Wescott Design Preload lift On Tundra Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TunofLunaRock, Aug 3, 2021.
  1. Aug 3, 2021 at 8:28 AM
    TunofLunaRock
    TunofLunaRock [OP] New Member
    Serg
    Tundra
    Was wondering if anyone has done this 1” lift to their truck? How has it preformed? Any issues?
  2. Aug 7, 2021 at 1:05 PM
    TexasTRD
    TexasTRD New Member
    I went with Wescott up front and coachbuilder +3 shackles in the rear as lots of folks here have done. Zero complaints or issues. Ive noticed no real difference from stock on performance.
    TunofLunaRock[OP] likes this.
  3. Aug 7, 2021 at 3:37 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Have it had it for about a month and a half…rides great so far and let’s me run 35” tires with no cab chop.
    and yes, my truck is a 1794, but I switched out to the TRD Pro fox suspension and had the lift added at the same time…pics are before and after new set of wheels
  4. Aug 8, 2021 at 10:47 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    No issues for me in 5k miles so far after adding the Westcott.
    I’ve got CB+2 in the back right now but am eyeballing the Roadmaster AS kit for the back.
  5. Aug 9, 2021 at 11:03 AM
    MinehunteR
    MinehunteR New Member
    I have been researching this lift as well.
    Would anyone be willing to give a center of front hub to bottom of fender measurement? With either the westcott or coachbuilder front lift?
  6. Aug 9, 2021 at 12:49 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    24 3/4” from middle of my center cap on wheel to bottom edge center on front wheel well with Westcott lift on TRD Pro Fox suspension
    pandapro and MinehunteR[QUOTED] like this.
  7. Aug 9, 2021 at 1:58 PM
    MinehunteR
    @1P7R9O4 thanks alot, this is incredibly helpful! Your truck looks great!
    1P7R9O4 likes this.
  8. Aug 9, 2021 at 2:15 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    :thumbsup: Happy to help…I will also add that if you do this lift on the front, you definitely need the 1” block at the rear (or shackles/add a leaf/etc.) or your front end will be nose high. I went with the 1” block for the time being as I don’t tow anything heavy/often enough to cause a lot of rear sag. Truck sits level, maybe very slight (1/2-3/4”) front rake but overall level
    MinehunteR[QUOTED] likes this.
