Water Fording
Discussion in '2.5 Gen Tundras (2014-2021)' started by k11white37, Apr 10, 2020.
  1. Apr 10, 2020 at 5:31 AM
    k11white37
    k11white37 [OP] New Member
    Kyle
    2020 Army Green TRD Pro
    I Google searched and tried searching through the forums, couldn't find much info on this. I am not looking to push it to the limits, just curious. I've seen the video of the black Tundra blasting through that intense flood, but I'm just looking to not flood the cab! I will probably purchase a diff breather before heading into any high water areas, Thanks.
  2. Apr 10, 2020 at 4:03 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Very simple rule of thumb I use... Never go faster than idle speed and never go deeper than the top of your tires, about 31". Also let the diffs cool to ambient temp before going through water.
    Personally I hate driving through water because it washes out wheel bearing lubrication.
    Can you go faster and deeper? Sure. Good luck tho.
  3. Apr 10, 2020 at 4:07 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Keep in mind your alternator is on the bottom of the engine.
  4. Apr 10, 2020 at 5:11 PM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    And hope the road hasn’t been washed out
    2mchfun and Cpl_Punishment like this.
  5. Nov 20, 2021 at 1:22 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    So a tundra fording depth hasn't been established?
    Bob_Loblaw and Mike59 like this.
  6. Nov 20, 2021 at 1:30 PM
    If you haven't done a rear diff breather mod then you shouldn't go any deeper than mid axle. Unless you want peanut butter in your diff.
    After that, keep it below your floor boards if you don't want water in the cab.
    NewImprovedRon, JLS in WA and Tundra2 like this.
  7. Nov 20, 2021 at 2:04 PM
    2mchfun
    Yep, been there, concrete pad in creek bottom was washed out and about 1/3 of the way across my front end dropped over a foot instantly. Not a fun experience. Always do the stick test in muddy water!!!!
    GODZILLA likes this.
  8. Nov 20, 2021 at 2:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I don’t know about being in a flood for hours, but if it’s just a typical water crossing like a river, water won’t get into the cab.
  9. Nov 20, 2021 at 2:18 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    So what's the next concern after passing the diffs (with a rear breather mod)?
  10. Nov 20, 2021 at 2:23 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Losing traction/contact with the bottom is certainly a concern.
  11. Nov 20, 2021 at 2:28 PM
    2mchfun
    Tranny breather
    wexttxco[QUOTED] likes this.
  12. Nov 20, 2021 at 2:34 PM
    2mchfun
    If you really really want to play in water, my advice is get a rental.
  13. Nov 20, 2021 at 3:29 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I don’t like crossing water when my rotors are red hot. I did once and I could basically see the water boiling and steam shooting out my wheels. Lol. I think that might’ve warped my rotors. But the next major concern is your intake. Suck water in there and you’re done.
    Mater, GODZILLA and Bprose like this.
  14. Nov 20, 2021 at 6:38 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    If you dont know, the engine air intake (and air injection system) is inside the wheel well behind the fender liner. It's not in a good location for water crossings.
    clarkritchie and Mike59 like this.
  15. Nov 21, 2021 at 9:02 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Snorkel on breather raised in rear an i sit a few minutes to cool things .other breathers are up in engine per toyota tundra .so no problem there
  16. Nov 26, 2021 at 12:40 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Where is the trans breather located?
  17. Nov 26, 2021 at 12:46 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Google say right side of engine
    wexttxco likes this.
  18. Nov 26, 2021 at 1:39 PM
    2mchfun
    If not mistaken, up behind brake fluid resevoir area on firewall. Think that is what I read somewhere anyway.
  19. Nov 26, 2021 at 1:46 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Thanks yall. We have a lot of flash flooding in the area and sometimes I have to go to calls that require driving through flooded roads and I'm considering a snorkel and any other mods, just in case. As well as knowing my limits. I won't drive through water for fun, btdt and nearly floated a 3/4 ton off the road and into something that would have killed me so I'll pass on that on purpose. Not looking to start filling my cab with water again.
  20. Nov 26, 2021 at 2:11 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Yep snorkel on an rear end breather in tail light
