What happens if you don't buff off the wax?
Discussion in 'Detailing' started by Retired...finally, Aug 13, 2022.
  1. Aug 13, 2022 at 5:49 AM
    Retired...finally
    Retired...finally [OP] Utilizing that doctorate of procrastinatory arts
    Rather unusual question but I have my reason for asking. This is about protecting the fiberglass roof of a travel trailer from stains etc. Since most TT roofs aren't anywhere close to being clean having a buffed out gloss isn't my priority but protection from the elements is.
    So, can I just do a good cleaning, put on a good thick coat of wax and leave it as is?
    Asking of a lazy friend.
    bulldog93 and Mr Badwrench like this.
  2. Aug 13, 2022 at 6:08 AM
    Taco-Spike
    Two Trucks
    Interesting
    it would just stay in the haze / cloudy state?
    Would the access wax harden to a rough surface?
  3. Aug 13, 2022 at 6:13 AM
    Retired...finally
    I assume the first point to be a given but since who looks up there I don't much care. Just trying to figure out any real negative points to doing such.
    Taco-Spike[QUOTED] likes this.
  4. Aug 13, 2022 at 6:34 AM
    Mr Badwrench
    Mr Badwrench New Member
    Disclaimer* I'm no chemical engineer.
    I don't see how it could hurt anything. All you're really doing is removing excess when you buff it off. I've missed spots after applying paste wax and not caught on to it for weeks and I've never noticed any adverse affects.
  5. Aug 13, 2022 at 7:02 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    No chemical engineer here either, but wax is just another layer of protection for the paint. Clear coat is a layer, wax is a layer, ceramic coating is a layer. What does it matter if one layer is a little thicker and not smoothed out?
  6. Aug 13, 2022 at 7:04 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I disagree, ive seen this happen and it damages the finish. Over time that stuff will etch the finish.
    It hardens and if left a while can be really hard/impossibe to remove, to the point where you will need to cut/polish to try and get it off. Having that sit on the paint will also attract contaminants, leave streaks. You are NOT getting additional protection leaving it on thick and unbuffed.
    Follow the instructions for the product you are using. For additional protection and longer lasting results, top coat with your favorite product like Bead Maker or something similar. A good coat of wax and top of beadmaker keeps my black truck looking good and protected for 4 months. So do it right 2-3 times a year and you will be happy you did.
  7. Aug 13, 2022 at 7:06 AM
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    If it is just for a fiberglass roof youre fine. I wouldnt make this a practice on painted or clearcoated surfaces though. The longer it sits, the more dust it is going to collect. No real good way to remove dust from wax like that so you would inevitably end up having to wipe or buff it into the paint to remove it, leading to scratches.
  8. Aug 13, 2022 at 7:15 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (current)
    It bakes on and becomes 3x as much of a pain to remove.
    Edit: it probably collects dirt as well.
    Sierradevil likes this.
  9. Aug 13, 2022 at 7:20 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Taco-Spike and ColoradoTJ like this.
  10. Aug 13, 2022 at 7:36 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
  11. Aug 13, 2022 at 8:04 AM
    Retired...finally
    Very good point about holding dirt in. As it is now I'm up a ladder at least 2x a year with Dawn and a long handled microfiber head scrubbing all the mother nature stain/debris off. After that fiasco the sides, front and back get waxed. Taking a break from doing that right now, as a matter of fact.
    I'm trying to avoid getting up on the roof if at all possible. Plus after being up there for an hour scooting around on my bum gives me concern about being able to get back up and down the ladder.
    Roctane84[QUOTED] likes this.
  12. Aug 13, 2022 at 8:13 AM
    Roctane84
    Louisiana
    As a roofer, albeit nothing to do with RV roofs, I would recommend a silicone coating. After prepping, cleaning, and pressure washing the surface, it can be rolled / brushed on and will last you years. If it gets to needing an additional coat 8 or 10 years from now, simply clean and prep the existing surface and roll on another layer (silicone sticks to silicone even though nothing else will).
    It will likely cost you more than anything else, maybe upwards of $1000 in material depending on the size of your RV, but will save you tons of time. I used some leftover GACO roof on sections of my 5th wheel. I never rinsed it off after but occasionally took it through the Blue Beacon 18wheeler/ Truck wash and had them spray it off.
  13. Aug 13, 2022 at 8:38 AM
    Retired...finally
    Would I have a problem getting any type of roof sealer to stick? There's currently a flowing type of sealant liberally applied around everything up there. After seeing how thick it is I can imagine it will expand and contract causing leaks. That's an expense I'm not looking forward too. Get this, the manufacturer recommends all sealant being replaced once a year. From clearance lights to roof vents. You'll never see that on their sales brochures.
  14. Aug 13, 2022 at 9:04 AM
    Rubberdown
    I would take that thing to line-x and have it sprayed. Never have another leak and don’t have to worry about cleaning it. You could even have it done in white or silver or something to reflect the heat.
    Retired...finally[OP] likes this.
  15. Aug 13, 2022 at 9:05 AM
    Roctane84
    Louisiana
    Without seeing what it is I cant say. Generally when we apply it on a standard flat roof, mod-bit/ granulated asphalt substrate, we apply a brush grade silicone with a fabric wrap around all penetrations like vents, AC platforms, skylights, etc.
  16. Aug 13, 2022 at 9:08 AM
    Roctane84
    Louisiana
  17. Aug 13, 2022 at 7:14 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That all makes sense. Don't pay attention to what I said.
  18. Aug 13, 2022 at 7:26 PM
    Why not just use a great ceramic product to protect the paint? Or PPF + ceramic. Be a lot easier to wash while protecting ur paint
  19. Aug 14, 2022 at 5:01 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Yep - and no more waxing.
    T-Rex266[QUOTED] likes this.
  20. Aug 14, 2022 at 5:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    NuFinish
    I wax every memorial day.
    I miss spot....they wipe right off weeks later.
    I bead water all year.
    frichco228 and T-Rex266[QUOTED] like this.
