Westcott Preload Collar 3/1 Lift Kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by brevard828, Sep 16, 2023.
  1. Sep 16, 2023 at 6:53 AM
    brevard828
    brevard828 [OP] New Member
    2021 Limited TRD Off Road
    I apologize if there is a 2.5 Gen thread on the Westcott lift, but i was unable to find one that answered all of my questions. So hopefully ill be able to help someone else a bit! Ive been posting in the "what have you done to your 2.5 today" but i thought this may help in the forum search.
    Jumped on the Westcott train this weekend! I've heard great things about their products and their customer service reps answer the phone every time. It's been a while since I've had time to play with the old Tundra. I've had 5100's on the middle setting for about a year and have loved them. I will be using the full 3-1 lift option for the Westcott. They say no BMC and no UCA (I will see what the alignment guys say and will possibly order a UCA depending) Per Westcott, i installed the driver's side 5100 clip on the second setting in order to compensate for driver's side lean. The passenger was set on the bottom. Everything measures evenly
    Also installed Daystar cradles for the airbags that I've had for quite some time as well. Toyo Open Country AT3 295/70r18's are going on Friday when she goes in for an alignment. Bilstein 5160 rears to come soon as well mostly because I can't find 5100 rears anywhere.
    Now that new tires are on! 295/70r18 on +25 methods. I tried to use the heat gun method and on while doing off-camber reverse turns still had fender liner rubbing. I didn’t want the funny line of a bumper shim so I compromised. I removed a small portion but left enough to protect the back of the fog light assembly. Now it is nowhere near anything. I attached some pictures to help answer the most common tundra questions :D
    I cant say enough about the product so far. Easy install and great customer service. The ride quality and handling is just as smooth if not more composed.
    https://westcottdesigns.net/product/tacoma-tundra-4runner-bilstein-5100-preload-collar-lift-kit/
    Capture.png 71614306133__044BFB2F-04FC-40DA-B735-511E0D02C911.jpg IMG_4573.jpg 71615300150__FB629F41-5464-4949-A5BB-7F02C9FB232D.jpg IMG_4570.jpg IMG_4574.jpg IMG_4571.jpg IMG_4617.jpg IMG_4611.jpg IMG_4616.jpg IMG_4618.jpg IMG_4621.jpg IMG_4577.jpg IMG_4603.jpg IMG_4615.jpg IMG_4619.jpg IMG_4545.jpg IMG_4602.jpg IMG_4620.jpg 71614246811__11C643F9-E4FD-4244-A361-C5C01AC94D10.jpg IMG_4606.jpg IMG_4607.jpg
