Visors won't stay up
Discussion in '1st Gen Tundras (2000-2006)' started by Britishfreak, Feb 16, 2019.
  1. Feb 16, 2019 at 5:58 AM
    Britishfreak
    Britishfreak [OP] New Member
    Marty
    2000 4dr sr5 trd 4x4
    My dual visors in my 2000 access cab won't stay up. Is this fixable or do I need to look for replacements? Surely some have had this same problem.:confused:
  2. Feb 16, 2019 at 7:08 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I had this problem on my daughters 2010 Civic, not sure if this is the same problem you're having though. If yes then this repair works well -
    https://www.8thcivic.com/forums/diy...ods/199011-diy-esthetic-sunvisor-fix-6-a.html
    Crazy thing is this turned into a Class Action Lawsuit and Honda's fix was to provide one set of new visors...and in time these would break too :facepalm:
  3. Feb 19, 2019 at 12:42 PM
    Britishfreak
    Marty
    Thanks, Tommy for my one and only reply! That might very well be a good way to fix my visors.
  4. Feb 19, 2019 at 1:17 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    On gen 3 4Runners it was common, as was our 2007. Internals would wear out and they would hang somewhere in middle eventually all the way down. No fix just replace, found OEM on Ebay for like $50 bucks.
  5. Feb 19, 2019 at 8:42 PM
    Britishfreak
    Marty
    I'll try to get a couple pictures of these visors. I've never seen any like them. Thanks, Trooper2, for your feedback.
  6. Feb 19, 2019 at 9:22 PM
    Trooper2
    JR
    @Roman (Toyota Parts) Get him pics, maybe your VIN#, unless you think they are aftermarket.
    Roman likes this.
  7. Feb 19, 2019 at 9:32 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've had this happen on all three Camrys I had before my tundra, up through 2010. I used replacements from Amazon, think they were around $40 per side. Originally tried opening them up and gorilla gluing them back together, but I think a combination of garbage design and Arizona summer heat was too much.
