Washer fluid not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by ATXHusker, Feb 7, 2025.
  1. Feb 7, 2025 at 8:21 AM
    ATXHusker
    ATXHusker [OP] New Member
    Chad
    Austin TX
    2016 TRD Pro CM Quicksand
    Ranch Hand brush guard, TRD rear sway bar, TRD air filter, Husky front mats, Weathertech rear mat, LED interior lights, tow mirrors, Salex console organizer, key ring light mod, AJT key fob, Gator bed cover
    Hey folks, for some reason the washer fluid isn't spraying onto the windshield. I have plenty of fluid in the reservoir so that's not the issue. Anyone else have this issue and fix? thanks!
    HulkSmurf14 likes this.
  2. Feb 7, 2025 at 8:28 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If it's cold (below freezing) you could have a stuck one way check valve - even if it's not cold, it's a failure part that occurs...the best way to mitigate this from ever happening again is remove the OE "Y" (check valve) on your firewall (or hood?) (keeps your fluid lines filled and ready to squirt) and replace with a standard Y fitting...the fluid will than roll back into your tank so the nuance is you will now have to wait approximately ~1.245 seconds before your windshield is sprayed...worth it!
    ATXHusker[OP] likes this.
  3. Feb 7, 2025 at 8:30 AM
    ATXHusker
    Chad
    Austin TX
    I don't think it's weather-related here in central Texas lol but I'll fiddle around with it. :) thanks!
  4. Feb 7, 2025 at 8:33 AM
    AZBoatHauler
    So.Arizona
    Can you hear the pump running? Mice like to chew the hoses along the passenger side front fender…
  5. Feb 7, 2025 at 8:56 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Also check the line I've seen them get pinched by the hood hinge and it won't allow it flow.
  6. Feb 7, 2025 at 11:37 AM
    Ericsopa
    Ericsopa Old man and the sea
    99% of the time, it's the check valve. This thingy right here ...
    OEM part 85321-28020, Dorman part 926-335. Either will run you about $25.
    Easily checked by disconnecting the inlet hose at the check valve and running the washer pump. If you got fluid there, it's the valve.
    HulkSmurf14 and ATXHusker[OP] like this.
