Variable Valve Timing Solenoid 2021 Tundra SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by slade.alms, Aug 18, 2023.
  1. Aug 18, 2023 at 3:47 PM
    slade.alms
    slade.alms [OP] New Member
    The 5.7L V8 inside the 2021 Tundra has 4 Variable Valve Timing Solenoids. 2 on each side of the engine. What direct current (DC) reading should I be getting out of the wiring harness that plug into those VVTS's?
  2. Mar 7, 2025 at 7:32 PM
    John P
    John P New Member
    2014 Toyota Tundra SR5 TRD 4x4
    1.5” lift 32” tires
    Hi , did you find out what voltage should we get from the battery to the harness?
    I’m having issues and getting code P0022 on 5.7 tundra 2014.
