    MaxLife will be certainly be a cheaper alternative than WS. MaxLife is synthetic providing some advantage regarding higher operating temperature. Many Toyota owners have reported good results when substituting MaxLife for WS in their transmissions. MaxLife also offers advantages as ATF, which is the more critical design application. I wouldn't read too much into the claim of "friction modifiers" added...sounds like marketing to me.
    The Patriot 1776[OP] likes this.
  3. Oct 10, 2020 at 5:38 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I use Maxlife for the trans. Anything extra goes into PS fluid swap.
  4. Oct 10, 2020 at 6:10 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I use it for both the transmission and pet steering fluid.
  5. Oct 10, 2020 at 6:16 AM
    Vizsla
    Vizsla 2 = 2.5
    I don’t see “or equivalent” for power steering fluid, would use what is recommended by Toyota.
    YardBird likes this.
  6. Oct 10, 2020 at 7:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd assume that's because Dex3 is a standard. If it said Toyota Dex3 the "or equivalent" would likely have been added since it's a specific product.
  7. Oct 10, 2020 at 10:26 AM
    JohnLakeman
    As I said, my information from the Toyota Repair Manual, not the Owner Manual. If the OP uses exactly what the Owner Manual says, he'll be safe:
