Vantrue N2 Pro Dash Cam
Discussion in 'Audio & Video' started by Bulldog1, Dec 17, 2019.
  1. Dec 17, 2019 at 4:50 AM
    Bulldog1
    Bulldog1 [OP] New Member
    Just purchased and hard wired installed. Having issues - 1. Can't seem to get Parking Mode to work. 2. LCD Screen never turns off and cam never stops recording. Need assistance please.
    sprede likes this.
  2. Dec 17, 2019 at 5:57 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    First post I've seen on Vantrue N2 Pro. Appears to have good reviews. If you've installed it properly (double check connections), then the camera is likely defective. Logic says cam should keep recording in park mode, and LCD screen should go to sleep to minimize battery drain. If you bought from Amazon, they'll take it back.
    Like most products anymore, it's made in China dash cam. Attempting to work technical problems through Support is likely to be ineffective, but I would give it a try. I contacted a pad manufacturer website yesterday to ask why a cheap pad wouldn't connect to WiFi when ever other device in the house would. (I anticipated the "Is your router turned on?", and, "Are you entering password correctly?" questions.) They came back to ask if I was getting "Avoided poor internet connection" message while it was connected to the internet! :facepalm:
    https://www.vantrue.net/contact/index.html
  3. Dec 17, 2019 at 6:29 AM
    Bulldog1
    Hi John, thank you very much for your response. I am trying one more thing and it that doesn't do it, I'm asking for a replacement. Have a good Tuesday.
    JohnLakeman likes this.
  4. Mar 5, 2020 at 11:43 AM
    sprede
    sprede New Member
    I just bought my Tundra two days ago. I had the same dash cam installed on my Tacoma, however it did not have the air bags on the side where the handles are. How did you route your wiring?
  5. Mar 5, 2020 at 11:57 AM
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    I have the same model for over a year now. Havent hard wired yet as I may get something else. If the screen never goes off then check the settings mine goes off automatically after about 30 seconds. Only time it comes back on is when I start the truck and screen goes off while still recording.
    sprede likes this.
