VoltageBoosterPro fused diode modification
Discussion in 'Electrical' started by IowaGuy, Apr 27, 2023.
  1. Apr 27, 2023 at 3:05 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    https://voltageboosterpro.com/
    Voltage Booster PRO is an over engineered solution to the do-it-yourself diode modification. It is crazy simple, robust, and easy to install. The Voltage Booster PRO allows you to easily increase your Toyota alternator voltage without expensive DC to DC chargers or other equipment.
    This popped up in my book of faces page as an ad so I thought I would post it here for you to see if anyone has seen this and if you have any thoughts. Is it better than a diode fuse or just another way to get someone's money? $85 seems little pricey
  2. Dec 21, 2023 at 7:41 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Found this thread today, I actually made my own out of a fuse tap and a diode
  3. Dec 21, 2023 at 9:27 PM
    SouthWestGA
    SouthWestGA New Member
    GM alternator fuse $5
    use one of those with the built in diode no need for mods of big money
    joseph_womack likes this.
  4. Dec 21, 2023 at 11:13 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I bought the voltage booster pro after going down the rabbit hole. My battery was measuring 13.0 volts and after install and switched to low it measured 13.7-13.8 regularly. I built the gym diode but got nervous and opted to pay the money for something little more “official” for my peace of mind.
    RitcheyRch likes this.
