What the heck is this stain on our RAV4 paint?
Discussion in 'Detailing' started by BravoDeltaRomeo, May 16, 2020.
  1. May 16, 2020 at 8:11 AM
    BravoDeltaRomeo
    BravoDeltaRomeo [OP] Old Man Little Blue Finger
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My wife's car, parked beside mine, is getting stains. She parks in a parkade at work and the tree in our driveway spans both our vehicles
    It turns white, you can feel it with your fingernails, kind of rough to the touch. It fades when wet, then comes back after washed with soap and water.
    It has only affected her Rav and I've never seen it on our vehicles parked in the same spot for the past 20y. Vehicle is under 6months old and is the Red Metallic paint.
    Is it bird crap?
    How do I remove them, without paying an autobody shop?
    Roof:
    Side panel:IMG_20200516_100555.jpg
  2. May 16, 2020 at 8:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The first one looks like the result of bird shit eating the clear coat. Unfortunately. Have you tried cleaning it yet? Is it permanent?
    I've had bird shit ruin the paint on previous vehicles I owned. I always tell my wife to never park under a tree if you can avoid it.
    15whtrd and BravoDeltaRomeo[OP] like this.
  3. May 16, 2020 at 8:35 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Have you tried goofoff? I used it to remove tar of the paint..worked well for me.
    BravoDeltaRomeo[OP] likes this.
  4. May 16, 2020 at 8:46 AM
    P-Factor
    P-Factor New Member
    Looks like concrete efflorescence is dripping from a parking deck or her parkade at work?
    NUDRAT, Hoff, 15whtrd and 1 other person like this.
  5. May 16, 2020 at 8:54 AM
    saybng
    Gary
    Ventura CA
    Yikes!
  6. May 16, 2020 at 9:02 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    That's what I'm wondering. She parks in a different spot each time but it could be a building issue.
    I've wiped bird crap off and we have been here for 20y without issue.
    I have tried soap and water, wax, polish, googone, nothing seems to fix it. I was able to fingernail remove some, but it leaves micro scratches
  7. May 16, 2020 at 9:07 AM
    P-Factor
    P-Factor New Member
    I've also seen this happen when parking deck operators apply ice-melt or salt and it leches down on parked vehicles.
  8. May 16, 2020 at 9:09 AM
    P-Factor
    P-Factor New Member
    https://ask.metafilter.com/81338/Ho...kdrip-stain-from-my-cars-paint-and-windshield
  9. May 16, 2020 at 9:11 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would bet it is from the parking garage.
  10. May 16, 2020 at 9:16 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you've tried everything my next step would be a light coat of compound then wax. Just go east. I wouldn't put goof off on my paint personally. Just seems like a really harsh cleaner.
  11. May 16, 2020 at 9:51 AM
    15whtrd
    15whtrd Mr. Blonde
    It does look like it may have etched your clearcoat. Believe it or not I have really good luck with some cheap stuff called scratch out. Comes in a yellow bottle. I always follow with a more quality polish and wax if I get the stain out or scratches. You may need a more aggressive type polish if you don’t want to try scratch out. Also try clay bar.
  12. May 16, 2020 at 9:53 AM
    15whtrd
    15whtrd Mr. Blonde
    I’d also have your wife start checking out coworkers cars to see if they are having the same issue. If this is the case, the building may be responsible for having this issue with the vehicles addressed. Also doing something to keep it from happening in the future.A shot in the dark but worth a shot LOL.
  13. May 16, 2020 at 9:55 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Thanks everyone
    @15whtrd I will definitely have her ask the her coworkers. She is a nurse, the the parkade is likely backed provincially.
    I had a hunch it was more than just bird crap and maybe a chemical spill.
    I've gone ahead and ordered some polish compound, a speed bar (plastic type clay bar) and will see about correcting them shortly
    15whtrd likes this.
  14. May 16, 2020 at 10:00 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Being able to scratch it off indicates that it is a deposit on the surface of the clear coat, rather than the result of etching. I assume the microscratches are from the material and not your fingernail. I'm leaning toward the concrete efforescence theory, and that means the residue will likely have abrasives in it. Removal is probably best done gently and manually with compound. Once you get the residue off, plan for a thorough wash with dawn and water, then DA polish, and then apply some good sealant protection. The roof paint ain't looking too bright in general.
  15. May 16, 2020 at 10:12 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I'd wash it as best as I can then start with a clay bar before compound.
  16. May 16, 2020 at 10:22 AM
    P-Factor
    P-Factor New Member
    I would try this method on a not-so-noticeable area first. It sounds reasonable and not vary invasive...
    Steps to Remove the Limescale:
    1. Combine one part water with one part white vinegar in a spray bottle or bucket.
    2. Spray it onto the affected areas.
    3. Wipe the area with a clean, soft cloth.
    4. If using a bucket, moisten a cloth with the mixture and use it to wipe away the limescale.
    5. If the lime is not easily wiping away, moisten a cloth with the mixture and lay it over the area.
    6. Allow it to soak for 5-10 minutes.
    7. Remove the cloth and wipe the loosened lime away.
    8. Repeat as needed until all of the limescale is removed.
    9. The vinegar in the mixture will remove the wax that was originally on the car.
    10. Wash the car as usual once you are finished removing all of the lime.
    11. Apply a good quality wax to protect the finish.
  17. May 16, 2020 at 10:33 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    @JohnLakeman we live on a gravel road ...our cars never look clean :(
  18. May 16, 2020 at 12:41 PM
    JohnLakeman
    As for dirt, it's cleaner than mine are. My observation is that the roof already looks like it's lost factory gloss. The side panels are better, and that's to be expected. DA polish should bring the gloss back, but you'll need to get some protection on it. Today's paint isn't worth spit.
  19. May 16, 2020 at 1:25 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Gotcha, thanks.
    I have a few more supplies and wash mitts etc en route. I hope to wash both her Rav and my Tundra soon, then wax/polish them to get them protected and shiny.
  20. May 16, 2020 at 1:27 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Lots of info and help from everyone ..thanks so much guys and gals.
