What does Eco mode do mechanically?
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Jul 25, 2024.
  1. Jul 25, 2024 at 3:00 PM
    SDHNTR
    SDHNTR [OP] New Member
    I understand what sport mode does. You can feel the shift points extended/prolonged. But what does eco mode supposedly do? I don’t notice or feel any difference at all. And I certainly don’t notice any improvement in fuel mileage. What exactly does it do?
  2. Jul 25, 2024 at 4:12 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Probably adds more lag to the gas pedal or adjust the fuel ratio.
  3. Jul 25, 2024 at 4:16 PM
    Retired...finally
    Just gives you a warm and fuzzy feeling that you're saving the environment.
  4. Jul 25, 2024 at 4:54 PM
    DRP
    DRP Old Member
    Dave
    It does exactly what the manual says it does:thumbsup:.
    Somebody had to say it.....
  5. Jul 25, 2024 at 5:18 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Mechanically, nothing. It’s all electronic. It changes throttle mapping to reduce input sensitivity and maximize timing with the least amount of throttle input. It really just leads to a lack luster driving experience.
  6. Jul 25, 2024 at 6:09 PM
    SDHNTR
    The manual says absolutely nothing about how it works. Says what it does, supposedly, my question is how.
    sandiegosteve likes this.
  7. Jul 25, 2024 at 6:10 PM
    SDHNTR
    Ok. That’s helpful. I literally cannot tell a darn bit of difference eco vs normal.
  8. Jul 25, 2024 at 6:15 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    It most likely is a very tame ecu throttle and timing curve map like stated above. Just general sadness and crushing disappointment.
    I can tell but I’m also running 35s and eco mode is just sluggish
  9. Jul 25, 2024 at 6:15 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Eco mode in other models reduces throttle response in the higher gears. 1st and 2nd gear are either going to be similar to normal, or just a tiny bit less, but then as the gearing goes up, then the response goes down.
    Tundrastruck91 and Jettster like this.
  10. Jul 25, 2024 at 8:38 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    That’s interesting. I can tell a difference in the performance. I only use in Cruise Control say at like 45-60 mph. I hate it otherwise.
    NORTHof54 likes this.
  11. Jul 25, 2024 at 11:34 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Eco mode shifts up at a lower rpm than Norm. It also shortens the run cycle of the A/C compressor.
    matth66 and Paulswagelock like this.
  12. Jul 26, 2024 at 5:31 AM
    Midnight Rider
    Midnight Rider None of the above.
    Dave
    Wright City MO
    2023 Platinum Crewmax 4x4
    Cup grips & a 2 decals.
    Strictly my experience, but for my use I get the same or better mpg in Normal as I get in Eco.
    22whatwedo and Retired...finally like this.
  13. Jul 26, 2024 at 5:54 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Should be renamed Govt MPG test mode. That is all it is for to eak out another 1/10 MPG on the tester while real world you get an extra .001 MPG sweating with AC neutered
    the4rdan and Deer Hunter like this.
  14. Jul 26, 2024 at 6:57 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I usually switch it over when I’m in bumper to bumber traffic. I find that the constant stop and go is a little smoother in eco
    Panic_Zeroize likes this.
  15. Jul 26, 2024 at 7:06 AM
    SDHNTR
    Isn’t that the exact opposite time you should be using it? From what I understand it’s only effective in the taller gears at high speed. I have even read that it can make mileage worse in stop and go or city driving scenarios. No idea if that’s accurate, but it stands to reason if you have to push the pedal harder to go the same speeds in the lower gears.
  16. Jul 26, 2024 at 7:17 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    It just doesn’t seem as jerky in traffic. I could be wrong
  17. Jul 26, 2024 at 7:49 AM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    The only thing I really noticed was less throttle sensitivity, slightly earlier shifts and made the AC unable to keep up with SC temps from May to September. No difference in gas mileage for my rural driving and even if it did the AC performance decrease would have made it unbearable to use.
  18. Jul 27, 2024 at 12:18 PM
    smileytn1
    smileytn1 New Member
    Can't tell much difference with eco and normal either just wist the ev part of the tranny would stay on a little longer off of the line
  19. Jul 28, 2024 at 5:51 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I notice the difference between Eco and Normal, just like I notice the difference between Normal and Sport.
  20. Jul 28, 2024 at 6:13 AM
    HulkHog
    HulkHog New Member
    2024 Limited Nightshade - 3” dealer lift w/ 20 in. wheels; Nitto RidgeGrappler 35x12.50R20LT
    35s here too, what mode you use for daily driving?
  21. Jul 29, 2024 at 11:40 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    Gretta Thunberg breathes seductively on Toyota's speakers (replaces the v8 sound)
    CringyDad likes this.
  22. Jul 29, 2024 at 4:59 PM
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    :crapstorm::lalala:
  23. Jul 29, 2024 at 7:18 PM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    Puts more stress on your rods lol
  24. Jul 30, 2024 at 2:47 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Allows engine to progress through gears at lower rpms to keep fuel consumption down.
  25. Jul 31, 2024 at 2:21 PM
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    Normal mode
  26. Jul 31, 2024 at 2:56 PM
    SD Surfer
    Bruce
    So Cal
    Sounds like they should probably rename it Emo.
    22whatwedo likes this.
  27. Jul 31, 2024 at 3:00 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    starts to imitate the responsiveness of a BabyMax.
