Volume is suddenly low, even maxed out
Discussion in 'Audio & Video' started by gosolo, Jul 22, 2019.
  1. Jul 22, 2019 at 10:20 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    The volume on my unit is not very loud, even when maxed out. This is a big change from how loud it would get previously.
    Until recently I never had it up more than about 1/2 way. Now at this level (1/2 way) you can barely hear the radio at all.
    Everything is completely stock. Nothing has been added or changed. What could have caused this? Any ideas?
  2. Jul 22, 2019 at 11:20 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax / 2024 Sequoia Capstone
    Do you have the factory amp under the passenger seat? Could be a blown fuse for that. I forgot to hook up the amp turn on lead for it when I put in my Pioneer HU and wondered why it had no nuts at first. Does it sound like it's only coming from the dash speakers?
    JoshuaA and gosolo[QUOTED][OP] like this.
  3. Jul 23, 2019 at 12:58 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yes, pretty much sounds like that. I’ll check for a blown fuse or loose wire in the morning. Thanks for your help
  4. Jul 23, 2019 at 5:24 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^. A paired phones "volume" is actually an output for the head units input. Again, as mentioned, make sure the phone volume is set to max. for paired music.
    Watt maker and gosolo[OP] like this.
  5. Jul 23, 2019 at 6:54 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, I thought of that and tried it with the iPod and the radio. Same problem with any source
  6. Jul 23, 2019 at 7:23 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would bet on the amp. If all the wiring is good and the amp is blown I bet you can find a OEM pretty easy. I have one sitting in my garage right now. Better yet just replace with a PNP aftermarket and update speakers later.
  7. Jul 23, 2019 at 7:31 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Is there a fuse specifically for the amp? Do you know the location?
  8. Jul 23, 2019 at 7:35 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    We had a 2011 Camry in the shop recently. Same symptoms - with the volume maxed out you could barely hear any audio. At first we suspected the factory amp, but believe it or not the OEM head unit ended up being bad. We replaced with the Alpine W650 and respective PAC interface module and had great sounding audio again.
    Mountun Goat and gosolo[OP] like this.
  9. Jul 23, 2019 at 7:56 AM
    TRDFerguson
    Jake
    In the fuse and relay box under the hood there's a 30A fuse labeled AMP. Here is the lid diagram on my 2018, but may be different on yours
    Watt maker, JoshuaA and Mountun Goat like this.
  10. Jul 23, 2019 at 7:58 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I wish my amp had a blown fuse. Then there would be a reason it sounds so shity haha
    #jbl
  11. Jul 23, 2019 at 8:05 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Not much help here but enjoy reading @gosolo 's post in Dale Gribble's voice (in my head).....
    My guesses are:
    -volume knob - somehow not working correctly, probably not fix. Have you tried turning knob with pressure on it? Inward, towards a side, up or down?
    -faulty amp
    Not sure how to troubleshoot either.
    Would think any blown fuse would result in NO output. Also if blown fuse then something caused it to blow; completely stock system - something no Bueno.....
    Good Luck!
    gosolo[OP] likes this.
  12. Jul 23, 2019 at 8:08 AM
    TRDFerguson
    Jake
    I thought the same when I had swapped my head unit, but apparently the dash speakers/tweeters run direct off the deck and the door woofers are powered by the amp. At least that's what I could gather from the behavior with the amp off.
    Agreed, if the fuse blew for some reason, something else is probably going on.
    gosolo[OP] and Trooper2[QUOTED] like this.
  13. Jul 23, 2019 at 10:14 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Found the fuse, took it out and put it back in. Wiggled wires at the amp, nothing visible that’s loose.
    Tried audio and problem has vanished. Don’t know how or why.
    Seems like many times in my life I’ve had a malfunction with an appliance or piece of equipment and taking it apart and reassembling it was a cure for no apparent reason.
    Thanks for your support and input
  14. Jul 23, 2019 at 10:15 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    PS: Dale Gribble lives!
  15. Jul 23, 2019 at 10:20 AM
    TRDFerguson
    Jake
  16. Jul 23, 2019 at 11:51 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Dale found him living in the Mega-Lo-Mart.
    "Every song I play know reminds me of Feels So Good"
  17. Jul 23, 2019 at 12:33 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Are you using the USB for music from your ipod/phone? If you are, make sure the volume is max, if the phone’s or iPod’s volume is low the volume over the truck’s radio will not be as loud.
    gosolo[QUOTED][OP] likes this.
  18. Jul 23, 2019 at 1:49 PM
    Trooper2
    JR
    You need to document what you did so you can share with others. Pics are great. Maybe get it added to DIY or MOD list..... :)
  19. Jul 23, 2019 at 3:33 PM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    When you pulled the fuse it most likely reset the amp. There might be a capacitor that was holding a charge and when you pulled the fuse it allowed it to fully discharge. If that is the case the issue might come back again. If it does that take it to the dealership and let try them figure it out. If they can't, repeat what you did in front of the tech and they might warranty out the unit. I know your truck is a 15 but still worth a try.
  20. Oct 25, 2020 at 4:24 PM
    alex500martinez
    alex500martinez New Member
    2020 Platinum
    Damn! I have a 2020 platinum w/jbl and have the same issue (connected iPod with usb @ full volume and sometimes it sounds plunder than others so odd. I also tried Bluetooth with my iPhone and same issue sounds great at first then after a while of driving sound starts dying down.
  21. Feb 2, 2021 at 4:23 PM
    PowayDave
    PowayDave New Member
    Dave
    2021 1794 Edition
    I know I'm jumping on an old thread, but I'm in the same boat have a 2021 tundra with the JBL sound system, the finish is the 1794 edition, I don't know if that changes anything on the sound system, but it is very low volume. Phone is up all the way, when Pandora puts on old tunes, it's super low volume, I can get that as it's an old recording, but modern stuff is just at a super low volume. Same with smx. Any fresh thoughts on this issue?
  22. Feb 2, 2021 at 8:24 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    In my former life I had problem with my daughter blasting her music in the house all the time. Couldn t get her to stop, so one day while she was at school, I got a piece of aluminum foil and loosly wrapped it around a headphone jack, and stuck it in the jack plug-in a way that it would stay in the hole. When she turned it on, could barely hear it in speakers. In hindsight it was dirty trick, but damn:annoyed:
    TS1794 and Saltyhero13 like this.
  23. Mar 29, 2021 at 4:08 PM
    ChuckTRDPro21
    ChuckTRDPro21 New Member
    Any luck figuring this out? I just got a 2021 TRD Pro and have the same issue. Driving me nuts!
  24. Dec 23, 2021 at 9:37 PM
    flightlessGoose
    flightlessGoose New Member
    Hi everyone I'm have the volume on my HU is not very loud, even when maxed out. This is a big change from how loud it would get previously
    I see someone else with this issue.
    I have a 1999 3.0 four harrier and can't find the amp so don't even know if it has one as I cant see any amp fuses in the fuse box
  25. Feb 23, 2022 at 6:01 AM
    Sgt_York
    Sgt_York New Member
    Brandon
    San Antonio, TX
    2021 Tundra Platinum Crewmax
    NSV Lightbar, center console wireless phone charger, Ultra Flex bed cover. Smoked tail lights and third brake light. Many mods in the near future.
    Has anyone figured out a fix action for this, I’m having the same problem with my 2021 Platinum. Before I take it to Toyota was hoping to find something on here.
  26. Feb 26, 2022 at 8:52 AM
    Sgt_York
    Sgt_York New Member
    Brandon
    San Antonio, TX
  27. Feb 26, 2022 at 11:26 AM
    Sgt_York
    Sgt_York New Member
    Brandon
    San Antonio, TX
    So I went to https://www.toyota.com/firmware-updates/download followed the instructions and updated my entune radio firmware. They came out with 2 new firmware updates recently. This improved the overall sound for my truck, but I'm still having an issue with the phone call being quiet (whether bluetooth or cable/carplay doesn't matter) and the Waze playing through one speaker in the driver door quietly. When bluetooth is active the Waze voice can be heard through the main speakers loud and perfectly. So this is an issue with the carplay, but yet the calling problem is a problem through both multimedia platforms.
    I have increased all volumes that I can on the phone and in the apps and the systems. I have also increased the in-call voice to max and it is still hard to hear a call.
    Thanks in advance!
  28. Feb 26, 2022 at 11:29 AM
    TRDFerguson
    Jake
    Have you tried force closing Waze or switching to another nav app? I’ve had problems where Waze notifications hijacks the audio and attenuates everything. Uninstalling and reinstalling tends to fix it when this happens after an update.
  29. Feb 26, 2022 at 12:28 PM
    Sgt_York
    Sgt_York New Member
    Brandon
    San Antonio, TX
    I'll try uninstalling and reinstalling on my phone. Stupid question, but there's not anyway to actually install and uninstall apps through the radio is there? It should just be apps from my phone in projection mode right?
  30. Feb 26, 2022 at 12:32 PM
    TRDFerguson
    Jake
    Correct, it would be the app on your phone.
