Vibration/shudder while towing…
Discussion in '3rd Gen Tundras (2022+)' started by NATE4SURF, Jul 10, 2023.
  1. Jul 10, 2023 at 4:42 PM
    NATE4SURF
    NATE4SURF [OP] New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    3rd Gen SR5 TRD 4x4 with leer topper.
    So I’m on a long road trip and the back of my truck has I don’t know 500 pounds of gear , 4 humans a dog and I’m pulling a trailer that’s about 3000 pounds. When I accelerate towing the trailer at about 1500 to 1700 RPMs I feel a vibration/shudder and then it goes away at about 1900 to 2000 RPMs mostly from when I’m at a dead stop accelerating. Anyone else experienced this? Could it be an engine mount being loose?
  2. Jul 10, 2023 at 6:28 PM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    I tow a closer to 7000 lb travel trailer and have not experienced the vibration/shudder you are describing. I’d say a motor mount is a possibility but could also be any number of other things. Are you using tow/haul mode while towing?
  3. Jul 10, 2023 at 7:41 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Sounds like driveline vibration symptoms to me. Crewmax 5.5 bed? Any lift?
    Durtywrench likes this.
  4. Jul 10, 2023 at 8:16 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Are you using Tow/Haul mode? I ask because it sounds like the torque converter possibly locking up when it shouldn't be.
  5. Jul 10, 2023 at 8:21 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I thought the Same . Especially if it’s diving more under acceleration
    DMackler[QUOTED] likes this.
  6. Jul 11, 2023 at 3:33 PM
    NATE4SURF
    Laguna Hills, CA
    No lift 6.5 bed.
    ryanwgregg likes this.
  7. Jul 11, 2023 at 3:34 PM
    NATE4SURF
    Laguna Hills, CA
    Yes, but I think it’s doing it even not in Tow haul. I’ll check when I leave the park tomorrow. And my trailer is more like 4000lbs.
  8. Jul 11, 2023 at 3:35 PM
    NATE4SURF
    Laguna Hills, CA
    What does driveline vibration mean?
    Durtywrench[QUOTED] likes this.
  9. Jul 11, 2023 at 3:48 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Driveline vibration is the driveshaft wobbling for a sec on acceleration. Extremely common on lifted truck, hence why another user asked, and usually cured by a carrier bearing drop. It's possible your suspension geometry is out of spec a little, and when you load it down it's just enough to induce shudder. Have you had any suspension work done at all?
  10. Jul 11, 2023 at 4:29 PM
    NATE4SURF
    Laguna Hills, CA
    No sir. Everything is stock.
  11. Jul 11, 2023 at 4:42 PM
    19TurdPro
    2019 Tundra TRD Pro
    How much was the truck squatting?
  12. Jul 11, 2023 at 5:37 PM
    NATE4SURF
    Laguna Hills, CA
    It was some yes. I’ll photo it tomorrow.
  13. Jul 11, 2023 at 5:38 PM
    NATE4SURF
    Laguna Hills, CA
    But my old gen 2 2005 tundra had same loads and same trailer last summer with no shudder. ‍♂️
  14. Jul 11, 2023 at 6:48 PM
    19TurdPro
    2019 Tundra TRD Pro
    A normal truck wouldn't if the geometry is in check. I'm asking if it was squatted because it gives me an idea of how much the suspension geometry has changed due to the load. Driveline shudder is more prominent under medium to heavy acceleration. You can almost eliminate it by being gentle with the throttle.
    Google "driveline shudder when towing", or "launch shudder when towing" to better understand what I'm talking about.
  15. Jul 11, 2023 at 7:40 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    I feel like the Crewmax 6.5 would be more susceptible to vibrations as it has a longer span on the rear driveshaft. Anyone know if either the 5.5 or 6.5 has a carrier bearing? I've never looked under my 5.5 truck for one.
  16. Jul 12, 2023 at 11:12 AM
    NATE4SURF
    Laguna Hills, CA
    Here is the photo loaded.
  17. Jul 12, 2023 at 12:14 PM
    19TurdPro
    2019 Tundra TRD Pro
    I'm like 99 percent certain that's your problem. You could have your angles checked, but honestly, if you plan on towing like that a lot, I'd invest in some airbags.
  18. Jul 12, 2023 at 2:59 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    Agreed. Airbags or a weight distributing hitch. I'm sure sitting on the bump stops is close to shoving the driveshaft into the transmission output shaft.
    That being said, I towed my RV about 10 miles last weekend without hooking up the torsion bars on my hitch and it sat just as bad, but I had no vibration. At least not in that short drive mostly through town.
    NATE4SURF[OP] likes this.
  19. Jul 12, 2023 at 3:17 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That trailer is too light for needing wdh. All tundras have soft springs, get some HD coils or airbags.
    it will drive way better towing anyways
  20. Jul 12, 2023 at 4:13 PM
    Personally, I would just level out the camper with a hitch and start there.
    NATE4SURF[OP] and Mattedfred like this.
  21. Jul 14, 2023 at 6:14 PM
    NATE4SURF
    Laguna Hills, CA
    So a hitch that puts the camper level like where you can move the ball mount higher?
  22. Jul 14, 2023 at 6:16 PM
    NATE4SURF
    Laguna Hills, CA
    Is that a ‘real’ issue of doing damage?
  23. Jul 14, 2023 at 6:47 PM
    Yes sir. With the weigh pivoting down on the back of the truck it will add more than normal.
  24. Jul 14, 2023 at 7:39 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Not following that logic. Yes, it will certainly tow better level but if there’s 300# on that tongue it’s going to be 300# whether it’s 4” higher or 4” lower.
  25. Jul 14, 2023 at 7:43 PM
    19TurdPro
    2019 Tundra TRD Pro
    I'd consider bags. Tent trailers don't have enough hitch weight for a weight distribution hitch, and you can't store much gear in them. That's why your bed has as much weight as it does. Your bed weight will vary, so will the amount of the sag. With bags you can set your ride height and the trailer will always tow level.
  26. Jul 14, 2023 at 7:48 PM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    It shouldn't be a possibility on a new/stock truck, but there is potential.
    Regardless, hauling anything, trailer or loaded bed that unloads that much weight from your brake/steering axle is never a good thing.
    In hindsight, the others are right. The 500# of gear, plus trailer tongue weight necessitate airbags. That or timbrens, but unless you are running a constant load I would stick with bags. Timbrens and sumo springs ride pretty rough completely unloaded.
    NATE4SURF[QUOTED][OP] likes this.
  27. Jul 14, 2023 at 9:16 PM
    Mattedfred likes this.
  28. Jul 14, 2023 at 9:31 PM
    19TurdPro
    2019 Tundra TRD Pro
    Is this article referring to wear and tear on the tow vehicle, or the trailer? One of the first paragraphs states that if it can't be level, the trailer should be nose down a little. What am I supposed to be looking at here?
  29. Jul 14, 2023 at 10:19 PM
    I would have mine a little nose down, just slightly.
  30. Jul 14, 2023 at 10:31 PM
    Hella Krusty
    Hella Krusty New Member
    Equalizer hitch is the fast fix. If you tow other things Airbag it. I tow a 5500 lbs surf boat with zero issues plus I have 14 cargo trailer that is fine. All my stuff sits 100% level.
