Weird?? Driver Side 0.5" Lower than Passenger side
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Aug 6, 2021.
  1. Aug 6, 2021 at 11:12 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I've noticed lately my truck seemed cock-eyed. Was really bugging me so I finally busted out the tape measure at work when I was parked on pretty level ground. Sure enough the drivers' side sits 0.5" lower than the passenger side. Front and Back.
    What would cause this? I put a Fox 2" coilover lift on the front and 1" leaf block lift in the back, about a year ago. At the time I measured and everything was bueno. Rear was 1" higher, but left and right were the same.
    Any ideas?
    Front Left:
    Front Right:
    Back Left:
    Back Right:
    Coachbuilder1 likes this.
  2. Aug 6, 2021 at 11:14 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    With the gas tank on the driver side, most Tundras tend to sag that way a bit. Mine certainly does.
    Saltyhero13 likes this.
  3. Aug 6, 2021 at 11:26 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    "Tundra lean" for the reason stated above. Tundra can twerk too.
    Gravy likes this.
  4. Aug 6, 2021 at 11:28 AM
    RussellVaughan
    Houston
    Well damn. I guess that means my OCD is getting worse since i've had the truck for 5 years and hadn't noticed...good to know the lean is normal though (i guess) lolol
    Saltyhero13[QUOTED] likes this.
  5. Aug 6, 2021 at 11:34 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    If you have adjustable coil overs it’s an easy fix
    HulkSmurf14 likes this.
  6. Aug 6, 2021 at 1:11 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    weight distribution causes this on every 2007+ Tundra. As others have mentioned battery, Steering column, instrument cluster, you in the driver seat and the fuel and tank all lined up on that driver side. Most of this weight is slid forward so by correcting the front it should un twist the truck and lower the right rear corner too. We build shims to fix this without needing to add preload to your coilover. Hope this helps.
    https://shop-coachbuilder.myshopify...ilder-strut-coilover-shim-provides-50-of-lift
  7. Aug 24, 2021 at 10:46 AM
    RussellVaughan
    Houston
    sweet! just placed my order. thanks for the info, I feel dumb just now learning this after owning this truck for over 5 years.
    Coachbuilder1[QUOTED] likes this.
  8. Aug 24, 2021 at 10:52 AM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    Don't feel dumb. I was in the same boat for a while. I even asked a dealer to check out my springs at some point.
  9. Aug 24, 2021 at 12:54 PM
    Coachbuilder1
    David
    Salt Lake City UT
    I hear this often and am happy to provide help in getting it corrected. Dealerships have replaced struts/ shocks and even leaf springs all because they don't understand what's causing it. :)
