Want to replace my Upper Control Arms.
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Jan 15, 2024.
  1. Jan 15, 2024 at 4:12 AM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I've found a couple of videos on YouTube, but nothing great.
    I really couldn't find anything instructional on this website, but I'm not sure I knew where to look.
    How hard is this to do on our trucks. The videos I did find made it look pretty straight forward, but it is never as easy as it looks in the videos.
    I was thinking of going with the JBA control arms. I like the fact that they can be lubricated.
    Thanks.
  2. Jan 15, 2024 at 5:39 AM
    SoJersey
    SoJersey New Member
    I’ve installed 3 sets of JBA arms on trucks and I’ll say they’ve all been an easy install and all have had great alignments after.
    You’ll have to move some harnesses out of your way some just to maneuver the pivot bolt. It’s a little bit of a pain to get in there to torque the bolt but it can be done.
    myt1[OP] likes this.
  3. Jan 15, 2024 at 8:30 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    I removed both last summer. Fairly easy other than a little bit of a pain getting access to the PS thru bolt. I had to remove them (Rough Country) to replace the upper joint. Also learned that the ball joint was specific to Rough Country.
    As mentioned, make sure to torque the nut as the one on the PS came loose causing the bolt to slide out a few weeks after I replaced the ball joint. Destroyed the new ball joint in the process. Luckily, it happened just down the country back road from my place while my daughter was driving. Was able to do a roadside repair and get the bolt back in place, but of course the nut was long gone.
  4. Jan 15, 2024 at 5:31 PM
    myt1
    Richard
    Scottsdale, AZ
    Thanks, I think I will give it a whack.
  5. Jan 16, 2024 at 5:08 PM
    AlexFIA
    AlexFIA New Member
    Tundra Rock Warrior
    Been a while since I did mine, but don't remember it being too difficult driveway job.
