Water Pump
Discussion in '2.5 Gen Tundras (2014-2021)' started by texasrho83, Jun 3, 2023.
  1. Jun 3, 2023 at 12:22 PM
    texasrho83
    texasrho83 [OP] DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pulled my H2O pump and the bearing seems fine as does the gasket. I know I am leaking antifreeze from somewhere in the front of the engine so I assumed it was the pump. Anywhere else it could be comin from?
    Oh accidentally pulled the fan pulley off too lol
  2. Jun 3, 2023 at 8:58 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've always put some sorta RTV sealant on the pump bolts. I've seen some do and some don't on these trucks. What's yall's take?
  3. Jun 3, 2023 at 9:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I didn't use any RTV... just the gasket that came with the pump. No leaks whatsoever... If you look at the engine block by the oil filter. If its caked with pink along with the sway bar your pump is/was leaking. Anywhere else is either the radiator, radiator cap or hoses.
    Tundrastruck91 likes this.
  4. Jun 3, 2023 at 9:10 PM
    blenton
    blenton New Member
    How much fluid are you leaking? The seal in the water pump can weep, especially when cold, then seal itself back up when warmed up. Look for light pink crusty gunk for a small leak.
  5. Jun 3, 2023 at 9:36 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's what I had
  6. Jun 3, 2023 at 10:21 PM
    blackdemon_tt
    yup, water pump... Had the same stream before it blew out
  7. Jun 5, 2023 at 2:26 PM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Yeah I JUST replaced my water pump. Take your time and follow the torque specs + pattern. I didn't use RTV or anything else. Just the gasket that came with the water pump. I bought mine directly from Toyota. When it comes parts, what I deem as critical parts, I just order from the dealer. Yeah it might be more but it's the peace of mind.
    I wouldn't want to be off-roading with my family and my autozone water pump takes a shi*. Yeah autozone replaces the pump because lifetime blah blah...but what they wont replace is the cost to have the truck recovered from the middle of nowhere. Just my $0.02
  8. Jun 5, 2023 at 2:29 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks. I bought the same pump that's OEM from RockAuto (Aisin). They ground off the "Toyota" name haha.
    So yes the fan pulley has some play in it? The nuts bottom out on the non-threaded part of the bolts. Don't remember it being loose when I pulled it off but the belt had held it on since new so......
    AstroDude[QUOTED] likes this.
  9. Jun 5, 2023 at 2:31 PM
    AstroDude
    Eddie
    Fan pully has some play in it?
    Yeah, there shouldn't be any. I'm big on tq specs and bolt pattern. If you followed them, then it shouldn't be moving around. Mine doesn't move at all and I also replaced the clutch fan.
  10. Jun 5, 2023 at 2:33 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Look at my video.
  11. Jun 5, 2023 at 2:37 PM
    AstroDude
    Eddie
    Oh damn sorry. Once you install the clutch fan it shouldn't move.
  12. Jun 5, 2023 at 2:38 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep. I'm tired and I am only on my first beer.
  13. Jun 5, 2023 at 2:43 PM
    AstroDude
    Eddie
    You only have 8 more hours to go and 1000+ cuss words. You got this.
    Johnmatrix likes this.
  14. Jun 5, 2023 at 2:45 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Haha I'm on the downhill slope. Just gotta button up a couple more hoses, install shroud and fan then fill with coolant.
  15. Jun 5, 2023 at 2:46 PM
    AstroDude
    Eddie
    Make sure you use Toyota coolant. Not that green shi*. Not sure if it makes a difference but if it calls for it, I'd use it.
  16. Jun 5, 2023 at 2:59 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I got Pentosin
  17. Jun 5, 2023 at 3:06 PM
    blenton
    blenton New Member
    The chemical makeup of the coolant makes a difference, which is why there are so many flavors now. Some will corrode materials used in assembly or the metal itself on certain parts. It’s not a matter of which coolant is better - it’s which one is correct for your motor. I use the pink stuff from Toyota. I’ve seen what the green stuff does to the wrong vehicle and it ain’t pretty.
  18. Jun 5, 2023 at 3:20 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Also the cololant pipes have an o-ring that is prone to leak
    texasrho83[OP] and AstroDude like this.
  19. Jun 5, 2023 at 6:37 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Got her done without leaks and then bled the air out of the system :yes:
    AstroDude likes this.
  20. Jun 7, 2023 at 6:58 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Can anyone chime in with how full their puke bottle sits on the regular? I think I'm overfilling mine (even though it's below the Max line) because I've been getting coolant spewing out of there when I go on a drive. I'm gonna take another test drive later on with the level where it sits now (near the Low line).
  21. Jun 7, 2023 at 7:45 AM
    blenton
    blenton New Member
    Mine honestly sat near empty since new. Somebody opened the rad cap at the dealer when doing the delivery inspection and spewed some coolant all over the underside of the hood and rad support, but didn’t bother cleaning it up or topping off the reservoir. After my recent coolant exchange, it sits at the cold empty line and goes up to the hot full line when hot.
  22. Jun 7, 2023 at 8:12 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah makes sense as to why I'm overflowing. Thanks for the info, bud.
  23. Jun 7, 2023 at 2:22 PM
    bfunke
    South Carolina
    I keep mine at the full line when warm on both my 2000 and my 2018. The first gen has a small leak at the rear crossover so I have to add a little once or twice a month. Eventually I’ll take the manifold off and fix it.
  24. Jun 7, 2023 at 2:28 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I watched a few videos on that repair job. Ouch.
  25. Jun 7, 2023 at 4:21 PM
    AstroDude
    Eddie
    My tundra is at the full line when cold and when it's hot its a bit over. Yeah I could probably take some out...but in the event the engine need more coolant for whatever reason, it's there.
