Water Pump Replacement Question w/ Pictures!
Discussion in '2nd Gen Tundras (2007-2013)' started by AstroDude, Apr 30, 2023.
  1. Apr 30, 2023 at 12:33 PM
    AstroDude
    AstroDude [OP] New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    So I'm on page 11,860 of the Tundra Service & Repair Manual and I noticed how it only states to "install new gasket and water pump"...but it doesn't state anything about using a liquid gasket.
    I'm just making sure...I don't need a liquid gasket, right? Just use the water pump gasket?
    I'd be more than happy to post the 218MB Tundra Service & Repair Manual PDF...but I'm not sure if I'd be breaking some policy or something by the company. Also, I'm posting the TQ specs for the bolts to help out those who will need to do one in the future.
    I'll be replacing the water pump in about 2 weeks. Just doing my research now.
  2. Apr 30, 2023 at 1:04 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Unless it's rubberized, I spray all of the gaskets edges with spray copper coat. Basically any paper or cork gasket gets sealed on all edges. 10 years out and nothing is seeping/weeping.
    AstroDude[QUOTED][OP] likes this.
  3. Apr 30, 2023 at 1:20 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I've replaced water pump twice, no liquid gasket required. No leaks.
    PhotoNerd and AstroDude[OP] like this.
  4. Apr 30, 2023 at 1:23 PM
    AstroDude
    Eddie
    Awesome, thanks for the info!
  5. Apr 30, 2023 at 1:24 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Your welcome. The gasket is metal with another thin rubber like material. See pic.
    AstroDude[OP] likes this.
  6. Oct 24, 2024 at 7:12 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    I am about to do the waterpump for my truck.. lets see how it goes.. :)
    chugs likes this.
  7. Dec 31, 2024 at 5:31 AM
    Randy9115
    Randy9115 New Member
    2010 Toyota tundra
    I'm a 30 year mechanic and it's always safe to apply a thin coat of high temp silicone to any water pump gaskets this almost guarantees no leaks when your done ..it also helps hold the gasket in place when reinstalling...nothing worse than missing a gasket bolt hole and having a leak when your done ....
    baraynavab, PhotoNerd and koditten like this.
  8. Dec 31, 2024 at 5:56 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Good luck! This job is a PITA! Might as well replace the serpentine belt while you're at it. Check the radiator for leaks, too, because it also inevitably needs replacing and it's easier to do at the same time.
    baraynavab likes this.
  9. Dec 31, 2024 at 9:38 AM
    baraynavab
    Atlanta
    Lol man this job was a walk in the park when you have done the starter for the 5.7l. A walk in the park....that starter was a excercise in all kinda things.
  10. Dec 31, 2024 at 9:47 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think the 4.7 takes the cake for the starter job; it’s under the intake
    AZBoatHauler likes this.
  11. Dec 31, 2024 at 10:21 AM
    AZBoatHauler
    So.Arizona
    I don’t know - I think I’d rather pull the intake than the exhaust manifold like is recommended for the UR engines. There is a solid chance we will eventually get to do both.
  12. Dec 31, 2024 at 10:29 AM
    FrenchToasty
    Mo
    Bone stock
    Oh that is lame for sure
  13. Jan 1, 2025 at 6:53 PM
    baraynavab
    Atlanta
    Oh no oh no no no.... The 4.7 is a cake walk when compared with the 5.7. I did both and by far the more pain in the ass ins the 5.7. It's a PITA for sure. I would never want to do it again.
  14. Jan 1, 2025 at 9:15 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Yeah 5.7 you just about need to have the trans and exhaust off to replace.
