Volant intake
Discussion in 'Performance and Tuning' started by tapout24, Sep 4, 2014.
  1. Sep 4, 2014 at 9:08 PM
    tapout24
    tapout24 [OP] New Member
    07 black tundra
    6 inch lift 18 inch tires, black trail lights, tinted windows, flower master
    Just wondering would this give me better mpg right now I'm getting 11 mpg is it worth the money ? Is the install easy and do u have to get my truck programmed or anything Thanks for ur input
  2. Sep 5, 2014 at 7:02 AM
    tapout24
    07 black tundra
  3. Sep 5, 2014 at 9:03 AM
    T-Rex266 SpaceX Director Staff Member
    I've heard more cons than pros....don't think it'll help at all....if any.
  4. Dec 11, 2014 at 7:53 PM
    JADINB
    JADINB New Member
    2015 Toyota Tundra platinum Crew Max
    6" Pro Comp Suspension Lift, 20' Moto Metal 987, 35/12.50/20 Toyo Open Country M/T Volant CAI with Donaldson 100,000 mile filter, G Force Performance Chip Roll N Lock Bed cover
    Yes, you should notice immediate throttle response, maybe micro noticeable fuel mileage gains, better sound from under the hood, with the 100,000 mile filter it pays for itself. The instructions that come with are questionable at best but fortunately there are you tube installation videos that make it a breeze. If you are even remotely mechanically inclined, should install in less than an hour. My opinion...Volant is the best CAI for your Tundra! Sealed box = colder air =better performance.
    Tundralicious likes this.
  5. Dec 14, 2014 at 8:19 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    CAI typically rob your low end power with marginal gains at redline.
    How often do you run out to redline? Hardly ever is my guess, so I would recommend saving your money. Get a drop in filter and save the rest of the money to fill up the beast.
    Or you can look into a Hypertech or bullydog tuner, dirtydeeds exhaust, JBA headers - all proven and will give you power in the RPM range you will see 99% of the time.
    My 2 cents
  6. Dec 14, 2014 at 8:28 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    You already have a cold air intake from the factory. Unfortunately the ecu will compensate for the extra air flow, if there is any at all. I added a drop in afe and it caused my low end tq to drop. The factory one with a paper filter is best.
