Vibration after complete brake job.
Discussion in '1st Gen Tundras (2000-2006)' started by Kgun, Jul 16, 2021.
  1. Jul 16, 2021 at 2:44 PM
    Kgun
    Kgun [OP] New Member
    Minnesota
    '06 Tundra 4.7 V8 SR5
    Changed pads, rotors and drums on '06 Tundra and have vibration when braking, feels like rears but not sure. Also changed out rear cylinders and front brake lines and was pretty anal about cleaning hubs and contact surfaces. Anyone have any ideas?
  2. Jul 16, 2021 at 2:53 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Spray everything with brake cleaner after the install? did you bed in the brakes after install?
    DaWhiteTundra likes this.
  3. Jul 16, 2021 at 2:57 PM
    Kgun
    Minnesota
    Not after, but pretty thorough cleaning throughout. Bedded brakes after my first test run, when I found out about bedding brakes, but didn't drive but a few easy miles in between.
  4. Jul 16, 2021 at 3:19 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Try applying just the emergency brake while driving to see if the rear brakes are causing the vibration. You should be able to feel it without necessarily coming to a complete stop.
    Kgun[OP] likes this.
  5. Jul 16, 2021 at 3:22 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Do you feel the vibration in steering wheel or even the peddle ?
    Assuming it is rear, have you double checked you got parking brake cable installed properly. We have seen that issue on a few occasions !
  6. Jul 16, 2021 at 4:12 PM
    Kgun
    Minnesota
    Thanks Jack n BubbaW, gonna do both and pull the rears to verify all is well. Wish I could do it at work tonight.
    Tundra2 likes this.
  7. Jul 20, 2021 at 4:54 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Had the same thing happen to me. Brand new Power Stop front rotors/pads, new rear drum hat/shoes/cylinders. Shook like a bastard even after several brake bedding runs, rear cylinder adjustments, and even trying to swap the old rotors back on. Turned out one of the drum hats was warped new out of the box. Had them turned and the vibration went away. Hopefully you solve your issue.
    Sampson likes this.
  8. Jul 20, 2021 at 5:59 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    This^
    Many new drums are warped out of the box. Became such a problem in my old shop we would turn every new drum we put on. Most were slightly out, some a lot.
    99% of the time you’ll feel front rotor warp in the steering wheel. If it’s not there, suspect the rear.
    Sampson, tvpierce and the red like this.
  9. Jul 20, 2021 at 7:06 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Do new toyota factory brakes drums need to be turned also?
  10. Jul 20, 2021 at 8:11 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    It’s never a bad idea to check runout on new drums. I installed some new NAPA ones put on along with some other additional parts and they’ve been great. What brand of parts did you go with?
  11. Jul 23, 2021 at 1:00 PM
    Kgun
    Minnesota
    I also went went the Powerstop all the way around. Pulled off rear drums and all is assembled correctly, couldn't feel vibration while pushing down parking brake so suspecting its the rotor/calipers. Was forced to drive it 800 miles to and from WI. this week and slowing down from 70 to 30 was pretty rough. Not sure if I should get OEM rotors and pads or just try rotors first and hope the pads aren't jacked up.
  12. Jul 23, 2021 at 1:41 PM
    Jack McCarthy
    Bill
    North of Boston
    Is there vibration only slowing down from high speeds and not low speeds? I have this issue and it's basically the rear brakes not being properly adjusted. To help I generally engage, disengage the rears several times once a day to help. Basically, the truck just doesn't depend upon the front rotors to do all the work at high speeds and engages the rears. If they're not engaging as well as they should, that puts the burden on the front disks.
    I'd say that was your issue if stopping or slowing down from 40mph or under doesn't create the vibration.
    I'm not sure what Powerstop model you purchased, but quite a few people have been able to correct the problem by going to the Powerstop cryogenically treated front rotors and pads which can supposedly handle the burden unlike the stock OEMs.
    DarkMint likes this.
  13. Jul 24, 2021 at 2:18 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Good to know! That's pretty sad though. o_O
  14. Jul 24, 2021 at 5:06 PM
    Kgun
    Minnesota
    Pretty much got the vibration slowing down from any speed, but much more pronounced from higher. Gonna tear pull front wheels off next free day and see if there's anything obvious. Thank y'all for all the ideas, f'en shame when you do all new and don't get the desired outcome.......but a lot of knowledge was gained and everything comes apart easier now!
  15. Jul 28, 2021 at 1:01 PM
    Kgun
    Minnesota
    Pulled front wheels off, both rotors look beautiful, spun over and no out of round friction of any kind.....bled brakes again since I was in there but no bubbles.....just can't seem to nail it down to front or rears....vibration not bad when braking in steering wheel and can't reproduce inching in parking brake down. SHIT, FRUSTRATING.
  16. Jul 28, 2021 at 10:52 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    This happened on my FIL's 2000 Tundra. Ended up being warped brand new drums.
    Do you still have old drums? Put them on for a short ride if possible and see if any change.
    Jack McCarthy likes this.
  17. Jul 29, 2021 at 10:48 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Yep, drums.
    Local auto parts / machine shop told me they turn every single drum they sell. Something is going on with all the current manufacturing.
    They told me raybestos seem to be the most reliable aftermarket drums.
  18. Jul 29, 2021 at 11:04 AM
    Kgun
    Minnesota
    BOOM!!!! Had my coworker pull old drums out of metal dumpster, installed and smooth as silk!!?!!!!!!! Now to return to RockAuto.
    DarkMint, bmf4069 and Jack McCarthy like this.
  19. Jul 30, 2021 at 5:58 AM
    Kgun
    Minnesota
    Appreciate all the advice and wish I would have gone after the drums right off but many of my peeps insisted on rotor issues and had never heard of out of round drums. It's a calling to put the word out there to all for the future. Saddest part is manufacturer is aware of defect and won't warranty and Rockauto will only give exchange. Do I really want another set of defective drums? Want my money back or a credit!
  20. Jul 31, 2021 at 11:07 AM
    Riverdale21
    OTP ATL
    Just have your new drums machined. Would probably cost as much as return shipping and you can usually get them back same day. If you have Napa or O'Reilly in MN some of those stores have machine shops that can cheaply turn your drums for you.
