What are the best front rotors and pads for 2008 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by PieFace#19, Apr 26, 2017.
  1. Apr 26, 2017 at 3:18 PM
    PieFace#19
    PieFace#19 [OP] New Member
    I have a 2008 tundra with warped rotors. I have a slide in camper that weighs approximately 2000 lbs wet.
    What would be the best rotors and pads to replace them with?
    Are drilled and slotted rotors best w oem pads?
    Please include the names of rotors and pads you would recommend. thanks Gary
  2. Apr 26, 2017 at 3:54 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  3. Apr 26, 2017 at 3:57 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    I put on Centric anti corrosive rotors with Hawk pads and love them. I do not tow though.
  4. Apr 26, 2017 at 4:57 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I've use PowerStop drilled and slotted rotors on other vehicles. When the time comes on my Tundra, I'll probably go with those with the factory pads.
    careyrob likes this.
  5. Apr 26, 2017 at 5:14 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I'm running Power Stop C/S rotors one OEM pads. Stops quite nicely now.
  6. Apr 26, 2017 at 7:08 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Ditto on the power stop rotors I run Wagners for pads and I tow a 3700lb trailer and they have been flawless
    No brake fade or noise
    I run them on all 4 corners
  7. May 24, 2017 at 1:28 PM
    badams1897
    badams1897 New Member
    Bobby
    2013 Tundra Black Limited with Canyon Red Interior
    3.5" Level Kit in Front and 2" in back. MB TKOs 285/65/20 BFG KO2 ATs
    How is the brake dust from the Wagners?
  8. Jun 12, 2017 at 11:03 AM
    Jbjb2630
    Jbjb2630 New Member
    2008 Tundra 4x4 SR5 Double Cab
    Leveling kit, cab marker lights, custom entertainment
    I have been running the Wagner's for about 8months now with new rotors because my power stop setup with cross drilled and slotted rotors got warped from too many power stops! (Ironic?)
    Wagner's stop just as good and brake dust is minimal. Ill probably stick with these.
  9. Oct 25, 2017 at 10:31 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    +1 on Power Stop.
