What is the sweet spot for tire pressure on a 295/70 R18 as a daily.
Discussion in 'Wheels & Tires' started by JALBA, May 11, 2024.
  1. May 11, 2024 at 2:40 PM
    JALBA
    JALBA [OP] New Member
    I am running 39psi for daily city/highway. Is tis too much? benefit of higher psi?
  2. May 11, 2024 at 6:33 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I’ve been at 40 but am going to drop to 37 and try that. Seems harsh now. But am pulling off 19.5 mpg with a recent 300 mile trip. That’s pretty good for 295’s on an 4x4 and a lift.
  3. May 11, 2024 at 8:23 PM
    JALBA
    40 psi and 19.5 mpg. That's pretty good. I have 39 psi and averaging 15mpg with hills. I might try bumping it up to 40psi.
    Retired...finally likes this.
  4. May 12, 2024 at 9:09 AM
    carbinefreak
    carbinefreak New Member
    I initially ran 35PSI and it was over 2mpg difference to running 40psi now. With 40 I get close to the stock fuel milage but the ride is a lot rougher on the dirt.
    JALBA[OP] likes this.
  5. May 12, 2024 at 1:14 PM
    JALBA
    I really don’t off road so Ill definitely try 40psi
  6. May 13, 2024 at 9:39 AM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    onroad LT 10ply no hauling - 45, Tundras come with P tires if you upgrade to LT and you do the math itll end up somewhere between 45-51 again depending on your vehicle load and trailer load
  7. May 13, 2024 at 9:39 AM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
  8. May 13, 2024 at 10:11 AM
    carbinefreak
  9. May 13, 2024 at 2:30 PM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    if you offroad air down for more rubber contact, drive with aired down tires lose 2-4mpg, for the LT's run more air in them to keep mpg's better, drive with 35psi for 1k mi and drive with 45-50psi 1k miles see if you see a significant difference
  10. May 14, 2024 at 6:31 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    This is a great tool for getting air pressure correct when switching from stock tires
  11. May 14, 2024 at 6:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    LT load E.
    Back is OK: 45 PSI
    Back hurts: 30 PSI
    Gravel road: 28 PSI or less
    Log road: 25 PSI or less
    Deep snow: 14 PSI or less
    ZPhilip and bulldog93 like this.
  12. Nov 30, 2024 at 1:36 PM
    Bigbadpoppa
    Bigbadpoppa New Member
    I'd like to hear more opinions for LT tires. I've also upgraded to 295/70/18 LT recently.
    My specs so far for LT tires:
    Daily Driving (no load)
    37 Front, 34 Rear
    • might drop my PSI even a tad more, curious to see what other people are running, thinking of even going down to 30 for rear when i'm not carrying a load.
    • All i care is maximum contact patch, don't care about longevity of tires. Gotta pay to play is my motto so I want the safest pressures.
    Towing?
    • I got a 3000lb loaded trailer that I tow periodically (maybe a tongue wait of like 300?), what are the recommendations?
    • I don't care about longevity of tires, but rather what is the safest and highest contact patch is what matters to me the most.
    • 42 all round?
    Hard to do a chalk test right now, it's raining every day where I am and I'm not going to tow my trailer around to find an under cover area in the middle of the night.
