Vented Seat Fan Fluctuating
Discussion in '3rd Gen Tundras (2022+)' started by 24TundraTRD, Jun 18, 2024.
  1. Jun 18, 2024 at 5:50 AM
    24TundraTRD
    24TundraTRD [OP] New Member
    '24 CrewMax Limited TRD
    Hello. I'm brand new to Toyota and the Tundra. I like the truck overall but it is a huge change from what I'm I used to. One thing that's bothering me, is the inconsistent fan speed in the vented seats. The fans respond to the setting adjustment (button that controls high/low/med.) But within those settings there is still a lot of fluctuations in the fan speed/noise. They're pretty loud so it's really obvious. I called the dealer and said it's normal. I'm not really sure what I expected them to say. I thought maybe I could link the fluctuations in the volt meter to the fluctuations in the fan noise but that doesn't always line up either. Anyway, just curious is anyone else is experiencing this, if it really is normal, or if there's an issue. It's incredibly annoying to constantly hear the fan run up and down. Thanks!
    2024 Limited CrewMax TRD OR
  2. Jun 18, 2024 at 6:44 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    I've noticed that as well. Ventilation fan speeds seem to correspond to system voltage which usually varies from float charge voltage during cruising speed or acceleration, then a increased voltage during deceleration which is normal for the gen 3's.
    Toyota1234 and mayan like this.
  3. Jun 18, 2024 at 7:41 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Yep, noticed the same thing
  4. Jun 18, 2024 at 8:06 AM
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Yes, if you are running other voltage draws like your AC it definitely makes a difference.
  5. Jun 18, 2024 at 8:52 AM
    24TundraTRD
    Hmm...it's pretty annoying. Maybe I'll get used to it. Is there a way to make the alt run constantly like older models? Maybe that would help?
  6. Jun 18, 2024 at 8:59 AM
    eddiefromcali
    Eddie
    100% Stock
    try putting it in tow mode.
  7. Jun 18, 2024 at 9:01 AM
    24TundraTRD
    I'll give it a shot. Thanks.
  8. Jun 18, 2024 at 9:05 AM
    eddiefromcali
    Eddie
    100% Stock
    hope it works...worked on my GM back in the day. That or turning on the defrost or high beams defaulted the alternator to 14v
  9. Jun 18, 2024 at 9:12 AM
    24TundraTRD
    Is that supposed to be a fuel mileage gimmick, not having it run all the time? It seems like with all the electrical draw in newer vehicles you want it going.
  10. Jun 18, 2024 at 9:18 AM
    eddiefromcali
    Eddie
    100% Stock
    Probably. No need for additional drag if the extra juice isnt needed?
    Rcflyersd likes this.
  11. Jun 18, 2024 at 9:28 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    You can thank epa for that lol. If you have an OBD reader look at battery current and voltage. Around cruising speed my draw is -2 amps at ~12V when I let off it's 14V and + 50-60 amps.
  12. Jun 18, 2024 at 10:36 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    On low voltage "mode" it doesn't discharge the battery, but just doesn't charge it. It's basically a float charge voltage. The engine management system does monitor battery overall state of charge percentage and if needed will bump up system voltage to recharge it for a period. At this time you will also get a notice in the cluster stating auto stop is not available, battery charging etc.
  13. Jun 20, 2024 at 12:38 PM
    24TundraTRD
    But should that effect the operation of equipment in truck? I know fans aren't fancy electronics, but I'd hate to think that some of sensitive electronics weren't getting consistent voltage. Look, if fans blowing up and down is my biggest problem, I'm doing just fine, but I'd like everything the way I like it if possible. I appreciate everyone's input.
    tesilential likes this.
  14. Jun 20, 2024 at 7:57 PM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    I have the same thing on my 24. It is rather annoying. Wish they could just have a constant speed. Other manufacturers do it.
  15. Jun 20, 2024 at 8:13 PM
    tesilential
    tesilential New Member
    Tampa bay
    ‘24 limited lunar rock hybrid TRD off-road
    I’m a fan (no pun, really!) of the seat fans. If I had to complain it’s louder than one would think it needs to be for the force generated.
    ArcticFox likes this.
  16. Jun 20, 2024 at 11:22 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I haven't noticed a change in my fan speed when using the ventilated seats. Either my truck isn't doing it or I'm a moron, but it seems consistent to me.
  17. Jun 21, 2024 at 5:27 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Mine fluctuates all the time.
