What did you put in your Transfer Case when you changed the fluid?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ARMYGREEN, Jan 15, 2020.
What did you put in your Transfer Case when you changed the Fluid?
  1. TOYOTA TRANSFER GEAR OIL – 08885-81080
  2. RAVENOL MANUAL TRANSMISSION FLUID MTF-3 75W
  3. 75w-90 Synthetic Gear Oil
  4. Royal Purple
  5. Redline
  6. Other
  7. Have not done it yet
Results are only viewable after voting.
  1. Jan 15, 2020 at 1:33 PM
    ARMYGREEN
    ARMYGREEN [OP] New Member
    2014 CrewMax MGM
    I have read many posts about the transfer case in 2014+ and wold like to see the poll results.
  2. Jan 21, 2020 at 5:08 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I used the new redline mt-lv with no issues no change in shift quality.
  3. Jan 21, 2020 at 10:07 AM
    Overisland
    Overisland New Member
    Tony
    Polson, MT
    2020 Tundra Voodoo Blue Sport
    On my 1st Tundra (out of three, 1st was a 2010) I changed both diffs and transfer case fluid at the same time around 40k miles to Amsoil and saw a 1.5MPG improvement across the board. That was lifted 8" on 37" tires. I am quite partial to Amsoil. Will probably get Amsoil in my new Tundra after I get some miles on it.
    16 blue crewmax likes this.
  4. Jan 21, 2020 at 4:16 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Only oem oil for transfer case. Amsoil does not have a fluid they recommend for it
    14burrito and HulkSmurf14 like this.
  5. Jan 21, 2020 at 4:29 PM
    AZBoatHauler
    So.Arizona
    If you don’t mind, how many miles were on it when it was changed and how did the OEM fluid look? Thank you.
  6. Jan 22, 2020 at 10:32 AM
    Overisland
    Tony
    Polson, MT
    The owners manual says Toyota fluid "or equivalent" and recommends a 75W.
  7. Jan 22, 2020 at 10:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I changed the Tcase fluid in my Tacoma at 50k and I could have put it back in the bottle and sold for new. I do use 4wd a fair amount but not like someone would in the frozen north. I do not think I will ever change the tcase fluid in the Tundra.
  8. Jan 22, 2020 at 11:10 AM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    For the most neccessary comparable OEM additives in a synthetic, Redline, or stay OEM. Please read all the charts by Btanchors, others and myself.
  9. Jan 22, 2020 at 1:04 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I used an equivalent Toyota transfer case fluid and now I experience delayed disengagement of 4wd...just blinks for awhile until I have a turn of the steering wheel... this did not occur when the factory fluid was in the transfer case...
    Not sure if it's merely a coincidence or if its in fact the reason...engagement works fast and correct, just not the disengagement.
  10. Jan 22, 2020 at 1:32 PM
    BigTree
    BigTree New Member
    2016 Sequoia Limited
    I know that Mobil makes "Toyota Motor Oil" not sure about the gear oil, but I'm pretty sure its not synthetic, just like their W.S
    (World Standard) tranny fluid isn't synthetic either. It would cost Toyota A-Lot More Money to fill all there new vehicles with synthetic fluids (besides motor oil), So I'm with Overisland, Amsoil Synthetic gear oil, in the transfer case, Front and Rear differentials,too. Also Amsoil Synthetic tranny fluid (low Viscosity). Synthetic fluids flow better in cold weather, and they can dissipate Heat much better
    (higher Flash point) than conventional fluids, which is extremely important in transmissions.
    HulkSmurf14 likes this.
  11. Jan 22, 2020 at 2:57 PM
    HulkSmurf14
    2014 Tundra Limited
    I used the WS fluid and am having annoyances...driveline works, but I have to wait longer for it to disengage...if I did it again, I'd go with Toyota fluid to ensure proper function...
  12. Jan 22, 2020 at 3:10 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    It's your truck but would recommend against 75W-90 and use the straight 75W. Toyota changed transfer cases in 2014 from Aisin to Borg Warner and it's Borg Warner that specifies 75W. 75W-90 is fine for the diffs but many have had shift problems after putting it in their transfer cases.
  13. Jan 22, 2020 at 3:19 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    75w90 is not the same as straight 75, just like 0w20 is not the same as 0w40
  14. Jan 22, 2020 at 3:25 PM
    ninjajay
    Spoolston, TX
    Amsoil is so amazing that people swear by their products even when they themselves say they don’t recommend one for that application!
    14burrito likes this.
  15. Jan 22, 2020 at 3:35 PM
    Js18tundra
    25k, it was a little dark but still golden
    AZBoatHauler[QUOTED] likes this.
  16. Jan 22, 2020 at 4:14 PM
    Tiamat
    Tiamat New Member
    I respect a company that tells their customers that they should stick to the oem fluid because it is a unique formulation for that application.
    AZBoatHauler likes this.
  17. Jan 22, 2020 at 7:40 PM
    Overisland
    Tony
    Polson, MT
    Good to know, thanks for the info. I havent changed the fluids in my new truck yet and wasnt planning on it for a bit.
    duece292[QUOTED] likes this.
  18. Jan 22, 2020 at 9:01 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You used world standard fluid in the T-case? The WS is associated to the transmission, not associated to the transfer case.
    duece292 likes this.
  19. Jan 23, 2020 at 4:38 AM
    HulkSmurf14
    2014 Tundra Limited
    Hmmm, I'll have to confirm now...I did fluid swaps in everything underneath and was told my choices were: Toyota OEM fluid or World Standard...the shop I had do the work is a well-known Toyota shop in my area and they said if it was their own rig, they'd have no problem using WS...I thought WS had a newish variation for t-cases but I'll need to confirm...
  20. Jan 23, 2020 at 6:45 AM
    Ericsopa
    Ericsopa Old man and the sea
  21. Jan 23, 2020 at 6:48 AM
    HulkSmurf14
    2014 Tundra Limited
    ^^ Hahahaha yup!
  22. Jan 23, 2020 at 9:15 AM
    BigTree
    BigTree New Member
    like I said, W.S is Toyota's transmission fluid, which is not synthetic (mineral-based oil) , so I believe Amsoil, low viscosity synthetic transmission fluid, is superior over Toyota's W.S. As far as transfer-cases and differentials go, I use Amsoil synthetic gear oil, at whatever weight is recommended for my vehicle. Not W.S transmission fluid.
  23. Jan 23, 2020 at 10:49 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Amsoil does not make a like 75w 14+ Borg Warner case fluid.
    I'm not sure why WS keeps getting brought up in this tread...
  24. Jan 24, 2020 at 6:23 AM
    BigTree
    BigTree New Member
    Only because someone mentioned, that they thought, W.S was a "newish" variation for T-cases. I used the Amsoil 75W-90 Severe gear synthetic gear lube with no issues. When its cold out , it will be at 75W, ( like Borg-Warner specs.) that's my main concern, when engaging or disengaging, 4 wheel drive, during the cold winter, granted the viscosity of the oil will increase (90W)during warmer weather, but that hasn't been an issue.
  25. Jan 24, 2020 at 7:42 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I used ravenol 75w in the transfer case to replace ththe 75w90 that was in it. Shifts into 4wd smoother and quicker now. Used Schaeffer 75w90 in front and rear end.
    HulkSmurf14, Overisland and 14burrito like this.
