Variable valve timing solenoid vvt
Discussion in '2nd Gen Tundras (2007-2013)' started by Vince, Nov 15, 2019.
  1. Nov 15, 2019 at 9:52 PM
    Vince
    Vince [OP] New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Does anyone have any idea if I was to replace these if my 5.7 liter I force motor will return from the 12 valve cummins concert it sings after sitting for a few days.
    :headbang:
  2. Nov 16, 2019 at 7:14 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    A sensible approach would be to try changing to another motor oil for noise relief before tearing down the front of your engine and possibly mucking something up. That approach is too much work for me to contemplate, and the likelihood of it making any difference is low imo. Consensus here is that Toyota engines just "tick" once they are worn in, you have to learn to love it.
    You posted to this thread: https://www.tundras.com/threads/2018-5-7-ticking.54394/. Early posts in the thread actually indicated success by changing from Mobil 1 Advanced Fuel Economy (AFE) 0W-20 to other motor oils silences the noise. I would try Mobil 1 Extended Performance 0W-20 first (different additive package). If that doesn't work, try Rotella Gas Truck motor oil in 0W-20. If the ticking still bothers you, and nothing else has worked, try Mobil 1 (or Rotella) in 5W-20 or 5W-30.
  3. Nov 16, 2019 at 6:53 PM
    Vince
    Vincent
    Run Mobil 1 0 20 from toyota or toyota oil i let them do it. I also add 1 quart of Lucas to every oil change. Still sounds like a 12 valve. Fig vvt silenoid would be easy since they are on top of the valve covers.
  4. Nov 16, 2019 at 9:06 PM
    JohnLakeman
    Oh...I thought you were talking about the main chain tensioner being installed in the link below beginning about 05:15: https://www.youtube.com/watch?v=oaDWBwmtVEE
    Everything on the front of the engine comes off for that one. Good luck.
  5. Nov 17, 2019 at 6:15 AM
    Vince
    Vincent
    Ya I'm not diving into that. At least I hope not.
