What oil filter socket fits OEM?
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Nov 2, 2022.
  1. Nov 2, 2022 at 7:42 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I buy only the Toyota brand oil filters. I can’t find the correct socket to loosen the filter. I had one, it’s too loose, bought a cast aluminum one, again too loose.
    Where can a brother get the proper fitting filter wrench?
    I have strap wrench, but prefer the correct filter wrench.
  2. Nov 2, 2022 at 7:49 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    edit, just realized this is 1st gen forum :facepalm:
    artsr2002, Jack McCarthy and bmf4069 like this.
  3. Nov 2, 2022 at 7:53 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Your putting it on to tight if you need a wrench to take it off
  4. Nov 2, 2022 at 7:56 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I use channel locks :anonymous:
    805Tundra, bmf4069 and shifty` like this.
  5. Nov 2, 2022 at 7:57 AM
    Yeah, I was about to say, if you're using a wrench, you're doing something wrong.
    Slap a little oil on the seal it and torque it down by hand. You don't need any more than that. These aren't canister filters where you need a special wrench. My wife's '12 Highlander used those, it felt so wrong wrenching the filter housing on and off.
    des2mtn likes this.
  6. Nov 2, 2022 at 7:59 AM
    A pair of these?
  7. Nov 2, 2022 at 8:05 AM
    des2mtn
    SW
    Tonto cover
    Nope, bigger lol and they're almost unnecessary. But I completely agree that you shouldn't need a special wrench. I tighten my filter just a bit more than I can do by hand.
  8. Nov 2, 2022 at 8:08 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Lube techs like those better because they can put the housing wrench on their impact and make sure it’s good and tight.
  9. Nov 2, 2022 at 8:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    shifty` likes this.
  10. Nov 3, 2022 at 3:19 PM
    Aerindel
    Aerindel New Member
    Montana
    Screwdriver and hammer.
    bmf4069 likes this.
  11. Nov 3, 2022 at 3:47 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    @bmf4069 Our resident enforcer would be proud of you for your self-realization. :)
  12. Nov 3, 2022 at 3:51 PM
    Jack McCarthy
    Bill
    North of Boston
    If the 2005 filter is the YZZD3 (same as 2002 filter), you can find one at Consumer Auto Parts if you have one near you. I don't know if there's a difference between the VVTI 4.7 V8 and the normal 4.7 V8.
    This is what I use for my 2002 V8 Tundra.
    CTA Tools - A254 - Cap-Type Oil Filter Wrench - 73mm x 14 Flute — CTA Manufacturing
    They may carry one for your filter if you know the size.
  13. Nov 3, 2022 at 3:53 PM
    Jack McCarthy
    Bill
    North of Boston
    Hasn't caused me a problem yet. Although I just snug it an extra 1/4 turn with the wrench after being hand tight.
  14. Nov 3, 2022 at 5:52 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I’m not cranking it down too tight. To me it’s like getting the correct
    Wrench vs using an adjustable wrench.
    Tundra2 likes this.
  15. Nov 3, 2022 at 6:02 PM
    Aerindel
    Aerindel New Member
    Montana
    I always put it on hand tight....I always need to hammer a screwdriver through it to take it off, go figure.
  16. Nov 3, 2022 at 6:14 PM
    lunchmeat
    lunchmeat New Member
    2018 Tundra
    A snug filter is better than a loose filter when it is time for an oil change. I have had the same experience over the years with all my vehicles…
  17. Nov 3, 2022 at 6:36 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I go 3/4 turn past the point where the "O" ring just touches the machined surface. After 5k miles, if it's a bit too tight to spin off by hand, or too hot, I use a band type wrench to make life easier. Take a filter to an auto parts store to get the proper size. The end mount type that match up with the flats on the filter slips too much.
    BubbaW likes this.
  18. Nov 3, 2022 at 6:39 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Just changed my oil today. Channel locks to get the old one off. Hand tightened the new one on.
  19. Nov 3, 2022 at 7:02 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
