What's this #2
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Sep 8, 2023.
  1. Sep 8, 2023 at 2:13 PM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Hey welcome back to an episode of what's this! Lol jokes, I was just poking around and so happen to come across this super greasy part, not sure what it is( AC?) . Also my AC doesn't work. So:
    What's this greasy part, and where could the grease/ oil be coming from? Timing belt cover gasket? Valve cover gasket?
  2. Sep 8, 2023 at 2:28 PM
    Aaol1
    Sam
    And I realize after a bit more research that it's the power steering pump. Do you guys think it would be leaking or is it something else around there that's leaking? Hard to tell I imagine
  3. Sep 8, 2023 at 2:29 PM
    shifty` Pattern Against User
    Should be the power steering pump.
    It appears to me the oil covering it is coming from the valve cover, although it could be from the cam seals, which are a known leak source on the '05-'06 models. Mine were leaking also, driver's side, and a full bottle of ATP AT-205 resolved all leaks within 100 miles are so (there's a thread on it around here somewhere). I would NOT use any other additive products. ATP guarantees their product won't over-swell gaskets when used per the instructions, not many other "fix it" products will or do guarantee the same. I used the ATP product because lots of dudes with far more mechanical experience than me swear by it, especially for rear main seal leaks.
    The Black Mamba and DarkMint like this.
  4. Sep 8, 2023 at 2:31 PM
    Aaol1
    Sam
    Oh interesting! I didn't expect a recommendation for an additive I know it's looked down on. I wonder how much more $$$ it would be to tack on valve cover / cam seals when already paying for a timing belt job. Do you think it's alot more time for them to do it? Or like just an hour or 2 more?
  5. Sep 8, 2023 at 2:33 PM
    Outlining the valve cover in yellow here. Notice most of the oil is south of here.
    I'm curious where the oil running down the orange line is coming from.
    DarkMint likes this.
  6. Sep 8, 2023 at 2:33 PM
    Additives are normally shit, and I would never recommend them. Like, never ever.
    Cam seals, you'll probably be adding another $600-800 onto your bill. It's pretty intensive and should be done at same time as timing belt/water pump and valve covers. Lots of the same parts must come off or do come off.
  7. Sep 8, 2023 at 2:35 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Shifty you are a gem for 1st genners as always. Saving the ATP recco for future.
    shifty` likes this.
  8. Sep 8, 2023 at 2:36 PM
    Aaol1
    Sam
    Right, alright good to know. Thanks shifty, always appreciated
  9. Sep 8, 2023 at 2:41 PM
    No prob. Check this out. This is my truck. Cam seals were leaking on the driver's side, as was the valve cover at the front corner, by the oil dipstick. Does my "coating everything below this point" look familiar to you?
    https://www.tundras.com/threads/hey-whats-leaking-here-lower-timing-cover-valve-cover.100798/
    Oh, and the yellow line here is basically the edge of the valve cover, which is one of the two leaks. Check this picture and others in that thread ... and you can also see what AT-205 did to my truck. I am dry as a bone still, to this day. Saved myself hundreds in labor.
  10. Sep 8, 2023 at 2:44 PM
    Aaol1
    Sam
    That's awesome! Thanks for showing me. Yea I may just consider that. Still do timing belt for sure but may use the atp for the other stuff. What would be nice would be to fully clean it up, it's insanely gummed up it must have been leaking for a long time
  11. Sep 8, 2023 at 2:45 PM
    Aaol1
    Sam
    Don't.know if brake cleaner all over would help a bit
  12. Sep 8, 2023 at 3:02 PM
  13. Sep 8, 2023 at 3:07 PM
    Aaol1
    Sam
    Nice! May just take a look into this
  14. Sep 8, 2023 at 3:29 PM
    Aaol1
    Sam
    So if I understand correctly I can just pour it into oil or power steering? Do I have to remove some oil or power steering fluid first as to not overfill?
    @shifty`
  15. Sep 8, 2023 at 4:58 PM
    Jasons2006Tundra
    Jasons2006Tundra New Member
    2006 Tundra DC SR5 4wd 4.7 TRD
  16. Sep 8, 2023 at 5:18 PM
    Correct, directly in.
    Given how much oil you've been leaking, you may not even need to remove any from the crankcase, just pour one full bottle in there.
    For the power steering, same thing, you've been leaking, look at current level, add if it's a bit low.
    It'll help rejuvenate the seals and hopefully save you some coin.
  17. Sep 8, 2023 at 5:22 PM
    Aaol1
    Sam
    Kk that makes sense , thanks! I know it says one 8oz bottle treats 6qt, I could do some research, but off the top of your head do you know how much you used in your oil job? Any idea for power steering?
  18. Sep 8, 2023 at 5:30 PM
    Don't know OTOH for power steering. Crankcase holds 6.5, so one bottle basically is a half ounce shy of treating everything. I used one single bottle in the crankcase and it did the job for me.
  19. Sep 8, 2023 at 6:16 PM
    Aaol1
    Sam
    Cool sounds good!
  20. Sep 8, 2023 at 6:42 PM
    Owners manual willl have that info in the Specifications. If you need a copy of the manual theres a link in the “so you just bought …” sticky thread, near the svc manual link.
    Aaol1[QUOTED][OP] likes this.
