Water Pump Replacement what else?
Discussion in '2nd Gen Tundras (2007-2013)' started by ZiaTundra, Jun 1, 2021.
  1. Jun 1, 2021 at 8:47 PM
    ZiaTundra
    ZiaTundra [OP] New Member
    During install of some 6112s the water pump was found to be leaking. I’m debating on doing it myself or having a local shop replace it. It’s a bummer because the truck is a 2008 5.7ltr only 67k miles but is what it is and hopefully it’s fixed and running good again soon.
    Anything you all recommend I replace while it’s apart getting a new water pump?
    I’m thinking might as well put a new serpentine belt and thermostat.
  2. Jun 1, 2021 at 9:06 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    Maybe have the pulleys replaced as well since the pump has been leaking. Definitely a serpentine belt I just had mine replaced as well as the water pump.
    ZiaTundra[OP] likes this.
  3. Jun 1, 2021 at 9:24 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    The pump is 14 years old, age will take its toll on the seals whether you drive it or not. Has the coolant ever been changed? I would suggest a fresh thermostat while you're in there. If you're feeling diligent you could do the fat upper/lower radiator hoses. With the belt off checking those idler pulleys is a good idea.
    ZiaTundra[OP] and TheBeast like this.
  4. Jun 1, 2021 at 9:32 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    I just did timing chains and while it was off I did a water pump, thermostat, all heater hoses (there are a lot), upper and lower radiator hoses, and one belt idler (it was pretty rough when I took it off).
    since you're fairly low on mileage, I'd probably just do the thermostat and call it a day. it has to come off anyway for the waterpump. and check the condition of the belt and idlers.
  5. Jun 2, 2021 at 5:27 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I just did the hoses on my '08 and found out that both the dayco and gates lower hoses do not fit well. Had to go OEM.
  6. Jun 2, 2021 at 11:28 AM
    ZiaTundra
    You did upper and lower radiator hoses?
    I’m thinking thermostat, serpentine belt, tensioner pulley assembly and idler pulley while in there
  7. Jun 2, 2021 at 12:16 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    I did upper and lower radiator hoses mainly just because the one that was on the truck fit terribly and was hitting the alternator pulley...
    I don't think you need to replace them otherwise.
  8. Jun 6, 2021 at 9:25 AM
    ZiaTundra
    I got under there to diagnose and saw pink fluid crusted all over block under water pump pulley and some on the skid plate so pretty sure water pump is leaking but...
    Does the water pump leak slowly because I’ve topped off coolant 3 days ago and can’t see any new fluid dripping?
  9. Jun 6, 2021 at 9:28 AM
    audiowize
    Paul B.
    Yes, if the water pump leaks like crazy when the truck is just sitting, that would be an extremely urgent repair!
    If you have a pressure tester, you can pressurize the system and you'll likely find that normal operating pressure is enough to get the pump to leak.
    Tom976 likes this.
  10. Jun 6, 2021 at 9:33 AM
    ZiaTundra
    So even if I have a slow leak, it’s failing and I need to replace?
    also I’m unsure if I can do it. It seems pretty laborious. How was it for you that have replaced?
  11. Jun 6, 2021 at 9:35 AM
    audiowize
    Paul B.
    The issue is predicting when the slow leak will lead to a bigger leak that's a bigger problem. This is not a particularly complicated repair, and you could shop it out to an independent shop if you didn't feel comfortable doing it.
  12. Jun 6, 2021 at 9:38 AM
    ZiaTundra
    I got a quote of $405 in labor plus parts. Seems decent as I’d supply the OEM parts. Or I could tackle it and save $405 but don’t know if I’m in over my head.
    I have mechanical experience but of course some things are easier or more doable than others
  13. Jun 6, 2021 at 9:43 AM
    coastaldesert
    coastaldesert New Member
    Oregon Coast
    Just bought an 07 (5.7) with 53k on it a month or two ago.
    Discovered I had a slow leaking water pump and took it in to confirm.
    Shop did the pump for $355 plus parts. The serpentine belt was replaced around 35k so it was still fine but they did the coolant, thermostat and pump while doing the job.
  14. Jun 6, 2021 at 9:56 AM
    The OEM pump has a self sealing seal. The seal on my 07 was weeping forming a pink crust. Was weeping the five years I owned it. I bought a NIB Aisin pump off Craigslist for $25. Never used it. I'd have to add an ounce of red or two every month or so in the summer. My Zerex Asian red jug is still near full.
  15. Jun 6, 2021 at 12:11 PM
    coastaldesert
    Oregon Coast
    Nice. I assume this was a slow weeper too but I live in pretty remote parts so don’t want to be stranded somehow 2 hours from cell service
    seems to be pretty common issue but not the end of the world at least they don’t seem to suddenly completely fail often
  16. Jun 6, 2021 at 1:43 PM
    Very slow weep otherwise I would have swapped the other pump in. I was adding so little coolant and after reading up on how common the weep was, I deferred on replacing it.
  17. Jun 6, 2021 at 2:39 PM
    P-Factor
    P-Factor New Member
    Water Pump Inspection and Diagnostic Tip
    Tom976 and Filthyphil like this.
