Water in Oil but no Oil in water
Discussion in '2nd Gen Tundras (2007-2013)' started by mikehh, Jan 10, 2025.
  1. Jan 10, 2025 at 8:40 PM
    mikehh
    mikehh [OP] New Member
    2010 sequoia 5.7
    Folks,
    I’m in need of some input. I have a 2010 5.7 with 200,000 miles. I have water in my oil. What is missing from my coolant reservoir is extra in my oil side. I do not see any signs of a blown head gasket to the combustion side. No smoke no error codes no overheating no pressure in coolant hoses. My coolant is 100% clean and just went down from max level to min in about 3000 miles.
    Before assuming that it is the head gasket, I’d love to rule out everything else.
    Can I rule out the oil cooler? Wouldn’t the oil go into the coolant as the cooler is on the pressure side of the oil?
    looking at the heads, are the outer elongated holes for the head bolts where the oil returns? Or does it return through the timing cover?
    What else could be the culprit? I’d hate to pull the heads without having eliminated everything else.
    Lastly, has anyone had any luck with adding a liquid head gasket to the coolant as I assume that there is no leak between combustion and oil but rather a leak between cool and and low pressure oil.
    Any input is much appreciated!
  2. Jan 10, 2025 at 8:46 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Valley coolant leak.
    SBGibson likes this.
  3. Jan 10, 2025 at 9:03 PM
    Tundra family
    Tundra family New Member
    What I use to test for combustion gasses in the radiator.
  4. Jan 10, 2025 at 9:15 PM
    mikehh
    2010 sequoia 5.7
    Thanks. I’ll do a block test tomorrow. Could you explain the valley coolant leak? Thanks!
  5. Jan 10, 2025 at 9:28 PM
    Tundra family
    I've seen people do block tests with a rubber glove over the radiator but I think that only works on boosted engines/diesels. Might be worth checking out though.
  6. Jan 10, 2025 at 9:48 PM
    blackdemon_tt
  7. Jan 11, 2025 at 5:02 AM
    mikehh
    2010 sequoia 5.7
    Ok thanks. I now understand that. However, I do not have any obvious coolant leaks on the engine exterior. Not having seen it apart, could you tell me how a failed valley cover gasket would get coolant into the oil? Thanks again for the help!
  8. Jan 11, 2025 at 5:46 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    How often have you changed the coolant ?
    Reason I ask is the Coolant becomes acidic if not changed out.
    It can wear out the seal according to the Car Care Nut Toyota Guy. This pic from his video is from a Sequoia 5.7 about the same mileage and no coolant changes.
    So if you have performed regular coolant changes maybe it eliminates this problem.
  9. Jan 11, 2025 at 5:58 AM
    mikehh
    2010 sequoia 5.7
    That’s interesting. It has not been changed in the last 160000 miles that I owned it. I’d hate to part with it, but will have to do something about the water in the oil. Not sure if I want to get into a head gasket nit knowing that it could have an easier fix.
  10. Jan 11, 2025 at 6:23 AM
    That coolant looks like strawberry nestle quick. Not good. That oil looks rough too. There is definitely a problem here.
    JLS in WA likes this.
  11. Jan 11, 2025 at 7:01 AM
    mikehh
    2010 sequoia 5.7
    I’ll do the block test today. If the Copland does have oil in it, would you think that the oil cooler could be the problem? I’d love anything other than the head gasket.
  12. Jan 11, 2025 at 7:27 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    A failed oil cooler sounds plausible to me for sure, though not sure how common that is as a failure point. Theoretically after shut down the oil pressure drops to nothing and the coolant pressure remains at 16psi until it cools down and the pressure drops.
  13. Jan 11, 2025 at 7:57 AM
    Worth getting the equipment to do a compression and leak down test while you’re in there.
  14. Jan 12, 2025 at 7:42 AM
    mikehh
    2010 sequoia 5.7
    Just did a block test. No indication of a failed head gasket there.
    I would guess a passage between coolant and low pressure oil. Could anyone guess where that could be?
    I’m ruling out oil cooler as it is on the oil pressure side. Even though my coolant doesn’t look pretty, I wouldn’t say that there’s oil in it.
    Any thoughts?
  15. Jan 14, 2025 at 9:32 PM
    lr172
    lr172 New Member
    07 DC
    I can’t think of a single path for coolant to get in the oil besides a cracked engine block or a leak in the oil/coolant heat exchanger. A bad head gasket leak, will allow coolant into the cylinders. While running, this burns in the combustion chamber. However after shut down, the coolant system is still under pressure and will/can push coolant into cylinders. In this case, that coolant will find its way to the oil pan. However it will also blow large clouds of white , sweet smelling smoke on startup that is almost impossible to miss.
    AZBoatHauler likes this.
  16. Jan 17, 2025 at 8:33 AM
    SBGibson
    SBGibson New Member
    2011 Tundra 4 wheel drive
    All that coolant mixing with the oil , has to be bad news for the bearings in the engine. Not sure how you could flush all that stuff out and not have the rod and main bearings live through it. If you
    can find what and where the leak is , along with making the fix, I would drain everything and then pour diesel , about a gallon down into the oil fill and then the oil and crank and run a bit at idle
    and then do it again after draining to at least help the bearing try to make a come back.
    That hose under the intake could also cause the problem with the coolant loss.
  17. Jan 25, 2025 at 5:14 PM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    If you are driving a lot of short trips you will get condensation under the oil cap, throw in a bad PCV and it can get a lot worse.. Not saying that's it, but maybe something to check?
