What’s the correct air filter for a 2019
Discussion in '2.5 Gen Tundras (2014-2021)' started by 94Toy22re, Dec 8, 2023.
  1. Dec 8, 2023 at 9:06 AM
    94Toy22re
    94Toy22re [OP] New Member
    I ordered a Bosch through rock auto, it was too big and douse not fit and now a Toyota filter 17801-0S010 and it’s also too large! It seems like reading reviews through Amazon others are also having issues with 2018-2021 Tundras, so what's the correct part number?
  2. Dec 8, 2023 at 9:23 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    go to any auto parts store website or location, type in year, make, model and engine and it will tell you which filters fit.
  3. Dec 8, 2023 at 10:07 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The correct part number is 17801-0P100
  4. Dec 9, 2023 at 5:00 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Just buy the right one from a Toyota dealer.. y go through this trouble
  5. Dec 9, 2023 at 6:56 AM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    Yes, I ran into the same thing with my 2021. There are two separate filter housings used. One is the small (10.25") which has a paper filter with rubber surround. It's commonly called the "soft" filter. Toyota part number 178010P100 like Joe says. Also can be found as Fram FDA11895 or Napa FIL 200085. This is the one mine has.
    The "large" filter is 12.45" if I recall correctly, has a cloth-like filter media, with much looser (wider spaced) pleats and a plastic frame around the outside. It's called the "rigid", and has a Toyota Part number 178010S020 (Fram FDA10343).
    Hope that helps.
  6. Dec 9, 2023 at 6:59 AM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
  7. Dec 9, 2023 at 7:00 AM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
  8. Dec 9, 2023 at 8:07 AM
    Joe333x
    Joe333x Member
    Boston
    The Tundra has one engine are filter (17801-0P100). That other filter you posted is for a Tacoma, 4runner and Supra 1993-2004. https://toyotaparts.ourismantoyotaofrichmond.com/oem-parts/toyota-air-filter-1780107020
  9. Dec 9, 2023 at 1:13 PM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    Hi Joe -
    Respectfully, I disagree. The Amazon ad I linked was for the photo (to show the difference between the two styles), not for the part number.
    If you look up parts for my 2021 Tundra on Toyota's parts lookup, there are two parts shown. One is the 1780-0S010 (the rigid) and one is the 17801-0P100 (the soft). They are different sizes, and both sohw fitting Tundra 5.7 and Sequoia. To be fair, I'm not sure which trucks got which one, but the housings are different. Mine has the soft one.
    Cheers,
    Russell
