What is this suspension on my tundra?
Discussion in 'Suspension' started by Boxerdog, May 16, 2023.
  1. May 16, 2023 at 9:12 PM
    Boxerdog
    Boxerdog [OP] New Member
    I bought a 2015 tundra back in the fall and haven’t done much with it. It has 20 “ wheels with 33 inch tires and appears to have a leveling kit. I did however purchase it from a Toyota dealership and I do not have any information about what was done to the suspension.
    Any idea of what’s on my tundra?
  2. May 16, 2023 at 9:15 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Big spacer lift
  3. May 16, 2023 at 9:25 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra Cement DC
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Looks like everything is stock except for a large strut spacer lift, which is easy to remove and usually makes the ride pretty rough.
  4. May 17, 2023 at 8:05 AM
    Boxerdog
    Can I just measure the spacer? Looks like a 3 inch?
    I am thinking about possibly doing a fox coil over ( or another brand ) and have done some searches here on them but I would like to keep the same height of the truck. What are your suggestions ? Thanks
  5. May 17, 2023 at 8:19 AM
    alb1k
    Left Coast
    It's good
    I'm running a first gen so I don't know that truck, but I would highly recommend Fox. I think their coilovers will get you close to the height or at least as close as anyone. You could check King as well. I think the resi adjustable versions are worth it if you are going to run it off street. A little bit of rake is nice if you ever put anything in/on the bed.
  6. May 17, 2023 at 6:39 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Eibach stage 2 kit, run it at 2” so it sits like a stock Trd pro
    Mfanatic22 likes this.
  7. May 17, 2023 at 8:49 PM
    shmellmopwho
    shmellmopwho New Member Vendor
    Ryan
    Lomita CA
    Almost any actually suspension lift that you switch to is going to ride much nicer than the spacer lift.
    More budget friendly would be Bilstein 6112’s up front.
    Fox or King more expensive obviously but great quality.
    Bilstein has circlip height adjustments whereas the King or Fox has a little bit more fine tuning in height with its spring collar
    Fox or King are pretty tunable and they’re rebuildable which is great
    Regardless, you’ll feel a night and day different over the spacers!
    mista_g likes this.
  8. May 18, 2023 at 4:16 AM
    The spacers are not a 1 to 1 ratio. A 2 inch spacer will give you close to 3 inches in the front. That particular spacer looks like the ReadyLift and should be 2 inches thick. Are there any blocks in the rear?
  9. May 18, 2023 at 9:37 AM
    Boxerdog
    Snapped these quickly before work
  10. May 18, 2023 at 9:43 AM
    Boxerdog
  11. May 18, 2023 at 9:51 AM
    From what I can tell, it doesn't look like there are any blocks in the rear. It would look like this under the leaf spring.
  12. May 18, 2023 at 9:56 AM
    alb1k
    Left Coast
    It's good
    I agree, no blocks. This should be easy.
  13. May 18, 2023 at 11:01 AM
    Boxerdog
    Thanks everyone for the help … I will take better pictures this afternoon
