voice that reads text messages
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Mar 16, 2023.
  1. Mar 16, 2023 at 11:08 AM
    Silver23
    Silver23 [OP] New Member
    2023 Silver 1794 TRD
    I know it's been talked about already, i.e. low voice and/or volume doesn't go low enough to hear the voice. My question is, during the final stages of development/testing, wouldn't you think some engineer notices that the voice is too low and/or the volume doesn't allow you to properly hear the text message? Maybe I'm living in a fantasy land, but I would think "everything" would be tested and verified before the truck actually goes into production. I know some issues arise later after real world operation, hence recalls. Seems like every function of a vehicle would be tested to ensure it works as designed BEFORE Toyota says "the truck is complete, start production".
  2. Mar 16, 2023 at 11:11 AM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    i feel the same way with the apple watch. dictation is terrible. i have to speak like a 1980's robot for the watch to get it correctly
    AND and FrenchToasty like this.
  3. Mar 16, 2023 at 12:16 PM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    If you're referring to a spoken Siri voice through Apple car play, then what you need to do is adjust the trucks radio volume knob as the voice(audio) is being spoken. This will adjust the volume of Siri's voice.
    Wayzata_Tundra, gnc1017 and bigjuice like this.
  4. Mar 16, 2023 at 12:34 PM
    NCrunner2012
    NCrunner2012 New Member
    Steven
    2007 Tundra Limited 4x4
    I use voice to txt all the time on my apple watch series 7 and never have any issues. I was actually surprised by how accurate it was.
    Wayzata_Tundra likes this.
  5. Mar 16, 2023 at 12:55 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    You are correct but the max volume on Siri seems capped very low
  6. Mar 16, 2023 at 1:12 PM
    Silver23
    Then maybe there's an issue with mine. When the text is being read to me, I can turn the volume knob wide open and there is no change to the voice or the music that is playing.
  7. Mar 16, 2023 at 8:05 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Yeah the volume won’t change when she is reading the message. This is one of the few things that is irritating to me about the truck. It’s probably something with Apple and Toyotas systems that just don’t line up with each other. That doesn’t seem unusual with Apple stuff to work a little wonky with other systems. When I press the gas pedal and hear that whistle, all is forgiven.
  8. Mar 16, 2023 at 8:23 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Try out the newest version of Android Auto, it works perfect! I can't put into words how much better it is than the stock system.
  9. Mar 17, 2023 at 6:03 AM
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    The method I described has always worked with my other vehicles but they where always connected with the USB cable. the Tundra uses Bluetooth. Try the same steps I described but use the iPhones volume buttons.
  10. Mar 18, 2023 at 4:27 AM
    FALQN
    FALQN New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    No problem here adjusting Siri volume while she is reading text. Works like it should…I have an iPhone 13 Pro Max.
    PNW Tundra Mike likes this.
  11. Mar 18, 2023 at 4:40 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Strange…mine raises her spoken volume perfectly when texts are being read also no matter how loud my music is…did it both with my iPhone 8+ and the 14+ I just switched over to.
  12. Mar 18, 2023 at 4:45 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    If you want to adjust the voice audio volume, while its "talking" use the volume controls on the steering wheel. This will adjust the volume of the voice, turning the knob wont do it. Cheers
    Nightshade5150 likes this.
  13. Mar 18, 2023 at 8:57 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    For me the knob does work when Siri is talking, but it only goes to a point. Sadly not quite loud enough. I’m gonna try Adam B’s idea and see if it works, better.
  14. May 19, 2024 at 9:09 PM
    leebishop3
    leebishop3 New Member
    2022 Tundra iforce Max limited
    I have figured out the fix if you can’t hear Siri or your texts at all
    All in the settings section
    1. Go to Bluetooth and devices
    2. Disconnect your iPhone from “use for Apple CarPlay” and then connect it to “use for phone”
    3. Go to the Sounds and Media menu and then the levels menu
    4. The “ringtone”, “new message” and “received volume” can all be adjusted now.
    5. Then you can go back and reconnect to Apple CarPlay
    This all worked for me, it does seem to lower the volume some, but probably not enough.
  15. May 20, 2024 at 4:25 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    What accent do you have? Big tech thinks you are stupid if you have an American regional accent and therefore could never afford their product. Even though 3/4 of them are Indian to include many CEOs with thick accents. I bet all the tech understands the Indian accent with 100% accuracy.
    The automated phone menus fro credit card companies are the absolute worst
