Wheel and Tire Weights
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Mar 14, 2023.
  1. Mar 14, 2023 at 3:32 PM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    Quick question as I am building my wheel and tire setup. 18” wheels with 35 by 12.5 tires. What do you think the limit is as far as weight goes for the combo per corner? Thanks.
  2. Mar 14, 2023 at 3:36 PM
    There not a limit on weights. If a tire doesn't balance, reindex it on the wheel and rebalance.
  3. Mar 14, 2023 at 3:44 PM
    AAA96
    What I meant was ideal for fuel economy/size. These wheels are 41lbs plus 75lbs for a tire. Any one know what a stock 18 with tire weighs for comparison?
  4. Mar 14, 2023 at 4:16 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    The factory wheels are 31lb each (TRD Off Road) or 27 lb each (BBS forged TRD Pro). I don't know about the other 18" OEM Tundra wheels.
    The stock Michelin tires are 41 lbs each. So you're looking at 72 lb for the stock tire on the stock TRD Off Road rim.
    Your truck is going to be noticeably more sluggish off the line, and you'll take a substantial MPG hit if you go to 116 lb per corner.
    I went from 72 lb per corner to 92 lb (forged BBS wheel @ 27 lb and 285/75R18 Duratrac @ 65 lb). I notice a bit of a loss of acceleration.
  5. Mar 14, 2023 at 4:57 PM
    Gotcha. As mention, your mpgs are about to take a big hit with that much weight.
  6. Mar 14, 2023 at 6:37 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Yes stock steel 18” is 38lbs, 31lbs alloy, 28lbs forged. 17” Rock warriors without the ring is 21lbs. FN BFDs 18” 22-24lbs. Most 18” wheels though are on the high 30s though due to having more bling on them/not forged.
    Then stock tires at size 255/70r18 is 38lbs while the 275 variant is 41lbs as stated above. So a normal SR5 was usually 76lbs a corner and higher trims low 70s.
    A jump to 116lbs a corner would feel like having half a pallet of concrete bags in the bed constantly. That’s why people will use lower weight wheels like FN BFD or BBS to offset some weight. Avoiding load E will keep the tire weight down, like there are 35s (315/70r17 for example) that are 60lbs, thus when paired with light wheels are very close to stock weight. Vehicles like the TRX and Bronco use new lightweight load D or C 35s to retain performance which are about 55lbs.
    Jettster, jachal and AggiePhil like this.
  7. Mar 14, 2023 at 6:41 PM
    AAA96
    very good insight. I am going to look to shave weight with the tires for sure as you mentioned. The wheels I am looking at now are about 34lbs. So adding a lighter weight 35” or 315 tire in the 60lbs would put me at 94ish lbs. that’s roughly 18-20lbs more per corner.
  8. Mar 14, 2023 at 6:45 PM
    Going to 35s you aren't going to get anything that resembles good fuel economy. Not just for the weight of the wheels/tires, but also because of the aerodynamics. If you mod anything related to wheels, tires, or suspension on the Tundra you will be paying for it at the pump.
    AggiePhil likes this.
  9. Mar 14, 2023 at 7:16 PM
    AAA96
    point taken. I did find the Nitto Terra grappler g2 tires that are 295/70/18 that are about 34.3” diameter. They weight 51lbs. With the fuel covert wheel that is 34lbs that comes to 85lbs total. Thoughts?
  10. Mar 14, 2023 at 7:29 PM
    Lighter will most likely be better, but if you want a rabbit hole you can look into the rolling resistance of tires. I've not gone down that rabbit hole, but it will have an impact as well.
  11. Mar 14, 2023 at 7:35 PM
    AAA96
    I read about rolling resistance on tire rack for a bit. Seems like the smaller/lighter the tire (less ply) the less rolling resistance it has. So this Terra grappler g2 should be a good fit since it is more of a highway tire that looks like an a/t tire.
  12. Mar 14, 2023 at 8:25 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    He'll be more sluggish because it's geared higher. The weight increase will contribute a little but not much.
    Mpg will depend on what he's taking off and putting on. Thick AT tread, beefy sidewalls, and weight will tend to make it worse, but... rolling resistance due to hysteresis is the biggest factor... and that is a crap shoot. My tires actually do better than the stock Bridgestones, which is great. Others that look and weigh about the same could do a lot worse.
  13. Mar 14, 2023 at 8:28 PM
    rruff
    rruff New Member
    I've spent some time researching that... and I used to test bicycle tires for rolling resistance. Hysteresis (the energy absorbed by the tire when it deforms) is the main factor, and can vary widely between tires that have the similar specs. Unfortunately no one tests truck tires for this. One of the better proxies when looking at similar tires is the speed rating. This is how fast the tire can go with a full load before it overheats... and they heat up because of hysteresis.
    These are 325/65r18 (fat 35s) and are D load, T speed rated, only 65 lbs... and I bet they get better MPG than any AT of similar size. I don't need tires yet, but since the ones I have are no longer made, I want to see some feedback on these. :D
    https://www.discounttire.com/buy-tires/goodyear-wrangler-territory-at/p/101610
    The photos are wrong BTW, this size looks like this:
    DIYDad and blenton like this.
  14. Mar 14, 2023 at 8:37 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The TSS 20" wheels weigh 41 lbs each
  15. Mar 15, 2023 at 12:58 AM
    blenton
    blenton New Member
    Interesting. I hadn't thought to try and gauge hysteresis by speed rating; I alway assumed that had to do with rubber compound and ply construction being able to deal with and/or dissipate the heat generated by speed. But you may be on to something.
    It is nice to see the advancements in tire tech over the last 10 or 15 years. I recall reading an article in an off-road magazine years ago about macro vs micro-keying on tread blocks. They used the example of an AT vs MT from the same tire MFG on some granite and slick rock, noting that the AT excelled at visually smoother rocks due to it's ability to micro-key with it's smaller sipes and grooves rather than the big clumsy paddles of the MT. Thinking an AT would do better than an MT in the rocks sounded like blasphemy at the time.
    I also happened across a similar article about siping and how it was formerly mostly used for winter tires to create more biting edges in the snow an ice, but that it is now being used by some MFG's to combat hysteresis. The article showed that allowing smaller tread blocks to deform by small amounts could create a better rolling resistance profile than larger tread blocks deforming the carcass. The smaller deformities allowed for a the heat to be dissipated by the tread, which was constantly exposed to the air, rather than by the carcass which seemed to hold the heat longer; as well, the smaller deformations created less heat overall due to the smaller deflection. I might have to look for the article but I think it was published in a print magazine - the kind that you held with your hands and fingers and never ran out of batteries.
  16. Mar 15, 2023 at 3:08 AM
    TundraClayDigger
    TundraClayDigger New Member
    2018 Crewmax Limited 4X4
    I have not had much luck with Goodyear tires but these Goodyear A/T tires look great. The lugs on them look perfect for digging through mud. I will check them out when I wear out the A/T tires I have on my Tundra now.
    rruff[QUOTED] likes this.
  17. Mar 15, 2023 at 9:23 AM
    rruff
    rruff New Member
    The Territory AT and MT (MT stands for maximum traction, not "mud terrain") are pretty new. They might not be very good... user reviews are mixed. In the 325/65r18 size the AT has the same tread as the MT; really everything looks identical. In other sizes the AT has a very mild tread. The MT comes in a 315/70r17 size that is only C load rated and 52 lbs which is pretty crazy for a tire this size (34.4" tall). https://www.tirerack.com/tires/tire...wcB:G:s&s_kwcid=AL!3756!3!!!!x!!&gclsrc=aw.ds
    Here is a review on the MT:
    https://youtu.be/1QPVzwmjmAU
