Water streaks inside windshield on a 2018
Discussion in '2.5 Gen Tundras (2014-2021)' started by cfred70, Mar 4, 2018.
  1. Mar 4, 2018 at 1:08 PM
    cfred70
    cfred70 [OP] New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    Quick question...the past few days I've noticed some water streaks on my front windshield. I use my wiper/wiper fluid and notice that the streaks are on the inside of the glass. Multiple streaks that start at the top of the windshield and make it about half way down the glass. We've have some weird weather here lately which has frosted my truck but then the sun comes out and warms my truck up rather quickly. I'm wondering if this could be condensation? Since my truck sits outside this could be annoying cleaning my front windshield daily. Anyone experience this and have a quick remedy? Thanks
  2. Mar 4, 2018 at 1:42 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    Had crazy weather here in North TX lately too. Last weekend when I came out of work to head home after a large temperature swing and rainy day the inside of my windshield and drivers door were covered with condensation. It was just as bad on those 2 windows as it was on the outside of the windshield. I didn't notice it was the inside of the windows until i realized the windshield wipers where not clearing the windshield. Thankfully I carry a large microfiber cloth in my truck and was able to wipe the inside of the windows down.
    1lowlife likes this.
  3. Mar 4, 2018 at 2:32 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You don't have a teenage son borrowing your truck for dates? :rofl::rofl::rofl: Seriously, sounds like something you might want the dealer to look at. You could run a little test by spraying it with a hose?
    TheBeast, joonbug and ColoradoTJ like this.
  4. Mar 4, 2018 at 2:46 PM
    cfred70
    Craig
    Ohio
    I've driven in the rain and snow and no signs of leaks, it only seems to appear during those times where condensation can occur, cold/frost outside and truck warms up from the sun. Today when I got in the outside temp was high 30's, but the sun had warmed the inside of the truck alot....I'm just wondering what I can do to keep this from happening...roll windows down just enough to keep airflow?
    831Tun likes this.
  5. Mar 4, 2018 at 2:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :notsure:
  6. Mar 4, 2018 at 2:52 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Condensation due to weather. Keep the airflow going. Will be alright when it warms up and the air temp is drier
  7. Mar 4, 2018 at 4:55 PM
    cfred70
    Craig
    Ohio
    Never had this happen before on any of my other vehicles and they all have been parked in the same spot. May throw some window rain guards on and crack the windows and see if that helps. I only notice it on days that have frost but then get warm. Hoping its just condensation....would think if its a real leak I'd notice it when its raining
  8. Mar 4, 2018 at 7:31 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I would give your truck a good once over looking for any leaks. Are your floor mats damp or wet? Is the carpet under your mats damp or wet? Our trucks, especially your new one are extremely airtight so there's no air movement when it's parked overnight. Relative humidity coming from something wet inside the truck will condense on the windshield as the air warms inside the truck and because there's no air movement the humidity can't escape.
  9. Mar 4, 2018 at 8:56 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    It is condensation, I noticed it a time or two on mine. I also noticed it under similar condition on my previous trucks (not Toyota), it is usually worst when you have sow on your floor mats that melts.
  10. Mar 4, 2018 at 9:14 PM
    Take back to dealership...maybe bad or defective weatherstripping?!??? Take pics of water marks show dealership
  11. Mar 6, 2018 at 3:01 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Make sure when you park it that you set the climate control to recirculate, that will keep the outside air out, stopping the moisture build up.
    Also on new vehicles the new plastics and adhesives used on the interior parts and pieces will off gas leaving all sorts of different visible shading and spots.
    I use Adams Polishes Brilliant Glaze on the interior and exterior of the windshield and the exterior of the remaining glass. Hope this helps.
    -Jason
  12. Mar 7, 2018 at 8:15 PM
    Inferno22
    Inferno22 New Member
    2018 crewmax inferno
    Bds 7" lift, led inside and out ,black out tints, color match end caps, progrill, nsv light bar
    Now that you mention it i did notice 2 streaks in mine I will check it tomorrow really did not give it any thought . And mine also condensate and gets really foggy nothing like I have experienced before.
  13. Mar 7, 2018 at 8:19 PM
    Was the recirculation selected on your HVAC system instead of fresh air?
  14. Mar 7, 2018 at 8:20 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Take it in for the dealership to look at. It could be nothing or it could be something. At least they will be aware if anything else happens.
  15. Mar 7, 2018 at 8:22 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    I get this all the time. I have a steep driveway so I back in when I park. Snow accumulates on the windshield then the sun comes out and starts to heat things up causing condensation on the inside of the window. I'm at the point of putting a towel on the dash to catch what's running down into the defroster vents.
    I'm going to try the recirculate trick mentioned above and see if it helps. I'm going to park the opposite direction as well.
  16. Mar 7, 2018 at 8:28 PM
    Don't use recirc on the HVAC controls. This will make it worse, and the reason I asked.
  17. Mar 7, 2018 at 8:51 PM
    NCinCO
    Gary
    Thornton, CO
    Bathroom stops are inevitable.
    Upgrayedd likes this.
  18. Mar 7, 2018 at 8:58 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I run the floor/defrost on the climate control pretty much all winter to help with moisture control in the cab. The AC system runs on this setting and dries the air out.
  19. Feb 25, 2019 at 7:25 PM
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    Bring this up. I had almost my whole windshield with was frosted this morning. I thought it was outside and when I hit my wipers, the condensation did not go away. I finally reach up and it was water inside. Like someone had sprayed water inside.
    I just had it at the dealer for an oil change last week. I will see if tomorrow morning happens again. I’m in Atlanta.
    It had rained for 5 days and then a warm day and this morning was 37F
    ‘18 CM MGM.
    Rocko9999 likes this.
  20. Feb 25, 2019 at 7:31 PM
  21. Feb 25, 2019 at 7:35 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Happens all the time in mine in this snowy climate. Get in with snow on boots or something damp is left in the truck, then have the truck sit for a while where it’s colder outside than inside the truck and you’lol have droplets running down the inside of the windshield. I put defrost on high and hit the recirc button to dry it out. Keeping the inside of the windshield clean helps too, as it cuts down on particles for the condensation to adhere to.
    eddie98 likes this.
  22. Dec 11, 2019 at 8:41 PM
    Deanclean27
    Deanclean27 New Member
    Dean
    The Heart of Dixie
    2020 MGM Tundra TRD Pro Crewmax
    Today at 1:15. I just bought this truck. Took to dealership for them to check out. It has been cold/snow last night. Never had this issue with my 2017 Tundra
  23. Dec 11, 2019 at 8:51 PM
    biebs96
    PA
    ^^ is this what everyone is referring too?
    If so I’ve had it since I’ve owned a Toyota truck (20 years)
    They are air tight and every one of them I owned always would do this windshield/window thing under the proper circumstances.
  24. Dec 11, 2019 at 8:55 PM
    Deanclean27
    Dean
    The Heart of Dixie
    Good to know. I haven’t ever had any problems this severe. My 4th Tundra.
  25. Dec 12, 2019 at 1:29 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I agree with those that stated weather..
    When some of the cold fronts come in it will layer the inside of the windshield (well, all the glass) in condensation.
    Depends on the variation of the temps and humidity levels..
    This happens on my 2014 a few times a year in Dallas..
  26. Dec 12, 2019 at 3:24 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Don't crack the windows it will only get worse
  27. Dec 12, 2019 at 7:34 PM
    Deanclean27
    Dean
    The Heart of Dixie
    Took the New Truck back in to the dealership for a water pressure test. No faulty gaskets or seals according to the technician. Raining tonight in Alabama....we shall see if any water is under glass in the morning.
  28. Dec 10, 2021 at 8:50 AM
    Rocko9999
    Rocko9999 New Member
    Old thread but what ever came of this? I have similar issue on my 2014. Entire windshield was covered in condensation. Can't find any leaks.
