What Fuse is the headlight Fuse?
Discussion in '3rd Gen Tundras (2022+)' started by DMac808, Nov 9, 2022.
  1. Nov 9, 2022 at 6:12 PM
    DMac808
    DMac808 [OP] New Member
    2022 Lunar Rock Tundra TRD Sport 4x4
    I just picked up and installed a YotaLED kit and they suggest hooking the piggy back fuse into the INJ slot, but I don’t like the grill LEDs on constantly. I looked on the fuse box cover and couldn’t figure out which fuse was the Headlight fuse. Also searched the forum and haven’t had any luck. If anyone has wired their LEDs to the headlight fuse and can point out which slot it is I would greatly appreciate it. Thank you in advance!
  2. Nov 9, 2022 at 6:38 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I would assume you have RH/RL/LH/LL fuses. Those are your headlights L is low beam H is high beam.
    But, instead of adding a fuse to the headlights, I'd use the add a fuse on the towing tail circuit.
    Taco-Spike likes this.
  3. Nov 9, 2022 at 6:45 PM
    DMac808
    Thank you @Windsor, I’ll try plugging in to that fuse!
  4. Nov 9, 2022 at 6:48 PM
    Windsor
    Homeless in Oregon
    Some.
    Also, make sure you check which side of the circuit has power and which side is load. The side of the add a fuse with the wire goes on the load side of the circuit.
  5. Nov 9, 2022 at 6:51 PM
    Taco-Spike
    Two Trucks
    Also check tail light fuse. Activates when parking lights are activated before headlights. Just another option of function if desired
    Windsor likes this.
  6. Nov 9, 2022 at 8:25 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Can you let me know what you find out?
  7. Jul 26, 2023 at 6:40 PM
    jmcontracting1
    jmcontracting1 New Member
    New Jersey
    2022 Tundra SR5
    Did any of you guys figure this out?
  8. Jul 26, 2023 at 11:00 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  9. Oct 12, 2024 at 7:39 PM
    Mr_Tundra_2022
    Mr_Tundra_2022 Mr.Tundra2.0
    Shawn
    Lake Elsinore Ca
    2024 Tundra Limited TRD
    ICON CDEV 3.0 Full Billet Suspension, CBI Rear Bumper, CBI Full Skid, RCI Gas and Rear Diff Skid. Prinsu Roofrack. Baja Designs all around front, back sides and bottom, ADD Front Bumper. Warn 12-S Winch
  10. Oct 12, 2024 at 7:49 PM
    Mr_Tundra_2022
    Shawn
    Lake Elsinore Ca
    Hey Nick since there’s no fuse cause of Can-Bus config now. Would you know how that affects current draw by chance. I have some BD S2 Sports running in place of my OEM fogs with NP as amp draw is low .9 per and have 2 . However I’m considering adding some BD squadron’s to the circuit by simply adding a splitter where OEM wiring plugs into fog. My concern is total current draw with the 2 added lights. BD squadrons sports only draw 2.1amp each, adding 2 I’m sure it’s fine but being techy I wonder what total amp draw limit on that circuit would be. I’d be at 6 amps. 3 per side IG @mr.tundra2.0
  11. Oct 25, 2024 at 10:04 PM
    gillty1
    gillty1 New Member
    Reggie
    2024 Blue Print Tundra
    Did that work??
  12. Oct 26, 2024 at 12:12 AM
    Mr_Tundra_2022
    Shawn
    Lake Elsinore Ca
    Well, since i was inquiring as I was going to add 2 more lights to my fog light set up. I was curious if I could add some BD squadron sports or stick to the S2’s. Since BD kit puts 4 S2’s on fog circuit and I only currently have 2. I decided to go with 2 S2 SAE’s. I didn’t need more light really just didn’t want empty corner bays in a new bumper. Installing Addictive Desert Designs Stealth Fighter Bumper. I’m Putting in BD 40 inch ONX6+ then the corners will have the 2 new S2 amber SAE’s wired to fog circuit. Makes sense? So in fog bay I have 4 S2’s, 2 clear S2 Pros to a BD switch in dash, 2 S2 clear sports to OEM Fog switch then corner bumper slots 2 S2 SAE’s amber to OEM Fog as well. Install happening in 2-3 weeks. Check it out at IG @mr.tundra2.0. Tell me it’s you. Installed ICON CDEV full suspension as well.
    Baja Designs likes this.
  13. Oct 26, 2024 at 12:17 AM
    Mr_Tundra_2022
    Shawn
    Lake Elsinore Ca
  14. Dec 13, 2024 at 12:13 PM
    slcsez2000
    slcsez2000 New Member
    Just FYI I have 2024 SR5
    ****Not the premium LED headlights****
    I just tapped into the green wire on the headlights for my TRD Pro grill swap for the amber grill marker lights.
    don’t think you can do this with the Premium LED headlights cause of the CanBus garbage.
    Marker lights come on and off when I turn on the lights or DTRL and do NOT stay on all the time like if I fused into the trailer lights fuse.
    Hope this helps someone.
