Weird jolt/jerk when coming to a stop or accelerating from a stop
Discussion in '2nd Gen Tundras (2007-2013)' started by Underdogg, Aug 15, 2023.
  1. Aug 15, 2023 at 11:12 PM
    Underdogg
    Underdogg [OP] New Member
    07 Crewmax 5.7L
    07 Crewmax 5.7
    Hey all. Whenever I'm braking into a stop, right before I come to a complete stop I feel the car make a slight jerk like something is shifting into place. When I remove my foot of the brake and the car moves a bit or when I tap the gas, I feel the same thing. Even when I shift into sport mode to manually shift it occurs so I am guessing its not the effect of the gears actually shifting. Shifting from P to R also feels clunky.
    The truck used to do this a few years ago then went away after I cleaned the MAF and throttle body. It magically reappeared after taking the car for an alignment a month ago. Not sure if any of these things are related. I recleaned the MAF and scrubbed the throttle body and it didn't fix it this time.
    Anyone know what the culprit might be? I only know how to do very basic maintenance so I have no idea where to start checking for issues. TCM? Suspension? Wheel/Brakes? Trans mount? U joint? Torque Converter?
    Cheers
    joonbug likes this.
  2. Aug 16, 2023 at 12:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If it started after the alignment, they probably didn’t torque the alignment bolts. And if that’s the case you probably need another alignment.
    2mchfun, Black Wolf and Underdogg[OP] like this.
  3. Aug 16, 2023 at 12:41 AM
    Underdogg
    07 Crewmax 5.7L
    thanks for the suggestion, I'll lift it up and check if everything is torqued right
  4. Aug 16, 2023 at 5:18 AM
    2mchfun
    Check your u joints and center carrier bearing, check your brake calipers and make sure they are not loose as well. Could be a broken shock banging around too. Many possibilities.
    Underdogg[OP] and g6t9ed like this.
  5. Aug 16, 2023 at 7:40 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    If the above suggestions don't work, might I also suggest adding a possible maintenance item: greasing your driveshaft/zerks. You didn't mention whether or not you performed this, so it could possibly be a culprit.
    Back in the day when I had an '08 Tundra, I would experience this jolt at stop lights. It started occurring right around 120k miles on the odometer. I didn't know shit from shinola back then but after later researching it (after I traded that truck in), I came to the conclusion this was the cause of it. So, I can't confirm if this is what you're experiencing but couldn't hurt to try.
    Please update on what the fix was so that I can feel better about myself and feel redeemed, lol.
    Underdogg[OP] likes this.
  6. Aug 16, 2023 at 7:42 AM
    2mchfun
    The driveshaft spline inside the boot might need grease. Mine had very little factory grease when it only had 20k on the clock. PM me if you need to find a new boot.
    landphil and Underdogg[OP] like this.
  7. Aug 17, 2023 at 2:24 PM
    Underdogg
    07 Crewmax 5.7L
    I have never done this and I am 99% sure the previous owner also did not do this. I'll look into this thanks. I will let you know if this fixes the issue haha
    g6t9ed[QUOTED] likes this.
  8. Aug 17, 2023 at 2:54 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    I don't understand how you ruled out the transmission, if you are in Sport mode it may seem like a manual shift but everything still shifts electronically. If you rule out mechanical issues and haven't solved the issue then I'd be checking that the ATF level isn't slightly low (actually I'd be checking the level first because I like to start by ruling out stuff that's simple to check).
    Underdogg[QUOTED][OP] likes this.
  9. Aug 17, 2023 at 4:08 PM
    Underdogg
    07 Crewmax 5.7L
    Oh okay thats good to know, thanks for the help. I'll check the fluid levels
  10. Aug 17, 2023 at 5:25 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    Your description of the clunk when you come to a stop and then when you let go of the brake and go sounds a lot like axle wrap. The 1st gen Tacomas were known for axle wrap (I have a 03 Tacoma) when their fairly soft leaf springs break in and become even more soft. They let the axle twist a bit at stop. When you let off the brake and go, the axle unwraps and and the slip yoke slides a bit and you get that "bump". Hard to say for sure, but the symptoms match almost exactly what I had on my Tacoma. Most solutions start with lubing the slip yoke. That helped on my Tacoma, but didn't fix it and I wound up getting traction bars. Some people replaced their leaf springs. Here is a thread on TacomaWorld. https://www.tacomaworld.com/threads/axle-wrap.334763/ In his first paragraph he says "....... try and figure out why in the world my truck was making this awful "thump" or "clunk" when stopping or accelerating.". The thread offers some cheap ways to eliminate it.
    Leo's first likes this.
  11. Aug 19, 2023 at 9:08 AM
    farnsrocket
    farnsrocket New Member
    Definitely lube your driveshaft. I had an 02' Sequoia that used to have a thunk at stop and starts that went away after lubing the driveshaft.
