What air filter brand are you guys using?
Discussion in '3rd Gen Tundras (2022+)' started by Eurodriver, Sep 5, 2023.
  1. Sep 5, 2023 at 3:36 PM
    Eurodriver
    Eurodriver [OP] New Member
    And where are you getting it?
    I just realized I haven’t changed my air filter in 40,000 miles. At least I drive carefully in clean environments.
    Are you buying OEM? Is there something else on the market? I’m not going with K&N or any other oil based filter.
    Also, has anyone done a brake fluid or coolant flush yet?
  2. Sep 5, 2023 at 3:46 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I get air filters from local auto parts stores.
    Usually Purolator. I think they only had fram last time, so I grabbed one of those.
    It's a wear item that gets replaced often enough that it doesn't need to be over priced or over marketed. Store brands and OEM work great and as designed. It's more important to change it more often and keep it from getting dirty and restricting flow.
    Sixty9Four20 likes this.
  3. Sep 5, 2023 at 3:47 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    Fram from walmart. Sometimes I use a paper towel folded many times.
    iforceAZ likes this.
  4. Sep 5, 2023 at 3:49 PM
    iforceAZ
    iforceAZ New Member
    Oiled or dry?
    ArticTundra likes this.
  5. Sep 5, 2023 at 3:56 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Unless its HEPA certified; it's a waste of money and you might as well lose the obstruction device.
  6. Sep 5, 2023 at 4:08 PM
    Breathing Borla
    Northern Illinois
    Oem Toyota in all my Toyotas , great filters and you can get them decent price online
    TundraDan723 likes this.
  7. Sep 5, 2023 at 4:14 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    My experience with diesel turbo engines is one thing you dont chinz on is the air filter
    Turbos suck a lot of air, and an el cheapo filter can disintegrate and if a substantial enough piece gets into the turbo you will be funding a turbo replacement. I have seen OEM filters for the diesels have metal support and the Walmart ones have paper supports
  8. Sep 5, 2023 at 4:16 PM
    EmergencyMaximum
    Dry.
    iforceAZ[QUOTED] likes this.
  9. Sep 5, 2023 at 4:26 PM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2023 ICE CAP SR5 CREWMAX
    AFE Pro Dry S......
  10. Sep 5, 2023 at 4:35 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Ah, this is 3rd gen. I need to stop hitting "new posts".
  11. Sep 5, 2023 at 6:10 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Might check out filterheads.com I dont have any affiliation, just used a few times. Decent prices if OEM isnt available
  12. Sep 5, 2023 at 6:38 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Assuming standard duty urban use, at what mileage interval should air filters be replaced?
  13. Oct 3, 2023 at 7:20 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    OK, I give up. Where are you guys buying the engine air filters from? I can find the OEM filters at several online stores, but they are charging $17-24 for shipping, making two filters come in at over $90. Ouch.
    And...I looked at the filters on my 2023 1794 TRD. They are paper, not oiled. Hum, thought the OEM filters were oiled. Anybody else have paper filters in their truck?
  14. Oct 3, 2023 at 8:01 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I may be mistaken, but I think the TRD filters are the same as K&N, which are oiled. My regular filters are paper. I just had them changed about a month ago at the recommended 30k mark. Dealer had them. Could you look on Amazon and get free shipping?
  15. Oct 3, 2023 at 8:05 PM
    22whatwedo
    The Open Road
  16. Oct 4, 2023 at 6:46 AM
    Tom976
    Tom976 New Member
    Tom
    OEM has two choices.... I had the regular paper ones in my 1794 and switched it to the toyota TRD filters which look exactly like the K&N filters just a bit cheaper. They are washable / re-usable.
    Performance difference? Maybe? You hear the turbos working a little but louder with the TRD filters.
  17. Oct 4, 2023 at 7:40 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    TRD filters in oem boxes
  18. Oct 4, 2023 at 1:15 PM
    22TXAG
    22TXAG New Member
    I recently purchased 2 of the TRD filters from Serra Toyota Decatur for $68 shipped. They were having a labor day sale at the time.
  19. Oct 5, 2023 at 5:13 AM
    therandomsuit
    therandomsuit New Member
    I just replaced mine with the OEM ones. I was planning on getting WIX air filters but none of the parts stores had them in stock yet. Wix part number is WA11653.
