Weak A/C blower???
Discussion in '3rd Gen Tundras (2022+)' started by 2022-1794-4x4, Mar 20, 2022.
  1. Mar 20, 2022 at 12:32 PM
    2022-1794-4x4
    2022-1794-4x4 [OP] New Member
    Does anyone else’s air conditioner seem like it’s restricted? When I have it on high/full blast it still feels very lackluster like it’s on maybe medium on any other truck. it doesn’t blow very hard at all?
    Also but probably not related to when you have the heat turned on and you turn it back down to a lower temperature let’s say 65 continues to blow pretty hot until you turn it all the way to low and then back up to 65 any thoughts? Thanks y’all.
    tundznoff and BarryB like this.
  2. Mar 22, 2022 at 9:40 AM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    I feel this way about mine. The main dash vents are very lack-luster. Where as the rear console vents kick ass. I don't get it. The blower makes more nose on high like it should be making your hair flow in the breeze but the result at the vent is "meh" at best.
  3. Mar 22, 2022 at 9:55 AM
    2022-1794-4x4
    Exactly, it’s not until you go down to”LO” if you have it on recirculate mode and on face or head “mode” and then you go down to LO ,you’ll hear it kind of switch and become quieter and actually blow harder like it supposed to. I tried posting a video of all this but it won’t load let me know if used those as well. No way this is how it’s supposed to be. It’s noise as hell and has no pressure until you do the steps that I stated above. I fear that this will become a recall issue but until then Toyota will say there’s nothing wrong with it.
  4. Mar 22, 2022 at 10:41 AM
    Cholland5583
    Cholland5583 New Member
    Stupid question but did you hit the A/C on button? I thought the same thing but wasn’t hitting that button and now that I do it’s get colder in the truck. Now I’m not sure if that’s a max ac feature or what as I haven’t read the manual.
    JRC likes this.
  5. Mar 22, 2022 at 10:43 AM
    2022-1794-4x4
    yeah, the a/c is switched to “a/c on”
  6. Mar 22, 2022 at 2:56 PM
    2022-1794-4x4
    And just what you could’ve figured Toyota told me everything‘s in working order and that’s the way it’s made it only blows harder when it’s set in “LO” temp. The technician was like yeah I totally see your complaint hopefully there’s a recall on it but this is the way it is we checked other tundras. It sounds very petty and minor but when you’re in 95° summer and sweating your ass off in your brand new $62,000 truck kind of makes you bite yourself in the ass I’m pretty positive I’ll be looking for a new GMC
    RoogerDog and BarryB like this.
  7. Mar 22, 2022 at 3:32 PM
    toms
    toms New Member
    Tom
    2022 Tundra SR5 TRD Sport Double Cab 6.5' 4x2 Blueprint
    My new SR5 TRD Sport is the same way, anemic from the vents. My '19 Platinum could freeze you to death, so this is definitely not normal. I had to check if it was even turned on, more than once.
    BarryB likes this.
  8. Mar 22, 2022 at 3:43 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    wonder if they downsized the ac to help with the mileage
    Y0TA PR0 likes this.
  9. Mar 22, 2022 at 3:51 PM
    2022-1794-4x4
    Exactly! The only way I know it’s on is it’s loud as hell. It sounds as loud as the defroster, or louder, but has nothing blowing out barley. Turn it to Lo and you’ll hear the blender door shut and it get quiet and blows harder. But that’s not going to cut it. I shouldn’t have to have it on
    The way low for my ac to work. I’m
    Legit going to GMC tomorrow while this tundra is still tradable. Sounds so petty, but if I’m in my truck sweating in 70° weather, what happens in 95° Weather? Nahhh
    MadMaxCanon likes this.
  10. Mar 22, 2022 at 3:59 PM
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    Did you make sure the recirculation buttion is on? This will be your max ac and should kick the blower in to high. Also, did you try closing the rear vents as well?
  11. Mar 22, 2022 at 4:01 PM
    toms
    toms New Member
    Tom
    Yah, I'm in SW Florida, cold is a necessity
  12. Mar 22, 2022 at 5:23 PM
    2022-1794-4x4
    Yep, I always run recirculate. Yeah, that may help, closing the rear vents, but we shouldn’t have to, ya know?
    Acedude likes this.
  13. Mar 22, 2022 at 5:32 PM
    tropro
    tropro New Member
    Troy
    MN
    I hear you. Been too cold yet in Minnesota for me to run the AC but we can get some hot, sticky humid weather in the summer. Better work. If I didn't have rear passangers in my 16 CM I would shut the rear vents for better front air flow. Maybe my vented seats will come in handy after all?
  14. Mar 22, 2022 at 5:37 PM
    gman54313
    gman54313 New Member
    Crazy to think a Toyota engineer would test this AC system and give it a thumbs up for production.
    BarryB and Totherion like this.
  15. Mar 22, 2022 at 8:01 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    15 years wasnt a long enough time to redesign a new tundra.:bananadead:
  16. Mar 22, 2022 at 8:18 PM
    Breathing Borla
    Northern Illinois
  17. Mar 23, 2022 at 6:30 PM
    Touchdown
    Touchdown New Member
    I checked my ac airflow on the center vents and agreed it felt restricted. When I switched the climate control to auto, the center vents airflow was very strong. I don’t understand the logic of why Toyota would allow normal airflow in auto but restrict airflow in manual mode.
  18. Mar 28, 2022 at 8:25 AM
    dgeels
    dgeels New Member
    Derek
    I am having the same issue with my 22 limited. Brought it into the dealer and they said they thought it was very odd but the other 22 tundras on site all had the same behavior. Thankfully mine seems to push out air pretty well when I have the AC set to Lo. So the truck cools down pretty quickly. As soon as I set the manual temp up above "LO", it seems like the air flow is being restricted in the front. The rear is blasting still though. Very odd and hopefully they get this fixed by next winter o_O
    Acedude likes this.
  19. Mar 28, 2022 at 10:02 AM
    HoustonACman
    HoustonACman New Member
    Mat
    I wonder, what is the difference between the car AC vs home AC? I want to call a Home AC contractor to fix my car's AC, I wonder if they can do it? Because My friend is a home AC Contractor and I just want to save some money by asking him to help me out.
  20. Apr 4, 2022 at 8:25 PM
    extremes074
    extremes074 New Member
    David
    West Coast, Florida
    22 1794 TRD Off-Road
    Wish mine was better as well. Comparing to my 2008 Highlander to this and the Highlander wins all day long. I mean I know it’s a larger vehicle and it is working but with the climate set for 70 it doesn’t blow as much as I’d have thought, gotta take it to 67 or below to really feel like it’s working better…
  21. Jun 16, 2022 at 4:13 PM
    RoogerDog
    RoogerDog New Member
    Kurt
    2022 Tundra TRD Crewmax
    Same here... bought mine in Montana. Technician and I tried other Tundras on lot - same issue. Fan works better (not great) w/recirculating air on. Although I love this truck now (700 miles), I have a feeling the poor fan motor performance will change my opinion (especially in the winter). Fingers crossed all of our complaints/objections to this issue will be handled properly by Toyota.
  22. Jun 16, 2022 at 4:53 PM
    fordguy1470
    fordguy1470 Member-ish
    West Columbia, SC
    22 CM SR5
    Getting there
    I don’t know what you all are on about. My AC works fantastic. I’m in Flora-Bama (Mobile area) for work and it’s satans nutsack hot here right now. My truck freezes me out, and I’m the most hot natured person I know. I start on low for a bit and usually have it turned up around 70 at the end of a 20 minute drive. Build date was May… Shouldn’t make a difference though. :notsure:
    Whitatu19, Polo08816 and hivetyrant like this.
  23. Jun 16, 2022 at 7:31 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    We have some of the highest humidity in the country here in South Louisiana. It’s been in the 90’s and the AC seems fine to me.
    It doesn’t blow as hard as my 17 did but it still blows plenty hard enough.
  24. Jun 17, 2022 at 5:37 AM
    hivetyrant
    hivetyrant New Member
    2022 Limited Tundra
    I'd agree that the ventilated seats are loud and not very effective, but the AC works great for me.
  25. Jun 17, 2022 at 5:52 AM
    pneffkell
    pneffkell New Member
    I am in south florida and I would say that the 22 i just picked up requires me to set the temp lower than I did in the 21 I traded in. I don't have a problem cooling the truck down but I highly doubt its really cooling my truck to 64 degrees. I feel like maybe the temp sensors for the AC are not very accurate
  26. Jun 17, 2022 at 7:07 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    My AC works awesome!! I need to close the shade on the pano roof though if I want it to really cool down (common sense).
    JRC likes this.
  27. Jun 17, 2022 at 10:43 AM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    Just rolled of the lot in my new Limited DC… a/c blows ice cold and powerful on LO… adjusting the temp manually doesn’t seem to affect the strength one bit, just the temp…
    ventilated seats are audible if setting still and quiet… radio on don’t notice it… I have noticed the upper back area is felt much more than anything down below…
  28. Jun 17, 2022 at 4:33 PM
    FALQN
    FALQN New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    My blower and AC work just fine…gets real cold, especially when I take it off of Auto and manually adjust settings. I have used the defrost and AC so far and absolutely no complaints. Very happy.
  29. Jun 17, 2022 at 8:57 PM
    Foques
    Foques New Member
    it is in the settings; I thought so too, at first. If the truck is in economy mode and climate control is on, the AC is laughable. but if you turn the ac on via button, it works well
  30. Jun 17, 2022 at 10:44 PM
    Booyashakalaka!
    Booyashakalaka! New Member
    I have more of a problem with a AC not being cold than I do the blower. Driving with AC on in normal drive mode. I can't imagine being stuck in 100 deg weather.
