Viper Alarm Remote start question.
Discussion in 'Off-Topic Discussion' started by Tierhog, Apr 2, 2020.
  1. Apr 2, 2020 at 7:50 AM
    Tierhog
    Tierhog [OP] SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Hi Guys,
    I had a Viper alarm system installed a year or so ago for the auto start function. I don't like the alarm or chirping and prefer the Toyota sound. Will simply clipping the horn wire and capping it solve the issue? Currently the oem noise is going off at the same time as the viper noise. To further complicate the issue, alarm is Viper only and isn't the trucks horn which I believe is the oem default.
    I wish a simple sequence of button pushes would place it in silent mode. Any suggestions are welcomed. So far I've simply accepted it as the pros outweighed the cons. Can't believe Toyota and the auto start / door insanity.
  2. Apr 2, 2020 at 7:56 AM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    You can usually do a passive arming/ no noise by pressing f1 before you lock or unlock. I am sure there is also an option to shut it off completely. If you go to their website they have manuals for their remotes and many options available after you access the remote menu. All the remotes are a little different.
    Tierhog[OP] likes this.
  3. Apr 2, 2020 at 8:05 AM
    ARMYGREEN
    2014 CrewMax MGM
    Also if you pick up a Carista adapter about $30 on Amazon sometimes on sale, you can turn the horn off on the factory settings.
  4. Apr 2, 2020 at 1:16 PM
    Tierhog
    That's a start guys... Thanks. I've passively armed before but I'll continue with the reading. Thank you
  5. Apr 2, 2020 at 3:34 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What alarm model do you have? It’s not that hard to put it in silent mode
