Vinyl wrapping question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Itchyjuffowup85, Jan 29, 2019.
  1. Jan 29, 2019 at 9:20 AM
    Itchyjuffowup85
    Itchyjuffowup85 [OP] New Member
    2014 Black TRD 4X4 5.7L V8
    Hey everyone. I have some questions for those who wrapped some of their interior pieces. I'm running into issues where it doesnt seem that the adhesive is sticking to my parts and slowly comes up. I used minimal heat if any for some the areas and tried not to stretch them very much. Most of the problems are either in the recesses around the cupholder piece and around the shifter piece. The inner radius seems to want to look pull out and wont stick. Any recommendations?
    I saw somewhere that someone said once you had the part wrapped, you need to heat the piece to a certain temp to active the adhesive but I can find anything else about that. Any tips would help. Thanks!
    Y0TA PR0 likes this.
  2. Jan 29, 2019 at 9:45 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I had a similar problem in those corners. Let me see if I can find photos.
  3. Jan 29, 2019 at 9:50 AM
    steve-smith
    steve-smith New Member
    2019 Toyota Tundra
    310 to 381 hp
    Compared with newer and more advanced power trains, the Tundra's engines and sole transmission are prehistoric.
  4. Jan 29, 2019 at 9:53 AM
    Boerseun
    Ferdie
    Sarasota Florida
    This was my first time wrapping anything. I only had a small sample piece of wrap so I could not practice on another piece first.
    At first I had multiple bubbles but most disappeared over time (about 3 months now). You can see there are many imperfections all the way around. I used a sharp pin to poke a small hole in each of the bubbles, and was able to get some of the air worked out through that.
    Now:
    ZamigwGwGvWLz2rq7jSbxN-1j23DN2KWCLwj3_8g_747bb1ca20569b6126f2b11e0c99566b050a3c26.jpg
    Most of them are gone, except for the small areas in the corners
    0OdB8R1kqnaBV1RZ646TdwkOgLUNFMHNSkGSakEJ_ad49a4d0746924f1daa31fbd5b276520985a5dd9.jpg
    0ZTcwLEnreAFZzLFXa8UE2nbgogVfRseHtn2ElL6_d46aefa318b4febc8452faf5b68bd58691d20132.jpg
    I did use a sharp pin to poke each of the bubbles and work out most of the air. Then over time it kind of healed itself. The bad corners will probably not get any better. I will have to redo it at some point, but for now it is better than the chrome, even with the imperfections.
    Itchyjuffowup85[OP] likes this.
  5. Jan 29, 2019 at 10:48 AM
    Itchyjuffowup85
    Thanks for the tips. And I agree, regardless it looks better than the chrome. I painted the surround on the shifter black to match everything else. That looks great. I think I'm going to try to rewrap the shifter pieces and see if maybe adding a few more relief cuts on those inner radii.
    With the carbon fiber, I may be abke to get away with the small holes. It may cover up a little better than a solid color.
    Boerseun and Mountun Goat like this.
  6. Jan 29, 2019 at 10:59 AM
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    I had the same problem with my Infiniti. I think that just happens because of all of the corners and creases. Its not a huge canvas like the outside of a car or truck
  7. Jan 29, 2019 at 11:43 AM
    jfits
    jfits New Member
    2014 tundra 5.7L 4x4
    Same problem here. Although it seems like it comes and goes :/EA4BD965-9216-4E6D-B061-2831D095C1C3.jpg
    Y0TA PR0 and Itchyjuffowup85[OP] like this.
  8. Jan 29, 2019 at 11:45 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
  9. Jan 29, 2019 at 6:01 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    One of the tricks when applying vinyl to a recessed area is to not bridge the gap. Work the vinyl into the gap without stretching it, that way the vinyl will not want to return to a flat form, as its "memory" has not been altered.
    There is also a product called primer 94 made by 3M, that is an adhesion promoter. It works great, but is tricky to work with..
    Any other questions, let me know
  10. Jan 29, 2019 at 6:04 PM
    Mdjamesd
    Mdjamesd New Member
    Most of the vinyl wrap films on the market nowadays have some form of an air release liner.....essentially the backing paper has texture that forms channels in the adhesive layer enabling the installer to work out air bubbles without poking holes in the film.
    Itchyjuffowup85[OP] and Boerseun like this.
  11. Jan 29, 2019 at 6:39 PM
    Mdjamesd
    Mdjamesd New Member
    @Itchyjuffowup85
    Look up 3M 1080 post heat. Essentially after applying the vinyl to an irregularly shaped panel, heating the vinyl will help to create a new memory for the film. The adhesive does not need to be activated.
  12. Jan 29, 2019 at 6:44 PM
    Itchyjuffowup85
    Yeah I didn't check if this one had the air release, its the 3M 1080 Red Carbon Fiber I purchased through Rvinyl. On the cupholder piece I tried wrapping it two different times. Mind you, I knew this piece wasnt going to be perfect because its broken on the thin side. It just kind of crumbled apart when I was cleaning it. But I wanted to try and wrap those recesses anyways to try and understand it. I tried working from the middle and working out to each edge. (Middle meaning middle of the length of the piece. The symmetrical middle)
    I though by doing that I would have reduced the tension and would be able to relax it in those points. I have 5 ft of the vinyl, so I can try it again.
    I thought about getting the primer for the edges. I did watch a few youtube videos and they recommended it there too
    Thanks for the help and I'll definitely let you know if I have more questions.
    Boerseun likes this.
  13. Jan 30, 2019 at 2:46 PM
    Mdjamesd
    Mdjamesd New Member
    @Itchyjuffowup85 , if just the edges are curling, try and wrap around to the back of the piece, and if needed, use the primer there. The primer can leave a texture that can be visible through the film if not applied carefully
  14. May 7, 2020 at 6:27 AM
    jamesmro
    jamesmro New Member
    That looks perfect....do you have a link to the color vinyl you bought?
  15. May 7, 2020 at 11:23 AM
    jfits
    jfits New Member
    jamesmro likes this.
