What engine oil/filter combo are you guys using?
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Mar 13, 2020.
  1. Mar 13, 2020 at 1:58 PM
    Alltimehigh
    Alltimehigh [OP] New Member
    I've got 200k miles. I was thinking Mobile One Synthetic High Millage w/ a Toyota Filter.
    If theres already a thread can someone link for me? I havent been able to find one.
    Hi06silver likes this.
  2. Mar 13, 2020 at 1:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i run mobil extended performance with a toyota D3 filter.
    i see no need for the high mileage stuff in a toyota.
    193k on the ticker.
    01 and 02 taco get the same treatment.
    06 avalon and 06 corolla do too. But the corolla has about 800-850k on it these days
    Alltimehigh[OP] likes this.
  3. Mar 13, 2020 at 2:12 PM
    JQ3
    JQ3 2005 XSP rwd
    Currently, I buy the cheapest name brand synthetic blend from Walmart or Amazon Basics synthetic blend. I’m using a Toyota filter.
  4. Mar 13, 2020 at 2:17 PM
    Alltimehigh
    Whats the difference between High Millaege and Extended Performance?
  5. Mar 13, 2020 at 2:35 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Napa synthetic 5w-30 (made by valvoline)
    Napa Gold filter
    5K intervals
    turboser91 and Hoff like this.
  6. Mar 13, 2020 at 2:42 PM
    Professional Hand Model
    Hand Protectors
    Toyota YZZD-3 Filtro
    Mobil1 Synthetic High Mileage 5w-30
    2002 with 170k miles
  7. Mar 13, 2020 at 2:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Exactly this. With 168k.
  8. Mar 13, 2020 at 3:02 PM
    Hand Protectors
    High Mileage tends to have more additives to recondition old seals and boasts higher levels of zinc. Works to slow weeps.
    Extended performance has more PAO waxes for slipperiness. I’ve used this and it leaked past my seals causing weeps (cams and crank). Costs about 10% more.
    Mobil does makes an Extended Performance High Mileage which combines the two (15% more). I’ve done my own blending with 5 quarts HM with 1.5 quarts EP when I had extra to use up.
  9. Mar 13, 2020 at 3:22 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Pennzoil Ultra Platinum with a Fram Ultra Synthetic Filter.
    Neo258 likes this.
  10. Mar 13, 2020 at 3:28 PM
    empty_lord
    05 rollover special
    Extra additives.
    May help with leaks. But my 4.7 is leak free as well as the two Tacoma’s and Avalon. The corolla has a leaky head gasket (back Of the engine gets oil soaked below the head) No noticed change when I tried the high mileage mobil
  11. Mar 13, 2020 at 3:52 PM
    JQ3
    JQ3 2005 XSP rwd
    I didn't know that!!! I just thought "high mileage" and "synthetic blend" were one in the same. I guess they are except one has additives...good to know!
  12. Mar 13, 2020 at 3:58 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Toyota or Napa Gold filter then
    Three of these
    Plus 3 of these (for the cam buckets)
  13. Mar 13, 2020 at 4:07 PM
    Hand Protectors
    They all have additives which differ according to the type of service the engines require. Check out Mobils site and read up. When my cats go bad I’ll start running pure racing oils with huge amounts of zinc.
  14. Mar 13, 2020 at 4:09 PM
    empty_lord
    05 rollover special
    The zinc isn’t really needed. It’s not a flat tappet like the ol cam in block setups. It is a flat bucket, but forwhatever reason they don’t wear at all. The 01 taco didn’t get a valve adjustment till 275k. Only 1 valve was right, and the cams were looking like new!
    When I had the cams out of the tundra with 191k they also looked damn near new. And no valves were out of spec
    these Toyota bucket style engines run forever and are designed to need very little oil
    FrenchToasty likes this.
  15. Mar 13, 2020 at 5:03 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Have any of you ever run your mobil 1 over to blackstone labs for oil analysis after 5k + miles? If so, care to share?
    I generally run Mobil 1 Extended and Mobil 1 or Toyota filter but I haven't had a sample sent over to blackstone for the Tundra yet.
  16. Mar 13, 2020 at 5:15 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
  17. Mar 13, 2020 at 5:17 PM
    noahrexion
    Washington
    2005 4WD DC
    Awesome thanks, what kind of filter was that with and what type of driving do you normally do with it? Thanks for sharing!
  18. Mar 13, 2020 at 5:27 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Daily driver. A fairly balanced mix of short trips under 5 miles, highway, and towing.
    Fram Ultra Synthetic filter.
    I’ve been running the FRAM ultra synthetic filters since I read this guide a few years ago. Xtended guard is the old name that was replaced by Ultra Synthetic. The part numbers stayed the same.
    http://www.gmtruckcentral.com/articles/oilfilterstudy.html
    Neo258 likes this.
  19. Mar 13, 2020 at 6:48 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
  20. Mar 13, 2020 at 7:10 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Take it to dealer every 10K for oil and filter and follow the recommendations for other items. The million mile plus Tundra had exclusively (and documented) dealer service history including recommended oil changes with dealer oil and OEM filters. The engineers tore the motor down, documented with pictures and observed no substantial wear on any of the internals. Can’t do any better than that. And by that standard, your Tundra isn’t even a high mileage truck yet! It’s not even 1/4 of the way to broken in! :)
  21. Mar 13, 2020 at 7:16 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not Mobile 1. It was some cheap blend.
    tvpierce, speedtre and empty_lord like this.
  22. Mar 13, 2020 at 9:44 PM
    remington351
    2006 SR5 DoubleCab
    There are lots of debates and posting on zinc, ZDDP, and phosphorus at BITOG, Hemmings, and others so I will not kick the hornets next here. The modern SN rated oils only have 600-800 ppm of zinc. Our first gens were designed to operate with SJ rated oils. SJ rated oils have 1,000-1,200 ppm of zinc. I wasn't really searching for specific zinc oils, my Tundra is a weekend/vacation truck, only 6k-8k miles per year. I didn't want to run a synthetic 12-18 months, nor did I want to be dumping a synthetic into the drain pan every 6 months either. So this seemed like a best of both solution.
    empty_lord[QUOTED] likes this.
  23. Mar 13, 2020 at 9:45 PM
    empty_lord
    05 rollover special
    nothing wrong with that.
  24. Mar 13, 2020 at 10:25 PM
    HbbTundra08
    HbbTundra08 Epstein Didn't Kill Himself
    Brad
    2008 Toyota Tundra Crewmax SR5 2wd 5.7L
    TAC Stainless Steel Bull Bar RCI Steel Engine Skid Plate Two Stainless Steel 100w KC Daylighters Black Husky Weatherbeater Floor Liners front and rear. Kenwood Media System with Rear License plate backup camera integrated.
    Mobil 1 Oil Filter M1C-453
    Mobil 1 Full Synthetic High Mileage 0W-20 (5W-20 has also been used in the past since my 08 Tundra allows for either weight, I almost always run 0W-20 now though)
    Might switch to the Toyota filter but Mobil 1 filters have been on this truck since about 80k miles and they've given me zero issues over the years.
    My Tundra is at 222k+ miles so far and I'll be doing an oil change again here within the next couple months.
    I plan to send off a sample for a Blackstone Laboratories analysis, although it will be at about a 10,000 mile oil change interval. I'll post once I get it back.
    Neo258 likes this.
  25. Mar 15, 2020 at 8:41 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    In many instances I would agree with dealer service but I wouldn't go dealer for oil. Many dealerships buy oil in bulk from a local refinery. That oil can be different from this little tanker to the next.
    I have started using Liquimoly oil with a OEM filter, cerratec additive every 4th oil change. My engine has been a lot smoother
  26. Mar 15, 2020 at 9:05 AM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    Amsoil oil and TRD filter.
    41bigdawg and HbbTundra08 like this.
  27. Mar 15, 2020 at 9:23 AM
    SouthPaw
    2000 Limited 4x4 AC
    I think next oil change, I’ll probably swap to OEM filters since they are about the same price as the Napa ones I’m getting. Kind of ‘why not’ thing.
    I have and do love Rotella and they recently came out with a 5w-30 gas motor specstfic synthetic oil that seems attractive.
    https://www.amazon.com/dp/B07MSQ6TP2/ref=cm_sw_r_cp_api_i_LuLBEbX87FB45
    Only reason I use Napa is because we get it in bulk at work so it’s available but I’m still considering switching to Rotella. They make some damn good oil and I use it in my bikes, trucks or anything else it that may or may not be applicable.
  28. Mar 15, 2020 at 11:02 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    I’m the first one to say I used to use crazy expensive oils in the past. Royal Purple specifically. I also used synthetic element filters. But the fact remains, and was pointed out many times, no one has produced a Blackstone (or other) report that the 10K interval on factory spec (dealer) oil and OEM filters isn’t just good enough, it’s a conservative interval and the TBN of the oil has always been fine in all the Blackstone analyses. So sure you can change it more frequently, use different oil, etc but it isn’t any better for the motor based on the actual million mile Tundra engine tear down... all of the internals were perfect using only dealer services and recommended intervals as well
    As dealer lubricants and OEM filters.
    JQ3 and HbbTundra08 like this.
  29. Mar 15, 2020 at 5:24 PM
    skeeter1949
    skeeter1949 New Member
    Cecil
    2014 TSS 4WD
    TRD Exhaust, K&N Filter
    I use Amsoil 5W-30 Signature series synthetic, with the Amsoil filter, or a Napa Gold filter. I have used Amsoil in all my vehicles for almost 30 years.
    coldcanuk likes this.
  30. Mar 16, 2020 at 9:25 AM
    jamess28
    jamess28 New Member
    Tulsa, OK
    2005 DC SR5 TRD Off-road 4x4
    K&N oil filter
    Change every 7.5k
    2005 4.7 with 112k
