What amp can I replace my factory amp with..
Discussion in 'Audio & Video' started by CH1NO, May 11, 2020.
  1. May 11, 2020 at 6:07 PM
    CH1NO
    CH1NO [OP] New Member
    TEXAS
    2016 SR5 CM
    What amp can I replace my factory amp with on a non JBL unit? Something that's just plug and play?
  2. May 11, 2020 at 6:24 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    This is what I used on my non jbl system. It is not plug and play. You don't need to run any extra wires including the power wires. Everything is under the passenger seat. It changed my sound substantially and I kept the stock speakers. It is small enough to slip under the oem amp without removing it.
    Pioneer GM-D1004 400W 4-Channel GM Digital Series Class FD Amplifier. 100 bones..
  3. May 12, 2020 at 1:18 AM
    CH1NO
    TEXAS
    2016 SR5 CM
    @jeremyd gonna give this a try thanks for sharing
    jeremyd likes this.
  4. May 12, 2020 at 4:58 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    This is my setup with factory head unit
    CH1NO[OP] and jeremyd like this.
  5. May 12, 2020 at 7:40 AM
    CH1NO
    TEXAS
    2016 SR5 CM
  6. May 12, 2020 at 7:45 AM
    Azblue
    The Dirty T ( ^_^)_且
    You can use any 4 channel amp with speaker level inputs, although I suggest a 5 channel so you can add a sub either now or later. There are wire harnesses available to make it kinda plug and play. Whatever amp you end up using, you will need to run new power and ground wires.
    Kung and panicman like this.
  7. May 12, 2020 at 8:18 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Here is what I did:
    https://www.tundras.com/threads/2018-sr5-non-jbl-audio-upgrade.65640/
    You could piece together a system however you like. I did mine in 2 phases: 5 channel amp and sub, then component door speakers with built in crossovers.
    The final phase I can opt for is upgrading the dash speakers.
    I am going to recommend you contact James at tech12volts. He can narrow down a very good product based on your desired outcome and your budget. He also responds immediately to email.
    I also would advise a 5 channel amp, especially after hearing the difference a sub makes in our trucks.
    AZBoatHauler and Azblue like this.
  8. May 12, 2020 at 8:53 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  9. May 12, 2020 at 9:34 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    You do not need to run new power wires if using a smaller amp like I posted.
  10. May 12, 2020 at 10:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    I would run a new wire from the battery. Those wires are tiny!
    Azblue likes this.
  11. May 12, 2020 at 11:12 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    It hasn’t burned up yet. Going on 4 years.
  12. May 12, 2020 at 11:37 AM
    Danimal86
    Daniel
    Sacramento, CA
    full tilt, that amp is drawing about 30amps. figure out what gauge wire the factory wiring is. If its 10ga you are good.
    I know on my non jbl, those wires are sooo small, maybe the jbl is beefier. I didn't want to power my jl Fix86 off the factory wiring, but i looked at the power draw, and its 1amp.
  13. May 12, 2020 at 11:40 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The only thing I said was that the oem wires were good for a small amp, obviously not gonna work for a bigger amp.
  14. Nov 2, 2020 at 9:12 PM
    glamisdave05
    glamisdave05 New Member
    Dave
    2014 DCSB
    Hypertech interceptor, Drop in K&N
    So you used both factory harnesses that are already under the seat and didn't need to run a new power wire or remote wire?
  15. Nov 3, 2020 at 4:41 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yes, The remote and power wires are already there. I used these two harnesses.
  16. Nov 3, 2020 at 4:58 AM
    Kung
    KG, VA
    This. I went with a JBL Stadium 5 because I wanted to replace all the speakers and add a sub. James @ Tech12Volts had a huge sale on these a while back; got it for something like $329 or so. The system sounds fantastic.
    Azblue[QUOTED] likes this.
  17. Nov 3, 2020 at 5:28 AM
    purplenova
    Tom
    Ohio
    It took me about 2 hours maybe, to get all the wires ran correctly and everything bolted down.
    I must admit, it took me two try's. The first time I had wires crossed and mt fade didnt work properly, so I unhooked everything and re-done it all.
    I used the autoharness house kit noted above by @jeremyd and made it easy.
