What oil filter wrench do you use?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Mar 1, 2024.
  1. Mar 1, 2024 at 5:30 PM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    Been looking at oil filter wrenches online and of course there’s a bunch of choices. Is there any specific ones to stay away from? Or just make sure it’s one that fits the filter for the 5.7 on our trucks?
  2. Mar 1, 2024 at 5:41 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  3. Mar 1, 2024 at 5:42 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Yup Motiv
    AZBoatHauler and WILLINH like this.
  4. Mar 1, 2024 at 5:57 PM
    Rockanock
    Much appreciated!
  5. Mar 2, 2024 at 4:11 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    the dorman on seems to work fine. i prefer steel over aluminum
  6. Mar 5, 2024 at 5:19 AM
    Rockanock
    Bought the Motiv. It is very high quality and precisely made. I don’t get impressed too often but from the packaging to the finish on the part itself I was impressed. I was also very happy to see it’s made in the USA.
    bulldog93 likes this.
  7. Mar 5, 2024 at 5:30 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Motiv
    I am doing oil changes on my Tundra and 4Runner. The dealer had done the previous ones.
    The 4Runner was yesterday. The dealer had put the filter on way too tight.
    Was not coming off with the 3/8" connected method.
    I ended up putting a socket on the Motiv nut, and attached a 1/2 " Torque wrench to break the seal and get it going.
    Impressed with the Motiv.
  8. Mar 5, 2024 at 5:35 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Motiv kit for the win.
  9. Mar 5, 2024 at 6:22 AM
    bfunke
    South Carolina
    What was the breakaway torque reading you obtained.
  10. Mar 5, 2024 at 6:36 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I use the Motiv wrench with drain tool. Worked great on both the Tundra and my wife’s 4Runner. Only have the 4Runner now but it sure does make the job less messy combined with a Fumoto valve.
  11. Mar 5, 2024 at 6:39 AM
    borla123
    borla123 The Pits
    Ontario
    I can't say what torque the dealer had it at. When I got to the torque wrench I was into it way too long - pissed off, and was just trying to break the seal, gently. My torque wrench if I recall was last used to put on tires so the setting was alot higher. 25-30 ft/lbs
    When I installed the filter I hand tigtened and then another 1/4 turn with the 3/8 inserted in the motiv.
    edit
    @bfunke
    when I do the Tundra in a couple of weeks, it was the same dealer, so I will start with the torque wrench method this time at 10 ft lbs and go up. let u know.
  12. Mar 5, 2024 at 7:08 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  13. Mar 5, 2024 at 7:55 AM
    mustangr2
    mustangr2 New Member
    Motiv here
  14. Mar 5, 2024 at 8:35 AM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Another Motivx user here. I’ve removed the plastic filter housings several times without issue. My buddy got a cheap filter tool and has broken every stuck on plastic housing he’s tried to remove with it requiring him to get the cheap parts store metal housings. Definitely worth spending a little more for a quality tools.
  15. Mar 5, 2024 at 8:42 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    MOTIV all the way, The dealer had done the oil change prior to me and I broke the plastic oil filter cap getting it off. Used the steel one that grabbed the "ears" on the filter cap and snapped them right off. The cap was on extremely tight, pretty much destroyed the filter cap getting it off. Fortunately I had planned on switching over the Aluminum one so I had that one hand. Made a heck of a mess!!
  16. Mar 5, 2024 at 9:20 AM
    Nikwho
    Nikwho New Member
    Nik
    Black 2015 Limited TRD Tundra
    Yes
    I just crawled out from under my Tundra, completing an oil change. I have a cheap chrome one off of Amazon. Works just fine. It was $10-$20. I know that some have had issues with these stripping their cap. I remember having some issue getting the cap off the very first time I did my oil change, but ever since then, it's been a breeze! I think the dealership techs run those caps down with an impacct driver drill, in fear that they'll come off. I would bet that one would never vibrate loose, if the cap were hand tight, with the o-ring that is in there. They do NOT have to be super tight!
    Also, fun fact, I had an empty quart bottle of idemitsu ATF fluid laying around, from a drain and fill of ATF yesterday. I cut the bottom of the bottle off, and the top of it literally threaded into the oil fill cap threads! So, it was like a free funnel that locks into place! Game changer over my old trans funnel buddy funnel that I typically use and have to hold! It threads into place and is super solid, freeing up my second hand when pouring a big 5 quart bottle of oil in. Just thought others here might be interested.
    equin, Droptarotter and Leo's first like this.
  17. Mar 5, 2024 at 11:10 AM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
  18. Mar 5, 2024 at 12:40 PM
    Dillusion
    Dillusion New Member
    Kyle
    2019 SR5
    Motiv here also.
  19. Mar 5, 2024 at 12:44 PM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    I ended up getting the MotivX kit. It great
  20. Mar 5, 2024 at 12:57 PM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    Motiv - game changer.
  21. Mar 5, 2024 at 6:18 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Subscribed....
  22. Mar 6, 2024 at 6:32 AM
    TexasWildman
    TexasWildman New Member
    RH
    2017 Quicksand Tundra
    Yassums. Motiv for me too either. And it looks great. Great piece of kit.
  23. Mar 7, 2024 at 4:47 PM
    clarks
    clarks New Member
    21 Tundra TRD Sport
    I bought the Motiv because I heard good things about it. Great quality. I plan on doing most oil changes for the next 10 yrs and wanted quality.
    The last oil change I had the dealer do before my 2 yr free service was up, they cranked on the bottom bolt of the filter soo tight, that I had to break the plastic cartridge cage to remove it. I had previously read about that issue and had a spare metal one ready to go. It seems over the last couple yrs, every time I have the dealer do basic stuff including oil changes, they mess something up. The oil change before, they decided to save time and not mount the lower bumper skirt to the skid plate so it was flapping lose.
    equin likes this.
