Water logged foam in frame ?
Discussion in '1st Gen Tundras (2000-2006)' started by wauto, Jan 10, 2025.
  1. Jan 10, 2025 at 5:53 AM
    wauto
    wauto [OP] New Member
    mike
    G_unit3000 and The Black Mamba like this.
  2. Jan 10, 2025 at 6:09 AM
    shifty` No Water in the Water Fountain
    That's crazy. I just went out to my truck and checked; no foam. But it's a 2006 and that one is a much earlier year (tricolor tail lights).
    G_unit3000 likes this.
  3. Jan 10, 2025 at 6:39 AM
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    That's weird af. I can speak for my 2000 AC as I just ran a hose clear up the boxed frame rails to the very front cross member to oil the inside if it... and no foam or obstructions period. :notsure:
    Must have been a PO brainstorm?
  4. Jan 10, 2025 at 6:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's not normal. Someone put that in there. That area is prone to rot too. I've pumped a lot of fluid film in there over the years.
    tvpierce, G_unit3000 and FrenchToasty like this.
  5. Jan 10, 2025 at 7:01 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Mine had foam on both sides. I didn't notice until I had the driver side repaired (autorust.com). I removed it from both sides.
    G_unit3000 and Jack McCarthy like this.
  6. Jan 10, 2025 at 7:18 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Dang, weird, i would assume that would have been to keep critters out of the hollow frame tube and was a cheaper option than welding in a plate to box the frame.
    Mine doesnt have it, 2005 DC.
  7. Jan 10, 2025 at 12:10 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  8. Jan 10, 2025 at 1:52 PM
    Jack McCarthy
    Bill
    North of Boston
    Here’s the big hint why it’s in there, although someone stuffed it waaay too deep in the video, @wauto.
  9. Jan 10, 2025 at 2:28 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Wow!. Yeah, I have no foam. 5/00 production date.
  10. Jan 10, 2025 at 2:32 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I've got a 2005 DC with replacement frame done by previous owner in 2014 and it's got foam on both sides. I found it when spraying Fluid Film this fall. I left it in but maybe I should take it out??
  11. Jan 10, 2025 at 2:36 PM
    Jack McCarthy
    Bill
    North of Boston
    I would take it out. Water is only going to get trapped in there and I would know.
  12. Jan 10, 2025 at 2:45 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    10-99 build date for mine.
  13. Jan 10, 2025 at 3:12 PM
    wauto
    mike
    Just had my son look inside the frame of my 04....No foam.:thumbsup:
  14. Jan 10, 2025 at 4:01 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So some trucks had this and some didn't. Toyota actually put these in some trucks?
  15. Jan 10, 2025 at 4:03 PM
    Jack McCarthy
    Bill
    North of Boston
    It’s part of the treatment they did to spray the rusty frames instead of replacing them.
  16. Jan 10, 2025 at 4:49 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    That’s why I don’t have it, no recall. I was thinking (in a weird stupid way) it might have been part of the PDI process and some dealers didn’t remove them.
  17. Jan 10, 2025 at 5:57 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Interesting. I think my frame was sprayed but I'd have to double check online.
  18. Jan 10, 2025 at 5:59 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Mine was treated, but no foam, maybe taken out at some point. Pics when I vacuumed them out before oiling them front to back.
  19. Jan 10, 2025 at 6:08 PM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, if it was done correctly, it’s just jammed 1/2 way into the channel and easy to pop out. I’d guess most people took them out or they eventually fell out.
  20. Jan 10, 2025 at 6:16 PM
    Guys at the stealership that day were, like, "Nah boss, how about we take the money for the foam bits and use that on pizza lunch for the shop today?!" :rofl:
    G_unit3000 and BroHon[QUOTED] like this.
  21. Jan 10, 2025 at 6:57 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    This now makes me wonder if my tundra only got the treatment vs replacement. I double checked my online Toyota owners service history and here is the entry that I thought confirmed the seller claim of frame replacement.
    Thoughts?
  22. Jan 10, 2025 at 7:02 PM
    Jack McCarthy
    Bill
    North of Boston
    2005 DCs were part of the limited service campaign? I thought that was only 2000-2003? Anything greater than that was part of a lawsuit settlement.
    G_unit3000[QUOTED] likes this.
  23. Jan 10, 2025 at 7:06 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I looked closer at mine, I wonder if "F" is frame, and CRC is the treatment?
  24. Jan 10, 2025 at 7:24 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    I found a Toyota PDF that explains some details about this Limited Service Campaign (LSC) D0D. My vehicle lived in upstate NY close to the NYC metro area so my Tundra was in the phase 3 portion of the campaign
    BroHon likes this.
  25. Jan 10, 2025 at 7:39 PM
    Jack McCarthy
    Bill
    North of Boston
    Huh. So the frame treatment without the free frame if you qualify? I’m not seeing anything about frame replacement in there.
  26. Jan 10, 2025 at 7:42 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
  27. Jan 10, 2025 at 7:44 PM
    Jack McCarthy
    Bill
    North of Boston
    Yep. That’s for when they spray the Noxodul 700 cavity wax inside the frame rails.
  28. Jan 10, 2025 at 7:46 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    This portion discusses a replacement frame a few times if the perforation is bad enough.
  29. Jan 10, 2025 at 7:52 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
  30. Jan 10, 2025 at 8:02 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    des2mtn likes this.
