What Noise Is This? Creeky Ass Bed...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jun 8, 2019.
  1. Jun 8, 2019 at 5:43 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Take a listen, my bed (I think) is making all sorts of noises. Anyone know what this is? My setup in the rear are Bilstein 5160’s with 1” shackles.
    https://youtu.be/D54cKw1kuXo
  2. Jun 8, 2019 at 5:46 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My gen 2 tailgate has made a TON of noise since day one. Putting a tonneau cover on shut it up.
  3. Jun 8, 2019 at 6:11 PM
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    Amp power step running boards installed on your truck by chance?
  4. Jun 8, 2019 at 6:13 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Nope. Just not super tight on bumpy roads
  5. Jun 8, 2019 at 6:13 PM
    Silv333
    NJ-NC-MD-NC
    Negative
  6. Jun 8, 2019 at 6:20 PM
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    They make the exact same noise on my truck.
    They rub the frame when retracted.
  7. Jun 8, 2019 at 6:31 PM
    TheBeast The Beach
    get some WD40 silicon spray and spray leaf pack/ shackles and the bed isolators (between frame and bed, 4 spots)
    Also check your bed bolts are tight.
  8. Jun 8, 2019 at 7:22 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It’s the new shackles. They are rubbing a bed bolt underneath. You need to grind the side of the threads down to clear the shackle. This is very common. Mine did the same thing until I grinded the bolt And relubed the shit out of the bushings at the frame. And I suggest you replace the factory leaf spring bushings with polys. The factory will eat up the new shackles. Plus the polys will make it ride even better.
  9. Jun 8, 2019 at 7:36 PM
    Silv333
    NJ-NC-MD-NC
    Mind sending me a few pics of exactly where I need to grind? Also, any recommendations for poly bushings?
  10. Jun 8, 2019 at 7:52 PM
    Danman34
    Danman34 New Member
    Danny
    I used the ones that came with my toytec shackles. I believe they are Energy Suspension bushings.
  11. Jun 8, 2019 at 8:07 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    I had a noise just like that on my 2017 Platinum and it turned out to be the spring on the assembly that holds the spare tire in place -- like the one shown here (not mine). I greased it a bit and haven't heard the noise since.
    Dave
    Hbjeff likes this.
  12. Jul 5, 2019 at 9:19 AM
    Danman34
    Danman34 New Member
    Danny
    Any update?
  13. Jul 5, 2019 at 10:09 AM
    Silv333
    NJ-NC-MD-NC
    THIS!! You hit the nail on the head, trimmed the threads off those bolts and no more noises. THANKS!
    Tundra_361 likes this.
  14. Jul 5, 2019 at 10:58 AM
    Danman34
    Danman34 New Member
    Danny
    Good to hear! Glad it worked out.
