What tire pressure for 33" Nitto Grapplers
Discussion in 'Wheels & Tires' started by TundraJunkie, Mar 16, 2017.
  1. Mar 16, 2017 at 3:15 PM
    TundraJunkie
    TundraJunkie [OP] New Member
    2008 Tundra TRD SR5
    I'm running 33" Nitto Grapplers on my 2008 Tundra. At what air pressure should I normally keep my tires. They seem to look low to me here lately. The guy at discount tire looked in my door jam and said I should keep them at the factory air pressure. I feel that's not correct since i'm not running factory tires. Can anyone help on this? Thanks in advance!
  2. Mar 16, 2017 at 3:18 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What load range?
    If D, 30-33 per the math. A lot of people dont feel "safe" that low.
    Otherwise do the chalk line test and see where your at and adjust from there.
  3. Mar 16, 2017 at 3:29 PM
    TundraJunkie
    2008 Tundra TRD SR5
    Yeah thats what the guy tried to tell me I should go with...30 for the front and 33 for the rear.
  4. Mar 16, 2017 at 3:29 PM
    TundraJunkie
    2008 Tundra TRD SR5
    My door recommends 30psi for the front and 33psi for the rear
  5. Mar 16, 2017 at 3:49 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    For example
    Specs on my tires,
    My 285/70/17 LR LR D Yokos
    3195lbs @ 65psi = 12780lbs at 65psi
    Truck weighs in maybe 5500lbs max
    5500lbs/12780lbs = .4304
    65psi x .43 = 28psi
    This gives you a rough estimate where to start. Then minor adjustments made from there.
    I usually ran 30-32 when the trucks dry.
    Higher pressure = higher MPGs BUT will wear the inside tread quicker due to the lessened contact patch/ballooning.
    As previously mentioned, you'll get a lot of different opinions on the matter.
    TundraJunkie[OP] and GNTundra like this.
  6. Mar 17, 2017 at 8:46 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    What about e rated tires with a max of 80 psi? Having issues with the trac. It gets better if I drop them down below 30 but it feels like driving a sponge. Had discount swap them out yesterday. I haven't tried airing down below 35 yet.
  7. Mar 17, 2017 at 8:55 PM
    What has not been mentioned.....what are you going to do with these tires?? Daily? Also, once you lose the OEM tires.. Throw out door jam specs. Just sayin.
    Law323 likes this.
  8. Mar 18, 2017 at 7:21 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I have toyo AT's (same company)
    LT tire- I run them at around 45-50. Perfect for hwy driving IMO. I'll air them down to about 40 and go from there when off-road.
    Start at 40 ish and make adjustments as needed until you find the right nbr.
    NewImprovedRon likes this.
  9. Mar 18, 2017 at 9:50 AM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    Do the chalk test.
    Tire folks originally put mine at 35. Looked, felt, drove soft. They can go up to 80 psi as well, so had no clue where to put them. Did the chalk test a few times, and ended up at 42 psi.
  10. Apr 4, 2017 at 2:29 PM
    TundraJunkie
    2008 Tundra TRD SR5
    These will be my daily driver tires and occasionally trail tires.
  11. Apr 4, 2017 at 3:29 PM
    TheBeast The Beach
    35 ish
    Black Wolf likes this.
